Old 12-02-2011, 02:09 PM   #1
crackhead OP
Oddometer: 1,253
klr650.com Grip Heaters?
I am replacing a set of work out Dual-Star grip heaters on my wife's KLR and ordered the setup from KLR650.com. The wiring on the clutch side finally gave up the ghost where it connects to the heating element. I thought they were the same ones, but upon closer inspection, it appears that they are not. Has anyone used them and if so are they worth a damn? If not, Ill send them back and get something else. It looks like the KLR650.com units use the resistor for one side, is that a weak design? Thanks. Just for reference:
KLR650.com
Dual Star
'98 1100GS - Mine
'02 F650 Dakar - Her's
'01 XR50 - Spawn's
crackhead is offline   Reply With Quote
Old 12-02-2011, 02:28 PM   #2
Krabill
Krabill's Avatar
Oddometer: 4,888
Those look an awful lot like the ones I buy at cycle gear. They work great.
I did have one of the wires come off the throttle side on one of my bikes, but I just soldered it back on. Still working great.
Loud Sucks!
www.wrrdualsport.com
www.designatedvaping.com <- for all your electronic cigarette needs
Krabill is offline   Reply With Quote
Old 12-02-2011, 02:32 PM   #3
crackhead OP
Oddometer: 1,253
I just looked at the ones over at www.cyclegear.com. They look like the same ones. Thanks for the heads up.
'98 1100GS - Mine
'01 XR50 - Spawn's
Old 12-02-2011, 02:37 PM   #4
redog1
KLR650-2009
redog1's Avatar
Oddometer: 1,800
Looks like the same set I got from KLR650.com...
a year and a half ago, they've worked great for me, no problems in the last 15k miles.
No, I don't know where that road goes, let's find out!
redog1
redog1 is offline   Reply With Quote
Old 12-02-2011, 04:08 PM   #5
willys
willys's Avatar
Oddometer: 2,904
I also bought the cheapest heaters on the market. They look the same with a resistor on one side. Last winter I had to replace the resistor as it broke off right at the cerramic. If you stop the resistor from being able to vibrate they will last a long time. Mine lasted a few years before letting go. That is 10's of thousands of kms a year. I will buy the same ones again if they finally to give up the ghost. I see no real reason to spend double or more for a set inside a set of grips......
Hope this helps
willys is offline   Reply With Quote
Old 12-02-2011, 04:23 PM   #6
crackhead OP
Oddometer: 1,253
Hope this helps
So, zip tie it to the frame with some foam behind it maybe?
'98 1100GS - Mine
'01 XR50 - Spawn's
Old 12-02-2011, 04:45 PM   #7
willys
willys's Avatar
Oddometer: 2,904
It does get warm if not hot right......so don't put anything that will catch fire so to speak or get harmed by heat. I used thin mechanics wire and wired it to a piece of metal and attched the metal to the back of my dash. Plus zip tied the wiring to stop it from vibrating.
Old 12-02-2011, 10:11 PM   #8
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,369
The heaters without the resistor are superior. Sometimes the resistor is trouble free, but always something to worry about, once you have had trouble. The other thing to think about is all the power you are wasting by heating it. The Symtech/Dualstar type is only about 1/3 more money. FWIW
___________________________________________
So much riding-so little time
Xcuvator is offline   Reply With Quote
Old 12-03-2011, 06:51 AM   #9
aaronrkelly
Oddometer: 535
Those look identical to the cheap Tusk brand ones I got for my ATVs. On the ATVs that dont get rode often, they are still working. For those that got alot of use - they are all broken. Wires pulled off the resistor on a few (despite being ziptied down).....random broken wires......etc.
I run the Symntec on my motorcycles.....Ive had some as long as 5 years and they are still going strong.
I pulled them off all the ATVs......Im not impressed.
I wouldnt waste the time to install them - your just going to be doing it agian soon if you ride often.
Iowa to Grand Canyon....and back
http://www.advrider.com/forums/showthread.php?t=615692
a quick run to the Black Hills
http://www.advrider.com/forums/showt...8#post14248448
aaronrkelly is offline   Reply With Quote
Old 12-03-2011, 08:35 AM   #10
pchGS
Mark
pchGS's Avatar
Oddometer: 97
As mentioned before the resistor is a failure spot. On the bike I just picked up the wire was also broken at the resistor. Being on a budget so I can buy other farkles I went into the local RadioShack and picked up a replacement and put it in.
Also as mentioned if you do use them make sure the routing of the resistor doesn't have any stress on it at that location. or you will soon have a set of non-heated grips.
"My" preference would be to go the route of less failure prone.
Good luck!
pchGS is offline   Reply With Quote
Old 12-03-2011, 09:00 AM   #11
el profe
el profe's Avatar
Oddometer: 144
I had the el-cheapo grip heaters similar to those in the first photo with the resistor and hi/lo switch for about a year before the wire broke right at the resistor. The low setting was too low, so I just ditched the resistor altogether and just run the grips on high all the time. I've had them wired like this since 2006 with no issues. I've heard of grip heaters that have a resistor to cool off the throttle side to match the clutch side, but the ones I installed the resistor was for the hi/lo function, which was as useless as tits on a boar.
I could never find a place to put that ugly, industrial-size hi/low switch. Getting rid of the resistor let me use the little Aerostich bar mounted switch.
I'd get the cheapos again, and I'd cut out the resistor from the start.
el profe is offline   Reply With Quote
Old 12-03-2011, 03:56 PM   #12
eakins
Butler Maps
eakins's Avatar
Oddometer: 18,991
http://lockitt.com/AccessoriesGrips3.htm#oxhg696
Alaska
Butler Maps website:
http://www.butlermaps.com
Old 12-04-2011, 03:20 AM   #13
greer
Oddometer: 3,820
Resistor Alternative
I've always just snipped the resistor and run High or Off, but my husband has been so happy with this little trick I try to share it every time the issue of grip heaters comes up. From RustySpokes over on the WRR thread:
OK boys and girls, I'm going to let you in on a little secret. I found an easy and cheap alternative to the dreaded resistor in your heated hand grip circuit.
Get a two terminal, heavy duty turn signal flasher and wire it in place of the resistor.
This is what your looking for...
On low your grips will run at about half the power of the the high setting, and thus, about half the heat. The flasher will turn on and off acting as a poor man's pulse width modulation unit. But you only get one pulse width.
I have also used this idea to make a "controller" for my homemade heated vest.
Jim
Jim's picture didn't come up, but here's a Google pic:
Anyway, Doug bought one at Autozone, wired it in and has been happy as a lark.
Sarah
greer is offline   Reply With Quote
Old 12-11-2011, 03:20 PM   #14
mikesova
mikesova's Avatar
Oddometer: 1,931
I just saw a set that is so cheap that I couldn't turn it down. We'll see how they go.
http://www.ebay.com/itm/Motorcycle-H...65529724305551
2009 Kawasaki KLX250S
2005 Yamaha TW200 (Wife's bike)
2005 Yamaha FZ6
2009 Honda Ruckus
mikesova is offline   Reply With Quote
Old 12-11-2011, 04:49 PM   #15
Xcuvator
Justa Venturer
Xcuvator's Avatar
Oddometer: 1,369
I like that idea, very clever if you already had the resistor type. But if I needed to buy some more heaters. I would still buy the non resistor type.
Times are GMT -7.   It's 09:52 AM.
