Old 12-07-2011, 10:11 AM   #31
petefromberkeley OP
Oddometer: 3,292
Thanks everyone. I feel much better.
Nine mile skid on a ten mile ride. Hot as a pistol but cool inside.
petefromberkeley is offline   Reply With Quote
Old 12-07-2011, 10:14 AM   #32
petefromberkeley OP
Oddometer: 3,292
Originally Posted by enfielddnepr View Post
In this case, would adding some 2 stroke oil to the gas(which is not gas, but benzine?) benefit?
All over the world you read bad things about alcohol in fuel,..
Yes, gasoline (benzine) not gas. That's a confusing thing we say- should probably call it petrol to avoid confusion. I agree that alcohol in fuel is a terrible idea for a number of reasons.
Old 12-08-2011, 09:48 AM   #33
Fudmucker
ex-lurker
Oddometer: 268
My wife's old VW Beetle had a similar problem years back.
Parked in the sloping driveway, the float in the carb did not shut off the fuel properly and a little would run into the manifold overnight. The fuel would find its way into the cylinder, past the rings and into the crankcase.
We only noticed this because the oil consumption stopped.
Instead of a can every second tankful, it stayed full.
One morning we had fluid lock and it wouldn't turn over.
We towed to the shop and they identified the problem.
We had been running the VW motor with two stroke mix in the crankcase instead of oil !
The oil was changed and the filter changed.
Then we ran the motor for 1000kms before changing oil again.
That motor ran beautifully for another 14 years...
Airheads are an admirable addiction...
Fudmucker is offline   Reply With Quote
Times are GMT -7.   It's 12:37 AM.
