Old 04-16-2012, 11:41 PM   #16
motomal
motomal's Avatar
Oddometer: 175
So we have perfectly good original sensors? Let's make the two mounting holes slightly slotted, it only needs 1 to 2 mm right? The should then be enough rotation in the switch to get it lined up correctly and it shouldn't affect the oil seal either.
I'll dig out the old part and see about modifying it over the next few days...
2007 KTM 950 SM
motomal is offline   Reply With Quote
Old 04-16-2012, 11:44 PM   #17
motomal
motomal's Avatar
Oddometer: 175
Originally Posted by kennyh View Post
Same issue here for a good while now. Mine has progressed to the point where the light comes on in second and stays on until I tap it up to third. Shifting is otherwise fine. Wonder how many of us have extra switches laying around now? I've gotten used to it. No neutral light on my 450 either...
It just occurred to me that if you still have the EPC fitted and enabled on your bike it could be all to cock if it thinks it's in 2nd when it's actually in 3rd and so on. I know we have EPC in the EU but not sure on US models?
2007 KTM 950 SM
Old 04-17-2012, 08:09 PM   #18
kennyh
kennyh's Avatar
Oddometer: 292
Originally Posted by spencergt66 View Post
LOL glad Im not the only one its really not that big of a deal but at the same time its one of those things that just gets to ya
Agreed, I much prefer to have things working as designed. I still giggle like a shoolgirl every time I ride the thing though. What a motorcycle it is!
Smugmug referral code : 01cndVMii0Dl2
kennyh is offline   Reply With Quote
Old 04-21-2012, 02:34 PM   #19
pebble35
pebble35's Avatar
Oddometer: 1,564
This all sounds a bit familiar - read my story here
http://www.ktmforum.co.uk/adventure/...next-week.html
Done 15,000 miles now since the bike went back together and the light is still working fine
Proud to be supporting Pyndon
www.lyndonposkittracing.com
www.bikersjersey.com for all your KTM parts
A 2,400 KM ride around Egypt by Scooter - ride report here
pebble35 is online now   Reply With Quote
Old 04-21-2012, 02:38 PM   #20
spencergt66 OP
Oddometer: 789
Dont think mine has moved quite so much as mine only shows neutral half way to 2nd
spencergt66 is offline   Reply With Quote
Old 04-22-2012, 06:35 AM   #21
kennyh
kennyh's Avatar
Oddometer: 292
Looks like the answer finally, thanks!
Were you able to move the end plate of the shift drum that was removed? Was the plate glued in to position or something? Just trying to figure out if there is some potential for failure in the part that needs to be addressed.
Old 04-22-2012, 02:34 PM   #22
pebble35
pebble35's Avatar
Oddometer: 1,564
From memory it was a tight push fit - not glued or pinned in place. Got the old part at work and will check tomorrow.
Old 05-06-2012, 09:45 AM   #23
motomal
motomal's Avatar
Oddometer: 175
Had a weather window this afternoon and tackled the issue. I had a look at which way the spring loaded contact moved when I moved the gear lever towards 2nd and figured the holes in the sensor needed elongating in the anti-clockwise direction when viewed from the outer face of the sensor. 15 minutes with a needle file and…
Trial fitted it but not quite enough rotation. I was trying to leave a little of the brass in the hole but not sure if it was that important. Anyway, a little more filing and…
Perfect!
Don't know if it will last but my neutral light now comes on when I'm in neutral, yay!
I thought about trying to rotate the disc on the end of the shift drum but thought that it was likely I would knock something out of alignment with the gear selectors, especially not having seen the inside on the cases. A fix for now anyway especially as I modified the old, now spare sensor.
2007 KTM 950 SM
Old 05-06-2012, 10:09 AM   #24
Peanuts
Peanuts's Avatar
Oddometer: 1,703
I think I would make up a tool and try turning the disc on the end of the drum (without breaking the motor apart), then pop mark the edges to lock it in place ;)
Peanuts is offline   Reply With Quote
Old 05-06-2012, 10:55 AM   #25
motomal
motomal's Avatar
Oddometer: 175
I'm guessing the disc with the two spring-loaded contacts is separate to the rest of the drum? It must be pretty tight in there despite the fact it can obviously move! I'd be very reluctant to apply more than a little force, even just turning the disc for fear of knocking the shift forks out of alignment, after all something is going to be resisting the turning force you will be applying.
Maybe someone braver can try! For now, I'm happy.
2007 KTM 950 SM
Old 05-06-2012, 11:35 AM   #26
spencergt66 OP
Oddometer: 789
Wicked Hmmm
Perfect!
I was thinking of cutting the ears off and then making a sting bac with a sep to re-clamp the sensor on this way if the disk does move again a simple turn of the switch is all that is needed
Old 05-06-2012, 12:32 PM   #27
motomal
motomal's Avatar
Oddometer: 175
I know what you're saying, if the disc on the shift drum keeps moving then I'm going to run out of material to elongate the holes through! Cross that bridge when I come to it I think!
2007 KTM 950 SM
Old 05-06-2012, 06:59 PM   #28
spencergt66 OP
Oddometer: 789
Thumb
Might have to try that I wonder how far off mine is?maybe I'm over thinking this
Old 12-06-2013, 12:09 AM   #29
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,100
So is it specifically a 950 problem?
I was wondering if there are any 990s with the same issue.
Anybody?
Old 12-08-2013, 03:22 AM   #30
pebble35
pebble35's Avatar
Oddometer: 1,564
Anybody?
Mine was a 990 (2007 model year)
Times are GMT -7.   It's 03:19 PM.
