Old 07-12-2013, 09:51 PM   #3046
bcinkc
bcinkc's Avatar
Oddometer: 62
Very true, but if there are worn friction plates, the pressure would be lower than spec. Weak spring pressure will cause the clutch to slip even more. Adding a single washer onto each of those springs may provide a stop-loss to the damage that is being done by insufficient force. The force may be greater at the lever, or may be approximately the same as before, depending on the damage already done. In the normal run of things one would just replace the clutch pack altogether and ride on. However, waiting in Mongolia for three weeks while the parts are still being whittled somewhere thousands of miles away isn't really the normal run of things.
bcinkc is offline   Reply With Quote
Old 07-12-2013, 09:52 PM   #3047
Trane Francks
Trane Francks's Avatar
Oddometer: 645
Originally Posted by Motopsychoman View Post
Adding washers is one way to compensate for overall plate wear but unfortunately friction plates rarely wear out evenly. Usually one or two get very thin while the others are almost new.
If doing a sandpaper-to-roughen surfaces, last-ditch effort to get moving again, it might be helpful to reassemble the clutch 'reversing' the plates in order of wear, i.e., replacing the least worn bits with the most worn and vice versa. Generally speaking, though, once you've glazed your plates, you're pretty much due for replacement over the long haul.
Trane Francks is offline   Reply With Quote
Old 07-12-2013, 10:30 PM   #3048
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,803
Originally Posted by bcinkc View Post
... force may be greater at the lever, or may be approximately the same as before, depending on the damage already done. .
"mmm.. yes. approximate is the force with you. always in motion is the future"
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp is offline   Reply With Quote
Old 07-12-2013, 10:30 PM   #3049
bcinkc
bcinkc's Avatar
Oddometer: 62
nice
Old 07-12-2013, 10:49 PM   #3050
Motopsychoman
Not a total poseur
Motopsychoman's Avatar
Oddometer: 729
Eek
Missed something. You would not add washers like #19, but you would add very skinny washers with OD and ID about the same as the springs. Add them at the bottom of each spring. Adding another washer the size of #19 under the bolt does nothing.
"It's a topsy-turvy world, and maybe the problems of two people don't amount to a hill of beans. But this is our hill. And these are our beans!" - Frank Drebin
Current Rides: '13 Sertao, '98 Bandit 1200, Currently a 1200 piece puzzle: '86 R80G/S PD
Past: '66 Suzuki T10, '72 CL350, '74 GT550, '80 GS750, '7? XT500, '83 RM250, '85 XT500
Motopsychoman is offline   Reply With Quote
Old 07-13-2013, 06:40 AM   #3051
dazz
dazz's Avatar
Oddometer: 173
Correct. Adding washers does NOTHING. Parts 2 and 17 are bolted tightly together with a bolt and one washer. Another washer does not help. You either need to increase the thickness of that pile of plates and friction plates or decrease the height of the clutch basket. (not an easy option.)
In the future, makes sure you always have play at your clutch handle. Make sure your clutch cable is not too tight. If it's too tight it is like slipping your clutch at all times. That's about the only way to burn up a clutch on one of these bikes.
As Moto says,"but you could add very skinny washers with OD and ID of the clutch springs thereby increasing spring tension." That OD and ID is the important thing with this method. Good luck.
Triumph Bonneville T100
1971 R50/5, BMW G650GS
DRZ400S, KTM 250 XC-W
XR200, 1947 James ML
dazz is offline   Reply With Quote
Old 07-13-2013, 06:59 AM   #3052
SwollenCranium
SwollenCranium's Avatar
Oddometer: 104
It might be a sign of my unwillingness to do BDAR unless absolutely life dependent but I'm thinking why try and Jerry rig it if you are in a comfortable place, and are not in danger?
Looks like all the options above, except replace with new, will leave him stranded again at some point and the next "some point" might be in a place less suited for not getting dead.
I'm not totally risk adverse but ...
SwollenCranium is offline   Reply With Quote
Old 07-13-2013, 08:50 AM   #3053
nylon2000
Wanderer
nylon2000's Avatar
Oddometer: 253
Petrol/gasoline and sandpaper seem to be cleaning them up nicely, will put it all together tomorrow and see if it rides. And, yes, i'll order new plates, but with a 2-4 week delivery estimate, i'm going to try to get them shipped further along.
Thanks for your help so far!
WineAndWater. West around the world, New York to London, then Africa. Raising money for Wine to Water, supporting clean water projects in 15 countries.
The expedition
About the bike
nylon2000 is offline   Reply With Quote
Old 07-13-2013, 08:53 AM   #3054
nylon2000
Wanderer
nylon2000's Avatar
Oddometer: 253
PS. So unimpressed with BMW dealership service in this - i tried germany, usa, and the uk.
That said, the support from ADV, HUBB, and the bikers here has been awesome.
The expedition
About the bike
Old 07-13-2013, 09:51 AM   #3055
kdennan
kdennan's Avatar
Oddometer: 624
You would think that BMW would be the obvious choice to go with for a bike based on world wide dealer support.
"F#%* you I won't do what you tell me!"
Rage Against The Machine
kdennan is offline   Reply With Quote
Old 07-13-2013, 10:05 AM   #3056
WayneC1
Oddometer: 2,477
One thing to remember with G Series engine part numbers is that there is likely to be a difference in royalties payable to Rotax between F Series and G Series and hence the need for a different part number
The clutch plates could well be the same parts as the F Series but that is masked in the parts system by the different numbers. A quick measurement and a pic could provide answers and posting over at f650 is bound to get some one with old plates able to measure them up. There may even be people over there with plates on the shelf, you would need the dual spark steel plates, fibre plates are the same single and dual spark
650GS Info - www.f650gs.crossroadz.com.au
WayneC1 is offline   Reply With Quote
Old 07-13-2013, 10:06 AM   #3057
petepuma
petepuma's Avatar
Oddometer: 392
Three words....K....L....R
sent via mental telepathy
petepuma is offline   Reply With Quote
Old 07-13-2013, 10:19 AM   #3058
kdennan
kdennan's Avatar
Oddometer: 624
Sorry, new subject for a moment,
Checking out lighting options from Twisted Throttle.
One kit, the Denali D1 for example, draws 10watts per lamp (2). Is that safe for our stock capacity, taking into allowance for the heated grips and my heated jacket?
And a GPS?
I'm a total noob savant with electrical
Old 07-13-2013, 02:14 PM   #3059
Motopsychoman
Not a total poseur
Oddometer: 729
Eek
And a GPS?
20W total is no problem. 200W would be a big problem. Anyone taken an ammeter and measured the current running with lights and grips on low? should try that but not at the present time.
Old 07-13-2013, 02:36 PM   #3060
kdennan
kdennan's Avatar
Oddometer: 624
Great, Thanks
I kinda thought so but I'm nervous about electric's.
Times are GMT -7.   It's 02:11 AM.
