Old 03-27-2013, 07:54 AM   #1771
Bronson1
Bronson1's Avatar
Oddometer: 75
Pivot pegz
You might want to look at my post on page 88 about PivotPegz. Since that post I have lowered and moved them back as far as possible and installed a wonderlich adjustable shifter which make it work much better.
Bronson1 is offline   Reply With Quote
Old 03-27-2013, 03:45 PM   #1772
Poznos
Idiot with a Wrench
Poznos's Avatar
Oddometer: 47
There isn't enough space on the ADV server to store all the posted pics so you have to link them from another site. I use photobucket.com. It gives you the image's URL next to the picture after you upload it. It's a little convoluted but not really a big deal.
"Good judgement comes from experience, and a lot of that comes from bad judgement." - Will Rogers
Poznos is offline   Reply With Quote
Old 03-27-2013, 04:07 PM   #1773
kdennan
kdennan's Avatar
Oddometer: 624
Here's my parts list anyway,
Progressive Suspension fork springs
2007 F650GS Dakar p/n 11-1547 $110
Touratech
300-0145 Front fork guards $81
040-0235 Low front fender (cut to accept fork guards) $126
300-5090 Quick release clear headlight guard $82
300-5255 Handlebar risers, 34mm $74
040-0338 Front brake line +3cm (must use with bar risers) $102
041-0626 Long distance footpegs, expanded rear $124
300-0125 Rear brake stop adjuster $34
#I ended up not using it. I bent the brake stop up and down a few times and broke it off. That gave the brake pedal just enough movement up to make me happy. Then I adjusted the brake and all set!#
TL-24 Tire lever with 24mm box wrench for rear axle nut $37
Parts Unlimited
Cruz Tools Roadtech B1 BMW toolkit
Twisted Throttle
Tool tube $15
SW-Motech center stand $218
A&S Cycles
8000-8100 Rear brake reservoir guard, black $45
BMW
Tall seat $260
Battery charger
Batterysplus
Scorpion AGM sealed maintenance free battery $63
Revzilla
Leo Vince LV-One EVO 2 slip-on exhaust, G650GS, stainless steel $320
Hockey puck bolted to bottom of sidestand
Heidenau K60 Scout tires
Wolfman Luggage
Explorer Lite tank bag $130
Rain cover $20
Side racks G650GS $215
Expedition dry saddle bags, black $225
Wolf bottle holster $20
Primus water bottle $22
Expedition dry duffle, small, yellow $105
Aerostitch
PIAA Extreme White Plus halogen headlight bulb H4 (55W/60W) $49
BMW style plug extension $10
I got a bunch of other camping related stuff. I had tons already as I have been backpacking all my life. But I did get a few special items to complete the list.
If you want, I'll post them
"F#%* you I won't do what you tell me!"
Rage Against The Machine
kdennan is offline   Reply With Quote
Old 03-27-2013, 06:06 PM   #1774
kdennan
kdennan's Avatar
Oddometer: 624
http://kdennan.smugmug.com/Motorcycl...636327_v8NZbp/
I give up. Try that. I wanted to put the pics here and label descriptions
Old 03-27-2013, 06:30 PM   #1775
alskee750
alskee750's Avatar
Oddometer: 518
Kdennan pics..
just helping out..
Just a few to help you out.. It's not hard, just right click on the photo and copy the image url. Once you have that when typing your message on the top you'll see a "insert image" icon. click that and paste your image url... waaahhh laahhhh...
12' BMW Sertao For everything
01' Triumph Bonneville Holligan Bike
94' Suzuki DR250 strickly woods
74' Kawasaki G3SS possible vintage race bike.
