Old 11-30-2011, 04:27 PM   #1
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Best way to remove a broken bolt extractor?
I broke 2) snap-on bolt extractors in one day. Drilling out the hardened steel of the extractor with a common drill bit isn't happening.
Anyone have a good suggestion on how to extract the extractor??
kirkster70 is offline   Reply With Quote
Old 11-30-2011, 04:30 PM   #2
griffo1962
griffo1962's Avatar
Oddometer: 1,576
Someone with actual knowledge may pipe up soon but there is a process called something like ed??? something like an arc welder but it disintegrates the bolt/extractor..
good luck
griffo1962 is offline   Reply With Quote
Old 11-30-2011, 04:31 PM   #3
Skippii
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,508
Weld something to what's left of the extractor.
"Umm be careful what you say, this is Skippii....
You may get it delivered in the form of a shake or some interperative dance routine that involves nakedness, pizza and a stuffed raccoon..." -DCrider
Skippii is offline   Reply With Quote
Old 11-30-2011, 04:36 PM   #4
Skippii
Hookers, my lad.
Skippii's Avatar
Oddometer: 6,508
good luck
Carbon arc gouging, maybe? That would get rid of the extractor.
Same with a Thermic Lance.
I'd worry that both would be somewhat...um...destructive to the workpeice. I do some to recall there was something else more specifically used for this, now that you mention it, though....something like a modified plasma cutter or something....I can't think what it was called.
Old 11-30-2011, 04:56 PM   #5
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
DUH! Why in the world I didn't think of that, I have no idea! Ha Ha! I can be the biggest doofus sometimes.
I did think of giving it a short blast with a plasma cutter but thought better of it. I'm sure I'd do more harm than good.
Next time I'm on break from work, I'll give the welder a try. Thanks for the idea, Skippii!
I was thinking along the lines of there might be some sort of diamond tipped drill bit sharp enough to cut the hardened steel that I didn't know about.
Old 11-30-2011, 05:05 PM   #6
Benesesso
Benesesso's Avatar
Oddometer: 9,898
Carbon arc is destructive? (heh heh) EDM would work, but you don't need it. Either weld something to it or use a carbide burr in a high speed die grinder.
US out of the UN, UN out of the US.
Benesesso is offline   Reply With Quote
Old 11-30-2011, 05:14 PM   #7
kirkster70 OP
moto junkie
kirkster70's Avatar
Oddometer: 1,905
Welding it is. Thanks, Benesesso.
Old 11-30-2011, 06:36 PM   #8
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,330
How big is this extractor? My suggestion is using a carbide dental burr in a dremel, but seeing a pic might help form a different opinion. My concern with welding is the risk of welding something to the side, and now you have an easy out welded into the hole. It doesn't even have to be much, like a tiny slag spatter.
GreaseMonkey is offline   Reply With Quote
Old 11-30-2011, 06:47 PM   #9
P B G
Oddometer: 10,001
You minimize the risk by welding through a nut. would also help to know if the hardware is in aluminum.
Old 12-01-2011, 02:38 AM   #10
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Rocklinizer. At BIG, fancy machine shops everywhere...
Old 12-01-2011, 04:16 AM   #11
Bounder
ExternallyDisplaced
Oddometer: 925
Spark erosion?
Bounder is offline   Reply With Quote
Old 12-01-2011, 06:05 AM   #12
willys
willys's Avatar
Oddometer: 2,904
Been here....done this!!!! It works but takes time with very minimal damage to the part. When there isn't enough material close enough to weld to, that is......still a better bet IMHO when dealing with a delicate bike engine, etc.
willys is offline   Reply With Quote
Old 12-01-2011, 06:23 AM   #13
ohgood
ohgood's Avatar
Oddometer: 2,998
mmm, hope there aren't any bearings or seals between the work an the ground...
have you tried an impact driver on the ez out or a left hand cobalt drill on whatever is stuck ?
Yes, Android AND iphone GPS works without cellular data. Use offline maps and enjoy. (thanks drtbyk!)
ohgood is offline   Reply With Quote
Old 12-01-2011, 09:33 AM   #14
slidewayes
slidewayes
slidewayes's Avatar
Oddometer: 561
Edm
Electrical Discharge Machine Is the correct way to remove broken drill bits ,taps and other hard tools(ez outs) and not destroy the part you were trying to save in the first place. Find em fast in the yellow pages
slidewayes is offline   Reply With Quote
Old 12-01-2011, 09:33 AM   #15
willys
willys's Avatar
Oddometer: 2,904
I should say used a dremel to grind away the stuck part ....but I have also welded one too.
Times are GMT -7.   It's 03:47 PM.
