Old 07-09-2013, 08:09 AM   #2971
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,899
BalletBiker,
What is wrong with nylons motor?
Does the bike run ?
Is there anything that we can do to help ?
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp screwed with this post 07-09-2013 at 08:52 AM
swamp is offline   Reply With Quote
Old 07-09-2013, 03:29 PM   #2972
kdennan
kdennan's Avatar
Oddometer: 630
Is there any update on Nylon?
"F#%* you I won't do what you tell me!"
Rage Against The Machine
kdennan is offline   Reply With Quote
Old 07-09-2013, 03:47 PM   #2973
windowto
Oddometer: 903
He is probably drinking with beautiful Mongolian chicks, since he knows he will be stuck there for a while .
No, seriously.... Nylon! Where are you? We are worried... Nylon...
windowto is offline   Reply With Quote
Old 07-09-2013, 06:35 PM   #2974
giganova
giganova's Avatar
Oddometer: 276
I am still getting to know my 2013 Sertao (700 miles) and I noticed two strange things after I picked it up from the 600 miles "break-in" service:
  1. Is the chain supposed to rest on the swing bar like in the image below?
  2. What is that cooling element that is squeezed between the bash plate and the engine block? It is only secured by one zip tie and looks like an afterthought.
giganova is offline   Reply With Quote
Old 07-09-2013, 06:58 PM   #2975
Aquatic
Aquatic's Avatar
Oddometer: 1,701
  1. Is the chain supposed to rest on the swing bar like in the image below? Yes.
  2. What is that cooling element that is squeezed between the bash plate and the engine block? It is only secured by one zip tie and looks like an afterthought. Voltage regulator - Been like that since 2003(I think) and don't worry, it is held with more than a cable tie
Aquatic is offline   Reply With Quote
Old 07-09-2013, 07:01 PM   #2976
giganova
giganova's Avatar
Oddometer: 276
Thanks, Aquatic -- I will be able to sleep tonight
Old 07-09-2013, 07:03 PM   #2977
swamp
swamp's Avatar
Oddometer: 1,899
wait until he changes the oil
Enduro Earth
YOUTUBE
Old 07-09-2013, 07:06 PM   #2978
swamp
swamp's Avatar
Oddometer: 1,899
Originally Posted by windowto View Post
Swamp,
I think you keep forgetting that many people still have their ABS;). With the ABS in place, fork extension has no effect on brake line tension at the bars. This is a separate line that goes from the steering head to the bars. But you already knew that .
Enduro Earth
YOUTUBE
Old 07-09-2013, 08:00 PM   #2979
Motopsychoman
Not a total poseur
Motopsychoman's Avatar
Oddometer: 882
Eek
Well, let Nylon know that DHL services Mongolia: Ulaanbaatar City, Erdenet and Darkhan. He can have parts shipped worldwide in a few days if need be.
Of course he may have to push the bike a few hundred miles to one of those cities first.
But honestly, give us the bike's symptoms and maybe we can all think of something to get him rolling again.
"It's a topsy-turvy world, and maybe the problems of two people don't amount to a hill of beans. But this is our hill. And these are our beans!" - Frank Drebin
Current Rides: '13 Sertao, '98 Bandit 1200, Currently a 1200 piece puzzle: '86 R80G/S PD
Past: '66 Suzuki T10, '72 CL350, '74 GT550, '80 GS750, '7? XT500, '83 RM250, '85 XT500
Motopsychoman is offline   Reply With Quote
Old 07-09-2013, 08:54 PM   #2980
WayneC1
Oddometer: 2,732
Giganova, the Voltage Regulator overheats in hot temps mounted under the engine like that, we move them to the side of the engine as per the 650X models
650GS Info - www.f650gs.crossroadz.com.au
WayneC1 is offline   Reply With Quote
Old 07-09-2013, 09:19 PM   #2981
giganova
giganova's Avatar
Oddometer: 276
Wayne -- That's interesting: my battery overheated two weeks ago when I was stuck in a traffic jam for more than an hour at 95 degrees. Acid spilled out of the battery and fried the accessory outlet; the next day the bike wouldn't start anymore. Got it towed to the BMW dealer who said that the battery had boiled over. From reading your mods site, could that have been caused by the voltage regulator overheating?
Old 07-09-2013, 09:33 PM   #2982
WayneC1
Oddometer: 2,732
Yes, the VR can "drop out" it protects itself basically, this allows the output voltage to go up to 16v and can over charge a battery.
I have not heard of a battery overheating to the point of spewing acid though, the acid spill is more likely poor pre-delvery work
Many owners report having the battery inner cells fluid levels lower than the outer when they check the battery and this can indicate those cells getting hotter than the outer ones. I certainly found that on my 02 model. The battery also needs more regular checking and topping up than other makes/models which indicates a problem.
Since it is a new machine and under warranty I would get the 650X VR mount and put the VR on the side of the engine
The mount is a little expensive but BMW could not complain since it is their own part
Old 07-09-2013, 09:40 PM   #2983
BalletBiker
Oddometer: 13
He found a yurt!!! And is now asking about a fiche no so he can order new clutch plates (or something appropriate) to repair his G650GS Sertao. Can anybody help point me in the right direction to find this? I will need to order it and send it to Oasis Hotel in Ulaanbaatar.
BalletBiker is offline   Reply With Quote
Old 07-09-2013, 09:40 PM   #2984
giganova
giganova's Avatar
Oddometer: 276
That's what my BMW dealer suspected; they replaced the battery and put in a new accessory outlet on warranty.
Can sealed non-acid batteries handle voltage jumps better? I'm thinking about getting a MotoBatt AMG battery.
Old 07-09-2013, 09:43 PM   #2985
BalletBiker
Oddometer: 13
Perfect, thanks for the tip! Now trying to find the fiche no of his bike to order new clutch plates and send to Ulaanbaatar. I'm a newbie to biking so trying to figure out where to order this...
Times are GMT -7.   It's 10:26 AM.