Soto Moto Adventures
alskee750 is offline   Reply With Quote
Old 03-27-2013, 06:49 PM   #1776
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 305
Looking good! KDennan, w/a heat shield you can shorten up those racks (bring them in)if you want. I'm running mine w/1 each of water and fuel rotopax (when needed) and also, if you can find them , there are pelican style cases that fill the entire size of the bag for hard/carry storage if needed. Congrats!
nomad5326 is offline   Reply With Quote
Old 03-27-2013, 07:11 PM   #1777
nomad5326
Xventurous
nomad5326's Avatar
Oddometer: 305
Originally Posted by kdennan View Post
is it me or do any of you see x's instead of pictures?
Nada. Nuke it! Nothing there.
Old 03-27-2013, 08:48 PM   #1778
nylon2000
Wanderer
nylon2000's Avatar
Oddometer: 253
Did some work on the bike today:
- installed the new Scorpion battery and redid the wiring to give me more space. Starts up in 0.5 seconds now. Glad to be rid of the OEM one, finally!
- Refit the beak.
- pulled the passenger pegs off, that saves 0.5kg!
- Played around with the Enduro Star Trail Stand. It works, but it wasn't SUPER stable. I need to play with it some more.
- Installed Wolfman luggage racks, and the Rocky Mountain soft bags. These bags were only released by Wolfman last month, so no reviews online. Basically, they are bigger than the Expedition Dry ones. These are most similar to the Adv Spec Magadans. More abrasion resistance, and more capacity than the expedition ones, plus an inner dry bag, so its easier to unpack at night.
- Still need to put the offroad tires on, the wider pegs, and a few other things.
Pics for proof!
Note the panniers are pretty wide, but they can be cinched down so the bike won't be wider than the bars.
And for Swamp, sorry this took me so long. I'd been away for work. Here are the pictures of the iphone mount, with drilled hole. Its pretty rudimentary, but works for me:
WineAndWater. West around the world, New York to London, then Africa. Raising money for Wine to Water, supporting clean water projects in 15 countries.
The expedition
About the bike
nylon2000 is offline   Reply With Quote
Old 03-27-2013, 09:10 PM   #1779
alskee750
alskee750's Avatar
Oddometer: 518
kdennan
Question, when installing your progressive forks did you change your fork oil to a heavier one? Did you remove your oil from the forks at all? Or was it easy enough to just remove the springs and replace w/ pvc spacers. Just curious.
Thanks.
Old 03-27-2013, 09:26 PM   #1780
nylon2000
Wanderer
nylon2000's Avatar
Oddometer: 253
Oh, and has anyone found a better tail light assembly? mine flexes all the time (and flexed off today!). Its about as strong as the beak.
Let me know if there's an aftermarket one thats just better?
The expedition
About the bike
Old 03-28-2013, 02:48 AM   #1781
ausbaxter
ausbaxter's Avatar
Oddometer: 158
Just installed my gps mount and case along with a Auxiliary 12v socket in the gloved compartment
ausbaxter is offline   Reply With Quote
Old 03-28-2013, 03:15 AM   #1782
kdennan
kdennan's Avatar
Oddometer: 624
Originally Posted by alskee750 View Post
kdennan
Thanks.
Simple stuff. Just swapped the springs
Old 03-28-2013, 04:00 AM   #1783
Murphy Slaw
Murphy Slaw's Avatar
Oddometer: 1,640
Originally Posted by Gundy View Post
Is there a VIN number, production date etc after which BMW has already fixed the hot start decomp lever issue?
I didn't see a response?
Also, do the Huskys NOT have this issue?
The Murph Channel
Acoustic Originals and some Double Aught
http://www.youtube.com/channel/UCkomGsMJXH9qn-xLKCv4WOg
Murphy Slaw is offline   Reply With Quote
Old 03-28-2013, 04:59 AM   #1784
kdennan
kdennan's Avatar
Oddometer: 624
We should try and plan a Sertao ride
Old 03-28-2013, 06:50 AM   #1785
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,851
now we are getting somewhere.
I second that motion in the ocean.
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp is offline   Reply With Quote
Times are GMT -7.   It's 06:38 AM.
