Old 12-29-2012, 11:02 AM   #241
harcus OP
harcus's Avatar
Oddometer: 1,322
Originally Posted by Nice_Rumble View Post
http://www.shop.globetrottin.com/pro...&categoryId=33
Is this the rack you are referring to? Where does the aluminum mount attached to the middle cross bar attach?
Aluminum mount? You may be referring to the RotoPax mount...There is a Pax mount to put on the top of this rack. It will soon be on the web site. If you plan to carry much gear & fuel (up to 60 lbs tested), the larger rack is preferred.
Want Creative Adventure Products? - See Globetrottin.com
Current rides - '14 KTM 1190 R Adv <2k, '07 990Adv 39k, '12 500EXC 7k, '09 GasGas 300 Raga
harcus is offline   Reply With Quote
Old 12-29-2012, 11:05 AM   #242
harcus OP
harcus's Avatar
Oddometer: 1,322
Will the Rotopax plate hold a 2 gallon tank? Your looks like a 1 gallon.
I have carried the 1.75 as well as the 1.0 gal on it. I guess the 2 would fit but haven't tried it.
Old 12-29-2012, 03:09 PM   #243
Hueychief
FNG
Hueychief's Avatar
Oddometer: 76
Sandwiched in with the seat mount thru-bolt.
Waterboarding Works
KTM 500EXC
Hueychief is offline   Reply With Quote
Old 12-30-2012, 11:13 PM   #244
dieselcruiserhead
Oddometer: 1,419
Do you mean the metal wishbone looking thing under the rack? That's included with the rack and is stainless steel (correct me if I'm wrong Jim?). It mounts to the seat lock collar and the other end mounts to the upper rack. there is a small tab that attaches to a muffler attachment bolt but this is mostly for alignment only, there is little/no actual load on this bolt. And then the bottom of the rack meets steel.
The alum subframe on the 08 and later Ktms is super dinky and chincy. On earlier bikes I used to drill holes in the plastics and add straps, but I don't think this will work well on 08 and later bikes. As a result this is the best approach I've seen from anyone. It completely removes the load from the subframe other than from the beefier upper section. Brilliant! Plus it looks good, is still light, and works great!
andreshoumatoff.smugmug.com
Grand Staircase Escalante Road Reports
Cycles South Vintage Moto Trek Movie - check out all 7 parts
dieselcruiserhead is offline   Reply With Quote
Old 12-31-2012, 06:40 AM   #245
Nice_Rumble
Nice_Rumble's Avatar
Oddometer: 2,247
Thanks guys (Jim). I was asking about the steel piece between the rack and seat lock collar. Just didn't know where it went but assumed it was to support the rack in some way. Very nice and definitely looks like the way to go. I would want the larger rack as I have a 2 gallon Rotopax and will be carrying gear.
Noise annoys, ride stealth
Member: CCCOFVT, MVTR, NETRA
2013 KTM 500EXC
Nice_Rumble is online now   Reply With Quote
Old 12-31-2012, 07:40 AM   #246
ThumperDRZ
Bouncing off Rocks!
ThumperDRZ's Avatar
Oddometer: 2,399
Who makes the side bags?....Thinking Giant Loop but didn't see them there....I like the way they mount.
"If you're going through hell.......Keep going!"
On Hiatus
ThumperDRZ is offline   Reply With Quote
Old 12-31-2012, 08:45 PM   #247
harcus OP
harcus's Avatar
Oddometer: 1,322
No, not GL. These are proto units from RTE / Globetrottin. Same as the rack. They are a "side loading" dry bag with "daisy chain" straps to hold them in place. These will soon be on the Globetrottin. com site. This is all part of the mini rack system.
Old 01-03-2013, 09:33 PM   #248
dieselcruiserhead
Oddometer: 1,419
Here's a better pic of the wishbone and some closer pics of the rack...
The wishbone attaches at the durable part of the upper rear subframe...
Jim/Harcus, the man himself..
The lower portion of the rack attaches to the steel main frame at the same spot where the aluminum subframe attaches. I've also bent my rear subframe in a wreck and this rack also protects the sub frame..
The rack works for both '08-11 models and 12/13 500s because they have [nearly??] identical rear sub frames.. For the 08-11 you have to cut a small hole in the plastics for the alignment tab off the rear rack where it meets the rear exhaust mount. For the 11/12 it still had this attachment but no cutting required.
