Old 05-08-2013, 12:18 AM   #2281
kdennan
kdennan's Avatar
Oddometer: 624
Originally Posted by swamp View Post
yes, you have to reset the computer thingy
How do?
"F#%* you I won't do what you tell me!"
Rage Against The Machine
kdennan is offline   Reply With Quote
Old 05-08-2013, 01:32 AM   #2282
ferals5
800+652
ferals5's Avatar
Oddometer: 1,149
Originally Posted by kdennan View Post
How do?
undo the big red plastic plug from the box under the seat go have a beer.... come back and hook it back up...good to go
edit; hmmm... mine is red dunno what yours looks like...think they changed
ferals5 screwed with this post 05-08-2013 at 01:40 AM
ferals5 is online now   Reply With Quote
Old 05-08-2013, 04:38 AM   #2283
kdennan
kdennan's Avatar
Oddometer: 624
I don't see any red plug
Old 05-08-2013, 05:45 AM   #2284
windowto
Oddometer: 838
because the YZ forks raise it in the front. have to even it out in the rear with the 18. also 18 is better off road . the bike is taller than stock now, more ground clearance.
the problem i've found is that i need to be careful with tire sizes and chain length... you may have noticed the consequences of getting it wrong.
OK, now it makes sense. Consequences? Yea, so does it rub on the swing arm? Did you have to lengthen the stands as well? Does it lean even more on the side stand?
windowto is offline   Reply With Quote
Old 05-08-2013, 07:07 AM   #2285
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,812
just need a longer chain.
side stand is fine
center stand is fine.
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp is offline   Reply With Quote
Old 05-08-2013, 07:33 AM   #2286
kdennan
kdennan's Avatar
Oddometer: 624
No reply?
the only connection/plug below the box in the center of my picture is on the right below the fuse box (it's black). I unplugged it and will now have a spot of tea..... and see
Old 05-08-2013, 07:55 AM   #2287
windowto
Oddometer: 838
side stand is fine
I was going through the gears on center stand after changing the shifter. The Speedo is definitely of the rear wheel. If you took off the ABS sensor, or some wiring to/from it, that could have caused your "no Speedo" situation. But you probably already knew it .
Old 05-08-2013, 08:29 AM   #2288
alskee750
alskee750's Avatar
Oddometer: 518
can someone tell me whats the size of the screw that is threaded into the grips holding it in place? I need to tap a new set up bars because the last one are bent really beyond repair. Thanks I would check mysef but I'm at work
12' BMW Sertao For everything
01' Triumph Bonneville Holligan Bike
94' Suzuki DR250 strickly woods
74' Kawasaki G3SS possible vintage race bike.
Soto Moto Adventures
alskee750 is offline   Reply With Quote
Old 05-08-2013, 12:00 PM   #2289
windowto
Oddometer: 838
Alskee,
Unfortunately I can't help you with the screw size, but wanted to chime in anyway. Did you possibly consider the 2007 Dakar bars? I am looking at the fiche and most components that go on the bars have same part numbers (including the bark busters). The price is the same, the bars are black and have a cross brace. Don't really know if they are any stronger, but have a feeling that anything is stronger than that piece of pipe that we have. I am considering this as a future possibility.
windowto screwed with this post 05-08-2013 at 01:11 PM
Old 05-08-2013, 01:40 PM   #2290
ferals5
800+652
ferals5's Avatar
Oddometer: 1,149
No reply?
Sorry...went to bed early
um yes I did edit that I thought the later control units changed. So how was the cuppa char ?
Old 05-08-2013, 02:23 PM   #2291
alskee750
alskee750's Avatar
Oddometer: 518
Alskee,
Win,
I went for a much stronger MX bar via protaper. I'll let you how it goes with the install. The Handlebar bends on the new one are pretty much the same, not exact but close enough. Also they only cost me less than half the price of the stock BMW ones . Thanks..
Old 05-08-2013, 02:26 PM   #2292
windowto
Oddometer: 838
Win,
Yes, please keep us posted. Will be curious to see how it goes.
Thank you
Old 05-08-2013, 03:06 PM   #2293
kdennan
kdennan's Avatar
Oddometer: 624
Is it that black plug/connection the right one? I left it unplugged for the ole tea bag and then, like a dumb ass, I went out on the bicycle for 3hrs.
The only thing I found on the webster was that the connection I unplugged is called the tail section something or other? It's to the right of the box and below the fuse box
Old 05-08-2013, 03:25 PM   #2294
kdennan
kdennan's Avatar
Oddometer: 624
Is this it?
Old 05-08-2013, 03:32 PM   #2295
windowto
Oddometer: 838
Is this it?
This plug is for the tail section harness (running light, brake light, turn signals)...
Times are GMT -7.   It's 11:17 PM.
