Old 12-03-2011, 08:40 AM   #1
hardwaregrrl OP
ignore list
hardwaregrrl's Avatar
Oddometer: 7,523
Not having a good day....advice needed.
I'll just start with some pics.
Photo & Video Sharing by SmugMug
"Kick me when I'm down" pic
The main problem is that I'm flat broke. Haven't worked steady all year and it's beginning to show in my bank account. I want to repair it, but is it so far gone that I should just save my pennies for a new subframe? I also just had the seat recovered.
Small tip over in the garage pushed it over the edge I'm guessing. It's funny, after Mike and I picked the bike up and assessed that nothing appeared to be broken, he made this comment: "that's a well sorted dual sport bike. It falls over and nothing has broken."
Old 12-03-2011, 08:48 AM   #2
baldwithglasses
Godspeed, Robert
baldwithglasses's Avatar
Oddometer: 798
Damn, Jenna.
Doesn't Brad have a spare subframe?
baldwithglasses is offline   Reply With Quote
Old 12-03-2011, 08:50 AM   #3
DaveBall
DaveBall's Avatar
Oddometer: 1,163
I feel for ya.
If it were my bike, I would be stripping that subframe off and taking it to a good welder friend. Have it all done up and maybe add a little more gusseting in suspect areas. Then if I was really attached to the bike, maybe save up for a replacement subframe for in the future.
My old '79 RT ended up with numerous frame cracks and broken welds after 25 years and close to 350,000 hard miles. Ever seen an RT used like a G/S. Sold the whole thing to a friend who took it all apart and did the welding himself. Did a complete rebuild on it and now has another 200,000 miles on it. No new cracks.
DaveBall is offline   Reply With Quote
Old 12-03-2011, 08:51 AM   #4
fishkens
Further...
Oddometer: 5,149
Oy, I wish I had a sub-frame to send to you because that zip-tie isn't going to hold.
Hang in there, Jenna.
fishkens is offline   Reply With Quote
Old 12-03-2011, 08:53 AM   #5
hardwaregrrl OP
ignore list
Oddometer: 7,523
Ha!!!! Just fyi, it's there to hold my vent tube out of the way, but that does seem like something I would try?....
About to take it apart and get friendly with it.
Old 12-03-2011, 09:48 AM   #6
England-Kev
Oddometer: 3,628
Hey Jenna, there is nothing so bad there that a good welder couldn't sort in an hour or two. so strip it down, make some cardboard templates, get some reinforcing brackets cut, and take it to your local engineering college and have them weld it up in one of the classes.
Good luck with it..
England-Kev is online now   Reply With Quote
Old 12-03-2011, 10:05 AM   #7
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,190
Looks like this was coming on for a while!
One nice thing about these bikes - they've got good manners!
Just think - it had the good sense to fail in the garage. How many other bikes are that civilized???
Doesn't look like anything too horrible there - just pull it apart and fix it! Not a big deal. Maybe take a good close look at the main frame while you're at it.
Old 12-03-2011, 10:10 AM   #8
One Less Harley
OH.THAT'S GONNA HURT
One Less Harley's Avatar
Oddometer: 4,728
Jenna, it's not that bad. Like others have said, pull the sub frame off and take this opportunity to add some gussets. Go ahead and cut the old gusset which is braking out and make another one. If it were mine where the tubing is cracked. Go ahead and cut both sides add another tube inside and then weld up the frame. The inner tube will provide support for the weak area.
It's easy to make the gussets with a $20 angle grinder, cutoff wheel and cardboard templates.
Does beater or Baldwglasses have a welder???
I'm w/ you on the money thing. Saw your Areo stitch and it'd fit me, but I really shouldn't spend the money.....damn it.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
Old 12-03-2011, 10:16 AM   #9
hardwaregrrl OP
ignore list
Oddometer: 7,523
Hey Richard, I have a welder. I'm just not the most "creative" when it comes to welding. But I will be taking a stab at it. As far as the Darien goes, do you need a jacket? I'm happy to wait for payment if you need it. I know where you live...so
Old 12-03-2011, 10:23 AM   #10
One Less Harley
Oddometer: 4,728
I've got a First Gear which is acceptable. I've got to be smart w/ what little money I have...starving student, the self unemployment thing you know about that.
Don't use that damn flux core welder on the frame, a mig is SO much better!!!!!!! If I were in your shoes get someone who can weld as you need good penetration with the weld!!! Just guessing that you might not be all that good. If you don't know a good welder...oh come on someone at the Harley dealer can weld it for you!!! If not what about a local vocational school?? Go by and talk to the instructor he'll be able to help you out I'm sure!!! As far as bracing goes, don't forget that a brace might get in the way of some fasteners and other things.
I'd look into adding a gusset to the opposite side of the broken one. Where your zip tie is. Do it on both sides. Like I said make sure you don't block off anything you'll need access to for disassembley.
2004 BMW R1150RS
1984 BMW R80G/S
(wrenching index)
One Less Harley screwed with this post 12-03-2011 at 10:30 AM
Old 12-03-2011, 11:35 AM   #11
walkingbear
walkingbear's Avatar
Oddometer: 3,582
sub frame
Jenna
I have a spare sub frame you can borrow until you get yours fixed.
Won't need back for 6 months.
Just pay for shipping it or maybe we can chip in and you can have a merry xmas
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 12-03-2011, 12:10 PM   #12
Bigger Al
Still a stupid tire guy
Bigger Al's Avatar
Oddometer: 7,960
Originally Posted by walkingbear View Post
Jenna
That's the Old's Cool spirit, right there!!
"I'd rather wake up in the middle of nowhere than in any city on Earth."
Steve McQueen
Bigger Al is offline   Reply With Quote
Old 12-03-2011, 12:49 PM   #13
walkingbear
Oddometer: 3,582
frame
just talked to Len, if I was earlier he could have taken it back east.
Oh, well..................
Old 12-03-2011, 01:02 PM   #14
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,848
I'm having a hard time telling what the kick me when Im down pic is...
But heck this is just a subframe... No worries, its a sign of maturity and correct usage
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 12-03-2011, 01:06 PM   #15
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
i've got an r100gs subframe on the shelf. you'll end up needing other parts, like a seat and other stuff, but if it helps you i'll send it your way.
bmwblake is offline   Reply With Quote
Times are GMT -7.   It's 10:30 AM.