This tab keeps the rack mostly from moving right/left and makes it really stout in the rear..
And again, the best part, its weight.. 5lbs, 4 oz, or 5.25 lbs... I could put a Shorae battery in and my total weight would only go up 2 lbs in the rear...
Old 01-04-2013, 06:26 AM   #249
kjooseppi
Oddometer: 8
Oil cooler
Hi
Is there anybody offering oil cooler yet for 500exc? Or simply oil filter adaptor? Does anyone know if i can use CPW oil cooler intended older (450/530exc) I want increase my oil change interval, for dualsport/ rallying.
Sorry about my english and thanks
2008 KTM 950 Superenduro R
2009 KTM 200EXC
kjooseppi is offline   Reply With Quote
Old 01-04-2013, 07:58 AM   #250
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,565
Did some MX yesterday and yanked my rear rack for the first time since install last May.
With all this rack talk I wanted to show the one I run and how easy it is to remove. Much smaller and less room to carry stuff than the above Trottin one. I only run a tool bag but could put a KLR rack (milk create) or fuel cell if needed - but I respect you guys to go out overnight and need room for gear. This sexy little rack meets my day trip needs perfectly. It's small but very stout. Hovers over the rear plastic and the dirty work is attached to the sub frame.
With and without.
Once removed, the only thing left are 2 holes that look they were made by a beaver . Instructions or installer?
Only thing holding it on are 2 button hex heads - and the channel the rack slides into. All the business is attached to the sub frame out of sight under the plastic.
No rack = empty channel.
Rack http://www.promotobillet.com/catalog...n8r9ljl9ggk0t4
Bag http://dirt-bike-gear.com/lfb.html
Guns keep society safe.
Colemanfu screwed with this post 01-04-2013 at 08:30 AM
Colemanfu is online now   Reply With Quote
Old 01-04-2013, 08:49 AM   #251
Foot dragger
singletracker
Foot dragger's Avatar
Oddometer: 12,852
Huh,racks................ I put some Wolfman day tripper packs on my 530. No rack,take about 10 minutes to put on,they dont bounce around,hold plenty for a day trip and more stuff can be attached on the top of them.
I never could keep my old GL Coyote pack from coming up and smacking me on jumps. The Wolfman side packs dont seem to move no matter what I do.
Some bikes around at times
Foot dragger is offline   Reply With Quote
Old 01-07-2013, 10:12 PM   #252
Unkgd
Oddometer: 344
Is this a 500 EXC?
Cole,
Looking at the rack you have mounted on your bike - according to ProMoto - it is for an SX/SF. Like this one much better than the one ProMoto has listed for the 500 EXC.
If this rack can be mounted on a 500 EXC - looks like my pcketbook just got lighter - again!
With and without.
SNIP>>>>>
Unkgd is offline   Reply With Quote
Old 01-08-2013, 06:00 AM   #253
Colemanfu
King of all manfu
Colemanfu's Avatar
Oddometer: 3,565
Yea, not for the weak in wallet but neither is this bike . I have no idea what a sx/sf is but my origional link is for 12's and newer and much better lookin IMO. Don't know why they are not more clear in the descritpion of what it fits? You can always call to confirm.
Here is the one for older exc's http://www.promotobillet.com/catalog...roducts_id=455
Hope this helps some.
Old 02-07-2013, 09:22 PM   #254
leftystrat62
leftystrat62's Avatar
Oddometer: 999
Originally Posted by ABYSS View Post
the XCW and EXC share the same engine the only differences are - sprockets, the EXC has the emmissions stuff, and the EXC- ECU, will need to be reworked if the emissions stuff is removed. the XCW will not as it doesnt have it. , Also in 2012 the EXC had less durable rims and the XCW had the stronger series. form the info I have read though the wheel issue is going to be gone on the 2013's, EXC has all the street legal crap and the XCW does not.
If you read the threads here alot of folks that have pruchased a EXC and would haev been better served and farther ahead $ wise to get he XCW and make it street legal. If there geographc locations were permitting.
How do you find out if you state allows you to register the XCW?
leftystrat62 is offline   Reply With Quote
Old 03-22-2013, 09:06 AM   #255
Johnnyktm
Oddometer: 117
Subscribing, to learn more about my bike
Johnnyktm is offline   Reply With Quote
Times are GMT -7.   It's 05:43 AM.
