Old 12-01-2011, 11:42 AM   #1
fullmonte OP
Reformed Kneedragger
fullmonte's Avatar
Oddometer: 5,399
Ice on the INSIDE of the windshield?
Went to my car this morning and there was a nice layer of ice on the inside of the windshield. The first time, it happened a couple of weeks ago during our first frost, but I thought maybe it was a fluke. Guess not. So now it looks like I'll have to spray the glass with de-icer and wipe it with a towel for the entire winter. All the doors and windows were shut and so was the sunroof. The vehicle is a 2006 Honda CRV which I bought last April, after our last frost of the season. Any ideas on this interior frost intrusion?
"If you are looking for the typical ride to a restaurant, eat tacos, hold the middle finger over the food, stop and take a picture of a gravel road type ride, you probably won't be interested." - dlrides
"A guy I know was the lead researcher for the University of Utah federally funded study of cellphone and texting use while driving. He found that your twice as dangerous as a drunk while using your cell phone and I think it was up to six times worse if the driver was texting."-dakardad
fullmonte is offline   Reply With Quote
Old 12-01-2011, 11:43 AM   #2
anotherguy
anotherguy's Avatar
Oddometer: 6,631
Leaking heater core and a dirty windshield.
you don't see luggage racks on a hearse..........act accordingly
Old 12-01-2011, 11:56 AM   #3
rallybug
Local Yokel
rallybug's Avatar
Oddometer: 8,099
Someone who has obviously never driven an old VW Bug in winter
Ben
My Ride Reports
rallybug is offline   Reply With Quote
Old 12-01-2011, 12:00 PM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,932
The AC system has to work for most, not all, cars window defrosters to work.The AC system "dries" the air that is then heated to defrost the windshield.
You will have to spend some time getting your car ready to travel. In the old days we actually warmed the car up before driving away. Modern cars can be driven right away in most of the coldest weather but you still have to be able to see so maybe you have to wait for the defroster to work before driving away.
I hope this helps. Is there really a problem I don't see?
Charlie
disston is online now   Reply With Quote
Old 12-01-2011, 12:20 PM   #5
troidus
Oddometer: 15,707
Damp carpet will cause it, too.
troidus is offline   Reply With Quote
Old 12-01-2011, 12:25 PM   #6
the_gr8t_waldo
Oddometer: 2,149
the defrosting opperation produces water, that's normally allowed to drain out of the car's defrost section. sometimes that drain gets clogged and that water, collects and evaporates and then re condensens on the windsheild right above the vents. from there, it freezes if conditions are right. if enought collects, you might start to find the the carpet is also starting to get wet
the_gr8t_waldo screwed with this post 12-01-2011 at 03:23 PM
the_gr8t_waldo is offline   Reply With Quote
Old 12-01-2011, 01:54 PM   #7
fullmonte OP
fullmonte's Avatar
Oddometer: 5,399
Originally Posted by the_gr8t_waldo View Post
the defrosting opperation produces water, that's normally allowed to drain out of the car's defrost section. sometimes that drain gets clogged and that water, collects and evaporates and then re condensens on the windsheild right above the vents. from there, it freezes if conditions are right. if enought collects, you might start to find the the carpet is also wet
This makes sense. I've never had ice form on the inside of a windshield before, just the outside. Even my old 240Z with Flintstone floorboards didn't have this problem.
Old 12-01-2011, 03:24 PM   #8
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Originally Posted by troidus View Post
damp carpet will cause it, too.
this.
Old 12-01-2011, 03:34 PM   #9
mewapiti
Schlub
mewapiti's Avatar
Oddometer: 43
If equipped, make sure the recirculate mode is not activated. Had the same problem many years ago.
mewapiti is offline   Reply With Quote
Old 12-01-2011, 04:22 PM   #10
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Good point, in the interest of fuel economy sqeaking every last bit, some newest are cars default to recirc, even if you'd parked it in fresh air mode. Still others have dropped the icons, the "MAX A/C" label too.
Old 12-01-2011, 04:23 PM   #11
VStromTom
Oddometer: 1,579
I owned a POS Chevette back in the 70's. Damn thing frosted up on the inside of the windshield. Finally I pulled back the carpet and the floorboard was almost gone. That was the source of the frost/ice on the inside of the car. If this is a recent thing for your car, check the floorboard. It's either gone or you have a leak somewhere that allows water inside the car.
VStromTom is offline   Reply With Quote
Old 12-01-2011, 04:40 PM   #12
rapidoxidationman
Easily trainable
rapidoxidationman's Avatar
Oddometer: 8,914
Originally Posted by VStromTom View Post
...a POS Chevette...
Redundant.
Just say'n
Patrick:
I know I'm feeling badly when I have no interest in speeding
rapidoxidationman is offline   Reply With Quote
Old 12-01-2011, 05:58 PM   #13
Tosh Togo
Oddometer: 1,594
...a POS Chevette back in the 70's...
Originally Posted by rapidoxidationman View Post
Redundant.
Just say'n
True, but some things deserve the double drubbing.
Default A/C on is the only way to go.
Tosh Togo is offline   Reply With Quote
Old 12-01-2011, 06:13 PM   #14
GreaseMonkey
Preshrunk & Cottony
GreaseMonkey's Avatar
Location: The only county in Illinois with no train tracks
Oddometer: 5,328
Can you describe where/how the ice has coated the windshield? Is it all over, or is it on the top half and the lower half is clear, or is the top clear and the ice is centered over the defroster ducts?
How about the other windows- especially the back- are any of them frosted too?
The good news is that it isn't your heater core, as that deposits a film that smears and is impossible to see clearly through and you definitely would have commented on that.
Last question is do you have a sunroof? If so I'd look at the drain vents there first.
GreaseMonkey is offline   Reply With Quote
Old 12-01-2011, 08:50 PM   #15
Lee Dodge
Oddometer: 264
+1. One hand the steering wheel, ice scraper in the other.
05 DL650
Lee Dodge is offline   Reply With Quote
Times are GMT -7.   It's 08:19 AM.
