Old 07-14-2012, 10:39 AM   #76
Sparqq
Oddometer: 67
why the need of a relay for the coolant light?
Sparqq is offline   Reply With Quote
Old 07-17-2012, 05:09 PM   #77
Damian_74 OP
Damian_74's Avatar
Oddometer: 413
Coolant Relay
When I was testing the LED set up, the coolant high temperature light always seemed to have a slight glow.
My thoughts on this was that there is a slight earth or continuity in the circuit (possibility in the sender or the computer) , just enough to allow sufficient current flow, to ever so slightly illuminate the LED.
My fix was to use a micro relay – in hindsight this may have been a mistake as I have encapsulated the whole lot in potting mix – if the relay fails – have to rego the entire lot! Time will tell!
Damian_74 is offline   Reply With Quote
Old 07-17-2012, 05:14 PM   #78
Damian_74 OP
Damian_74's Avatar
Oddometer: 413
Pic's
Mark - please share any pic's that you have – we are all guilty of stealing others ideas and work – you might have the solution for some of my issues!
Originally Posted by ergomoto View Post
Been looking for this alloy swingarm mod and thread for a long, long time now Damian-74. Thank you, I sense capable movement on this issue. Much thanks too for the progress lath & mill pics re: the GS/DRZ swap, not to mention Aquatics 3D modeling illustrations. Jakubs TT & Factory swingarm pics prove the alloy work has been done, if not trickled down.
Was disappointed to find no movement from BMW on suspension in general when the Sertao was debuted, you know, to upgrade too.
In the mean time, I'm stretching the simple steel rectangular box channel .82" to better clear an 18" wheel and 130/80 18 DOT knobby. I'm in the middle of the Emig Dakar/KTM Clamp build up front, as it's still cheeper for me to buy that clamp kit & KTM forks than buy a 3 point mill and garage space to work. I have requests for rake angles in to Gary, but hope the rake is closer to the KTM 63.5° than the stock Dakar at 61° to keep the wheelbase at or below 58.5" even after I stretch the swingarm.
Mark S
Old 07-20-2012, 07:29 PM   #79
TobyG
be happy :)
TobyG's Avatar
Oddometer: 544
Originally Posted by Sparqq View Post
detailed pics:
Are you guys sure this swingarm was meant for a F650?
The Schalber Rally bikes used a different swingarm.
Here you go:
Schalber F650 RR (the original carb model)
Same (basic design, that is) swingarm on a 650 GS:
"a scoot (that wouldn't go more than 28mph if you dropped it out of an airplane)" ~duck
"If loud pipes saved lives, then ambulances would run straight pipes instead of lights and sirens." ~Phlemdog
This is why I always wear gloves. How you gonna wipe your butt with hands covered in bandages? ~MrBob
TobyG screwed with this post 06-25-2014 at 02:50 PM
TobyG is online now   Reply With Quote
Old 07-21-2012, 03:10 AM   #80
Damian_74 OP
Damian_74's Avatar
Oddometer: 413
Sub Frame
Ok – found some time and got a good start on the sub-frame.
Main rails - 6060 25mm x 3mm square (radius corner)
Ends – 6061, 25mm billet
Gussets – 5083, 3mm plate
Still lots to do – but I think that it will be about 3kg’s when finished.
Old 07-21-2012, 06:03 AM   #81
Aquatic
Aquatic's Avatar
Oddometer: 1,570
Very nice work D! Very nice.
I assume you keeping notes and sketches for when you get a request for the 2nd and 3rd and.......
Aquatic is offline   Reply With Quote
Old 07-21-2012, 06:08 AM   #82
Damian_74 OP
Damian_74's Avatar
Oddometer: 413
Subframe
If you are offering to push them through on the CNC we might have a deal - as you know - a manual mill take lots of time!
Old 07-21-2012, 06:32 AM   #83
Aquatic
Aquatic's Avatar
Oddometer: 1,570
We need to talk over a beer sometime!
You at home in 2 weeks time?
Old 07-21-2012, 08:31 AM   #84
Kawidad
Kawidad's Avatar
Oddometer: 4,751
Nice work!
Quis custodiet ipsos custodes? - Juvenal
(Who watches the watchers)
Kawidad is offline   Reply With Quote
Old 07-22-2012, 12:04 PM   #85
ergomoto
FOCUS ON THE THROUGH.
ergomoto's Avatar
Oddometer: 83
Thumb +1 On The FABulous Work
Thanks for the progress pics indeed Damion_74. Looking great! I immediately started thinking about how an alloy swing arm's wheel/chain adjusters could similarly be milled and welded in to rectangular box channel. It's the cross over and rear shock link strut mounts that would be con-foundery-in'. Anybody know anything about this swing arm fabricator, if I didn't find this elsewhere at this Forum, if not even this thread? http://www.klpracing.com/index.html
Got me wondering if the commonly milled swing arm wheel adjusters weren't an off the shelf pre-designed resource at some industry level, not unlike the ones on the TT unit or mystery swing arm Sparqq posted(?)
M
2004 R1100S[BCR]
2005 F650GS
2004 DRZ400S/E =SOLD=
2004DR200SE
=SOLD=
"Is that what you wanted that to look like?
ergomoto is offline   Reply With Quote
Old 07-23-2012, 05:48 PM   #86
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 300
Was looking at the 650x as well. Has anyone ever seen/built a updated full tubular frame/subframe that will take all OEM attachment points? Basically a F800 style frame set?
nomad5326 is offline   Reply With Quote
Old 07-24-2012, 12:25 AM   #87
Sparqq
Oddometer: 67
That does look very nice, I think I will do same thing in winter. I guess it saves around 3kg.
Old 07-24-2012, 06:04 AM   #88
Damian_74 OP
Damian_74's Avatar
Oddometer: 413
Subframe Update
EDIT
On first impression, I think that my subframe might actually me a little stronger than the OEM – the stress calculations but the material strength at about the same, but there more stiffeners in mine. Stiffer is not always better – there needs to be some flexibility, steel has a greater fatigue strength than aluminium – the ultimate test will be the track!
Damian_74 screwed with this post 07-24-2012 at 08:07 AM
Old 07-24-2012, 07:51 AM   #89
Damian_74 OP
Damian_74's Avatar
Oddometer: 413
Weight?
I hope that it will be more than 3kg's! It just isn't the subframe - it is all the other stuff that BMW throws in - 2nd set of footpegs, grab rails, luggage rack etc... The all up savings should be over 5kg's - the scales will be the ultimate test!!!!!!!!!!
Old 07-24-2012, 08:42 AM   #90
kubiak
Oddometer: 4,810
nice subframe!
Times are GMT -7.   It's 10:07 AM.
