Old 12-03-2011, 09:49 PM   #1
Westbrook OP
Oddometer: 108
Quick airhead oil change q
My oil change kits (part 11 00 8 056 146) includes this stuff:
My clymers makes no mention of what I'm supposed to do with the black seal/o-ring. It's an 88 R100RS w/ oil cooler.
Thank you in advance.
Westbrook is offline   Reply With Quote
Old 12-04-2011, 12:27 AM   #2
batoutoflahonda
Oddometer: 1,386
This may help
http://www.maxbmwmotorcycles.com/fic...4&rnd=03252011
also post 67 here
http://www.advrider.com/forums/showt...=169507&page=5
It's eight and a half gallons of gas; and an engine. What more do you need?-- BMW R80G/S
Save lives. Legalize lane sharing.
Cow eyes don't glow.
batoutoflahonda is offline   Reply With Quote
Old 12-04-2011, 12:30 AM   #3
pommie john
pommie john's Avatar
Oddometer: 1,474
The black square section seal goes in a groove inside the filter cover.
It's obvious where it goes once you take the cover off.
The trouble with the world is that the stupid are cocksure and the intelligent are full of doubt.
Bertrand Russell
pommie john is offline   Reply With Quote
Old 12-04-2011, 06:35 AM   #4
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,805
If there's one inside the cover where the filter is then replace it with the new one. If there is no black seal inside then through it away. Oil filter kits for a lot of vehicles today are made to fit several different models and or years. There will often be extra parts. This applies to oil filter "kits" and other "kits" I have seen.
Charlie
Old 12-04-2011, 07:31 AM   #5
Westbrook OP
Oddometer: 108
Thanks all! Just what I needed.
Old 12-04-2011, 08:41 AM   #6
fishkens
Further...
Oddometer: 5,149
Originally Posted by batoutoflahonda View Post
Yes, do heed Joerg's advice in post #67. I had a similar movement in the oil filter tube this past summer and now use two shims.
fishkens is offline   Reply With Quote
Old 12-05-2011, 07:04 AM   #7
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 7,997
Play it safe on a new-to-you-bike. Rather than put back in what gaskets and o-rings were there, check to make sure it was done correctly in the first place. Anton Largiader's site has a good section on BMW oil filters: http://largiader.com/ .
'73 R60/5 Toaster
Old 12-05-2011, 07:44 AM   #8
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 6,072
What he said - when I brought my ST home and changed fluids, the white $3K o-ring(inflation value adjusted ) and shim were reversed and the cannister had been close to cutting the o-ring.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 12-05-2011, 08:09 AM   #9
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,805
What Bill and Mark said. This is much better than just following somebody else's tracks. I've adjusted my attitude. Thanks.
Charlie
---Albert Einstein
Old 12-05-2011, 09:42 AM   #10
lkchris
Albuquerque
lkchris's Avatar
Oddometer: 1,028
FWIW it's a quad ring.
Your (useless) Clymers also doesn't tell you that you won't use the paper gasket, and if your internal oil filter canister has a roll-over edge, you won't use the metal shim either.
Kent Christensen
Albuquerque
'12 R1200RT, '02 R1100S, '84 R80G/S
lkchris is offline   Reply With Quote
Old 12-05-2011, 10:26 AM   #11
supershaft
because I can
Oddometer: 9,116
That all depends on if the setup needs them. There is no cut and dry answer to that question. Use a paper gasket on any airhead if the O-ring is pinched too much without one and use a shim or shims on any airhead even if it is a later model that doesn't HAVE to have one that needs the O-ring pinched a bit more. That and/or minus the paper gasket. What they ALWAYS need is the right combo that gets the right squeeze on the O-ring. The O-ring needs just barley flattened.
Old 12-05-2011, 07:11 PM   #12
jackd
Oddometer: 3,050
I had my GS puke it's oil overboard on the first ride I ever took on it - within a kilometre of my home. Not a good way to introduce yourself to the BMW brand - the reason was that the PO incorrectly installed a paper gasket under the filter cap on my GS. It shouldn't have had a paper gasket installed and I never used one in every subsequent filter change. No issues since.
Old 12-06-2011, 01:20 PM   #13
supershaft
because I can
Oddometer: 9,116
My point is that it all depends on the bike's particular filter can/filter cover setup. It sounds like your white O-ring isn't pinched too much without the gasket. Some are. It all depends. The real issue had nothing to do with an improperly installed paper cover gasket. If it was installed correctly, no oil would have gone overboard. If the paper filter was installed correctly and the white O-ring was sufficiently crushed, it would work perfectly with a paper gasket. If the paper filter cover gasket was installed correctly and the white O-ring was not sufficiently crushed, the oil would have leaked inside of the engine and the only symptom would be low oil pressure. Of course, that scenario can happen with a paper filter cover gasket if the white O-ring is crushed too much and suffers a tear for it. Whether or not a bike gets a paper cover gasket all depends on what the white O-ring needs. Nothing else.
supershaft screwed with this post 12-06-2011 at 01:38 PM
Old 12-06-2011, 09:14 PM   #14
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
Remove the guesswork on whether the white o-ring is too pinched or not. Carefully measure the oil canister depth and move on from there. You will then know how many shims are needed and if the paper gasket is required.
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Times are GMT -7.   It's 12:00 PM.
