Old 03-19-2012, 02:29 AM   #61
Sparqq
Oddometer: 67
A few weeks ago in bought an alloy swingarm, the guy who sold it to me said it was for a F650 but I wanna try if its fits a F650GS. I've heard it is made by Nico Bakker for Schalber;
Sparqq is offline   Reply With Quote
Old 03-19-2012, 03:27 AM   #62
Damian_74 OP
Damian_74's Avatar
Oddometer: 439
Nice!!!!!!!!!!!!!
Hi Sparqq,
That looks the business!!!!!
Can you please measure up the size of the side rails and the shock mounts (and every thing else if you have the time)
What does it weigh?
Damian
Damian_74 is offline   Reply With Quote
Old 03-19-2012, 03:46 AM   #63
Sparqq
Oddometer: 67
I weighs around 4kg, the steel stock is 6kg???
I measured the inner distance of the fork, where the wheel is mounted, it is 2cm tighter then stock. I didn't measure other dimensions yet. I will try to do it this week.
Old 03-19-2012, 06:16 AM   #64
Aquatic
Aquatic's Avatar
Oddometer: 1,701
It is only 1 picture, and a good one. Not a dig at you Sparqq
But from what I can see you are missing some pieces.
To me it looks like the OEM shock linlages will not work on that swing arm. I could be wrong.
But yes please, as much info and dimensions as possible.
Aquatic is offline   Reply With Quote
Old 03-19-2012, 06:43 AM   #65
Sparqq
Oddometer: 67
I will make some good pictures with the measurements.
Indeed i'm missing the link system, so I will get in contact with the builder of the swingarm to get these.
Old 03-19-2012, 11:13 AM   #66
Parx400
Oddometer: 2,028
Its has both mounts for a KTM chain holder
Parx400 is online now   Reply With Quote
Old 03-19-2012, 05:21 PM   #67
Throttlemeister
Oddometer: 3,907
Very nice, I love the custom fabrication and seeing options for better swingarms
www.throttlemeister.net
Throttlemeister is offline   Reply With Quote
Old 03-26-2012, 05:23 AM   #68
Sparqq
Oddometer: 67
I had to take out my shock absorber for a revision so I could try to fit ALU swing arm. Unfortunately it doesn't fit, the seller told me it is for a F650, it turns out that this swing arm is not wide enough for a F650GS. I think it is useless to make the measurements.....
Old 03-26-2012, 06:16 AM   #69
Aquatic
Aquatic's Avatar
Oddometer: 1,701
Bummer. Any idea what it is from?
Have you wasted money on the swing arm?
Old 03-26-2012, 07:46 AM   #70
Sparqq
Oddometer: 67
I've heard it is made by Nico Bakker http://www.bakker-framebouw.nl/ for Schalber, but don't know if it's true.
I didn't spend that much money on it and try to sell it on ebay, I think some Germans will like it.
I will make some detailed pics and post them here, so it will help your design.
Old 04-02-2012, 11:23 AM   #71
Sparqq
Oddometer: 67
detailed pics:
Old 04-02-2012, 02:18 PM   #72
Aquatic
Aquatic's Avatar
Oddometer: 1,701
Thanks Sparqq
That's great.
Do you perhaps have the measurements of the box section used?
detailed pics:
Old 07-08-2012, 09:33 PM   #73
ergomoto
FOCUS ON THE THROUGH.
ergomoto's Avatar
Oddometer: 83
Thumb Proper GSingle Alloy Swingarm
Been looking for this alloy swingarm mod and thread for a long, long time now Damian-74. Thank you, I sense capable movement on this issue. Much thanks too for the progress lath & mill pics re: the GS/DRZ swap, not to mention Aquatics 3D modeling illustrations. Jakubs TT & Factory swingarm pics prove the alloy work has been done, if not trickled down.
Was disappointed to find no movement from BMW on suspension in general when the Sertao was debuted, you know, to upgrade too.
In the mean time, I'm stretching the simple steel rectangular box channel .82" to better clear an 18" wheel and 130/80 18 DOT knobby. I'm in the middle of the Emig Dakar/KTM Clamp build up front, as it's still cheeper for me to buy that clamp kit & KTM forks than buy a 3 point mill and garage space to work. I have requests for rake angles in to Gary, but hope the rake is closer to the KTM 63.5° than the stock Dakar at 61° to keep the wheelbase at or below 58.5" even after I stretch the swingarm.
Mark S
2004 R1100S[BCR]
2005 F650GS
2004 DRZ400S/E =SOLD=
2004DR200SE
=SOLD=
"Is that what you wanted that to look like?
ergomoto is offline   Reply With Quote
Old 07-14-2012, 04:59 AM   #74
Damian_74 OP
Damian_74's Avatar
Oddometer: 439
Starting to Look Like a Bike Again
Suspension back in – Ohlins all round - 46HRCS in the back and MX46 inverted forks - had MPE in the Sunshine Coast play with the forks and shock. http://www.mpesuspension.com.au/
New bushes/ bearing in all the swing arm and linkage arms and the wheels back on.
Relaced a 18” to the STD hub
Replaced every bolt that I could get reach to rid myself of those dam TX bolts – can’t print what I really think about those things!
Complete lack of time at the moment so the Ally swing arm will have to wait – but it is on the project list – Her list and mine are starting to clash – something about not wanting to have to jump over the bottom two rotten steps on the veranda – Women , want everything!
Have started to build the ally subframe to take the standard fuel tank – using a DR650 rear guard and a cut down STD seat. Queensland Transport offers Single Seat registration which is half that of two seater registration
“Seating modifications Compulsory Third Party (CTP) insurance premiums on motorcycles are determined by the seating capacity of the motorcycle. Conversion of a motorcycle from a two-seater to a single-seater, or vice versa, can be certified by an Approved Person.
For two-seats to single-seat conversion the maximum length of the upholstered section of the seat must be
500 mm or less, and the pillion foot pegs must be removed with any associated brackets and threaded
holes drilled out. You are not permitted to use a removable cowl or other structure fitted over the seat to
reduce the length of the seat. Seating modifications are approved under the Code of Practice; you should seek
advice from an Approved Person before performing a seat reduction modification”
Hope to have it on the road in the next few weeks – depending on what else she adds to the list!
Damian_74 screwed with this post 07-14-2012 at 05:28 AM
Old 07-14-2012, 05:24 AM   #75
Damian_74 OP
Damian_74's Avatar
Oddometer: 439
Indicator lights
Finished my warning light block.
Used LED’s and components form Jcar - http://www.jaycar.com.au/
Ally diecast housing, nutsert’s, selection of LED’s and resistors, micro relay (for the coolant light) and a potting compound to keep it all from shaking itself to death.
Times are GMT -7.   It's 08:40 AM.
