Old 11-17-2012, 05:05 PM   #1
Grits&Gravy OP
Grits&Gravy's Avatar
Oddometer: 362
Leo Vince W/ or W/O baffle insert
Grits&Gravy screwed with this post 12-14-2012 at 09:18 AM
Grits&Gravy is offline   Reply With Quote
Old 11-17-2012, 05:09 PM   #2
johngil
Reseda, CA
johngil's Avatar
Oddometer: 3,801
Borrow a scale and a db meter and you'll be that much farther ahead I'd say.
johngil is offline   Reply With Quote
Old 11-17-2012, 06:33 PM   #3
Grits&Gravy OP
Oddometer: 362
Grits&Gravy screwed with this post 12-14-2012 at 09:19 AM
Old 11-17-2012, 06:42 PM   #4
runnin4melife
Oddometer: 806
It is not going to be a miracle reduction nor a miracle increase in HP, subtle difference. If you don't like it I will give you $300 for it :-)
runnin4melife is offline   Reply With Quote
Old 11-17-2012, 06:59 PM   #5
LukasM
Oddometer: 5,426
Originally Posted by grneggz View Post
I don't need to borrow a scale. Just saying that people talk chit.
People talk shit but you are the one relying on your hand as a scale? How very scientific of you, it's obviously very well calibrated.
If you want some actual data, the original carbon LeoVince saved 2.2 kgs over stock, which is a reduction of over 40%. Now go and weigh yours to see if the One is really that much heavier.
Gotta say though, for me the much smaller size and better looks and sound would be enough!
Old 11-18-2012, 07:39 AM   #6
Grits&Gravy OP
Oddometer: 362
Old 11-18-2012, 08:39 AM   #7
DoWorkSon
Oddometer: 270
On previous bikes with aftermarket exhaust, I've always noticed more/heavier backfiring with the insert removed. Especially on bikes that run lean already, an more "open" exhaust is not necessarily the best.
For example on my Ducati I had a very open custom exhaust... No insert and loud as hell. However when dynoing it, it hurt performance. I installed a baffle and performance improved. This is an extreme example with a crazy loud and open exhaust.
I think you will notice more backfiring with it reduced, but nothing extreme.
DoWorkSon is offline   Reply With Quote
Old 11-18-2012, 08:43 AM   #8
ebrabaek
Oddometer: 4,763
In case your didn't search........
http://www.advrider.com/forums/showthread.php?t=667297
Erling
Old 11-18-2012, 11:26 AM   #9
Grits&Gravy OP
Oddometer: 362
Old 11-18-2012, 11:30 AM   #10
Grits&Gravy OP
Oddometer: 362
Old 11-18-2012, 12:32 PM   #11
LukasM
Oddometer: 5,426
I run mine with the baffle in, it's too loud and annoying to me otherwise.
I don't think you will pick up any extra power from running without an insert either, unless you alter the fuel injection map at the same time. It's already lean with the stock can.
Old 11-18-2012, 03:10 PM   #12
ebrabaek
Oddometer: 4,763
Engines need some backpressure to perform better. Obviously, if you knew where the engine performed best and at what level of backpressure, then you could engineer and size the exhaust to create the required backpressure, but that's not what I'm trying to do.
Just asking if you run your LV w/ or w/o the insert....
I actually now have this.......
http://advrider.com/forums/showthrea...=783641&page=9
As I would agree with Lukas, imho, the LV one is obnoxious open......but the motor was breathing better, a bit better throttle response, and just a few mpg better open, I could not handle the tone. That is me...how ever, and is a biased thing. Several fellow riders like theirs open, and that is all great. As far as the motor goes. I think it ran better open.... But yet again, That is why I made my own pipe. I think the back pressure is created with the cat, and the headers. The natural flow through the pipe is in pulses, and there are many different ways to create the back pressure you speak of as goo for the engine. Usually the worst way to do this is by narrowing the exit.
Erling
Old 11-19-2012, 11:01 AM   #13
itsatdm
itsatdm's Avatar
Oddometer: 4,935
I run with baffle in because of the noise.
I did a lot of experimenting with a 680cc single cylinder bike and a more open exhaust. No dyno, just a stretch of 7% grade marked off in increments. A carbed bike. I ran it with and without the air box lid, different jetting and a host of different length baffles.
It all made a difference where in the rpm range the power came on. Short story was, it made more power higher in the rpm range with an open exhaust, but it always came at the expense of low rpm power.
I think FI can negate some of that, by fine tuning the afr on the go, but I really question how rich a mixture the stock mapping can provide. I saw a 14.4 afr on a dyno with the stock can, but flow more air and the ratio should be higher. so I suspect the result will be similar.
itsatdm is online now   Reply With Quote
Old 11-19-2012, 11:06 AM   #14
Gumbeaux
The Chameleon
Gumbeaux's Avatar
Oddometer: 820
Leo Vince
Running with the baffle. no backfiring, but maybe a little more growl/pop on deceleration than stock.
I love the new sound....but without the baffle it would be a little loud for my taste, and I am trying to get along with the hikers, horsers and bikers in our forest as well...can't give them any more reason to try and keep us out...
I doubt there is any more power...for me this was about a little weight, a slimmer look, and a better sound...typical farkle therapy.
Gumbeaux
Gumbeaux is offline   Reply With Quote
Times are GMT -7.   It's 04:41 PM.
