Old 07-13-2013, 06:53 PM   #3061
Motopsychoman
Not a total poseur
Motopsychoman's Avatar
Oddometer: 724
Eek
Originally Posted by kdennan View Post
Great, Thanks
I kinda thought so but I'm nervous about electric's.
When I get a chance, I plan on breaking down all of the electric loads so we all know how much we can use (unless anyone else want to beat me to it).
The 2013 spec says it has a 400W alternator. You should always keep 10% in reserve for charging the battery. That leaves 360W. So, if you can measure how much the engine and headlight use, and then the heated grips, the rest is available for accessories.
"It's a topsy-turvy world, and maybe the problems of two people don't amount to a hill of beans. But this is our hill. And these are our beans!" - Frank Drebin
Current Rides: '13 Sertao, '98 Bandit 1200, Currently a 1200 piece puzzle: '86 R80G/S PD
Past: '66 Suzuki T10, '72 CL350, '74 GT550, '80 GS750, '7? XT500, '83 RM250, '85 XT500
Motopsychoman is offline   Reply With Quote
Old 07-13-2013, 09:30 PM   #3062
WayneC1
Oddometer: 2,475
The alternator and many other parts are all the same as the older models and the power consumption figures etc are all documented either in the Dakar thread or over at F650.com. Dwayne wrote a little on it recently http://www.advrider.com/forums/showp...ostcount=11093
Heated Grips for instance
Power Consumption @13.8v - 42 watts
Half Power Current @13.8v - 2 amps
Full Power Current @13.8v - 3 amps
One thing to remember is that BMW rate the alternator at 7500 RPM, 29 amps, 14v so at lower RPM there is a little less power
650GS Info - www.f650gs.crossroadz.com.au
WayneC1 is offline   Reply With Quote
Old 07-13-2013, 09:37 PM   #3063
nylon2000
Wanderer
nylon2000's Avatar
Oddometer: 253
Clutch assembly
Can someone send me the pages that explain how to reassemble the clutch? There are a few spacers that I'm not sure what order to put them back in... :(
WineAndWater. West around the world, New York to London, then Africa. Raising money for Wine to Water, supporting clean water projects in 15 countries.
The expedition
About the bike
nylon2000 is offline   Reply With Quote
Old 07-13-2013, 11:19 PM   #3064
nylon2000
Wanderer
nylon2000's Avatar
Oddometer: 253
and...give me the measurements for the plates - i will measure the full stack once cleaned, and hope they aren't too far apart from the recommended size!
thanks
The expedition
About the bike
Old 07-14-2013, 12:09 AM   #3065
nylon2000
Wanderer
nylon2000's Avatar
Oddometer: 253
Not sure how i posted 3 times in a row, but this is what im looking for:
These are the specs for the F650, i want the equivalent for the Sertao. At least these measurements, but ideally all the info about the clutch! :)
thanks all
The expedition
About the bike
Old 07-14-2013, 01:47 AM   #3066
WayneC1
Oddometer: 2,475
That list above is for the single spark with 8 plates, yours should have 7 of each, Part list for the F's and clutch info is here
http://www.f650gs.crossroadz.com.au/ClutchRepair.html
Old 07-14-2013, 01:54 AM   #3067
nylon2000
Wanderer
nylon2000's Avatar
Oddometer: 253
Good page, but that doesnt give me the sizes for the Sertao...
The expedition
About the bike
Old 07-14-2013, 02:01 AM   #3068
WayneC1
Oddometer: 2,475
The sizes will be the same as the F dual spark, it was only the No of plates they changed to stop clutch slip which the single spark suffered from
Old 07-14-2013, 02:28 AM   #3069
nylon2000
Wanderer
nylon2000's Avatar
Oddometer: 253
I have: 7 friction plates, and 6 drive plates. Using that site, and the sizes for the F650GS 04-05 (inner Plates 6 x 2.13 mm and Friction Plates 7 x 3.50 mm - Total height 37.28 mm).
My plates are 35.5mm, +/- a little, as my calipers suck.
2mm is way outside tolerance, so i'll be stacking washers to squash the plates together.
Can someone confirm that the Sertao plates are the same, and should be 37.28mm?
The expedition
About the bike
Old 07-14-2013, 04:04 AM   #3070
WayneC1
Oddometer: 2,475
I did a check and the Sertao parts are the same as the G Series 2008 through to 2010 all the same through the series
I would be extremely surprised if there was any physical differences between the F Dual spark and the G Series plates
Think if you check you will find you have 7 steel "drive plates" which brings the stack size up a bit
The numbers you quoted "F650GS 04-05 (inner Plates 6 x 2.13 mm and Friction Plates 7 x 3.50 mm - Total height 37.28 mm)."
Are not as per the source, F650GS 04-05 - Inner Plates 7 x 2.13 mm and Friction Plates 7 x 3.50 mm - Total height 39.38 mm
The wear limit on total stack is 1 mm
EDIT - What they have done is replace the 7th steel plate with 2 x "Judder Rings", measure the stack with those rings included
WayneC1 screwed with this post 07-14-2013 at 04:18 AM
Old 07-14-2013, 06:22 AM   #3071
windowto
Oddometer: 834
Images sent. Sorry, I don't have the plate thickness dimensions. Anyone care to chime in?
Good luck! We are all routing for you!
windowto is offline   Reply With Quote
Old 07-14-2013, 06:48 AM   #3072
WayneC1
Oddometer: 2,475
The plate thickess's should be in the RepRom but I would almost put money on them being the same as the dual spark.
It was only the steel plates which changed in thickness between the single spark and dual spark
Old 07-14-2013, 08:12 AM   #3073
jonmbakermd
Oddometer: 37
The front fender breaks off
Originally Posted by Trane Francks View Post
Earlier Sertaos had a tendency to break off the beak over the bumpy stuff, so adding weight up there could raise eyebrows. Hope it all works out for you!
Just got back from doing the Utah Backcountry discovery route and I can tell you the front fender will break off without ever crashing this bike. Good news is A&S BMW will replace it for free. Now once the Warranty is up next year I will be on my own. My bike has 17,000 miles on it.
http://www.youtube.com/watch?v=QMn_JWVkVYI
jonmbakermd is offline   Reply With Quote
Old 07-14-2013, 09:50 AM   #3074
windowto
Oddometer: 834
Make sure the plates are oiled before assembly!
Attention
Clutch plates can burn if installed dry.
Immerse the new clutch-plate stack in clean engine oil before installing.
Immerse lined plates (1) in engine oil....
BMW maintenance manual
windowto screwed with this post 07-14-2013 at 11:31 AM
Old 07-14-2013, 02:59 PM   #3075
muratokay
Oddometer: 4
Eh? Waiting for my new Sertao
Hello all,
I'm new in the forum, but I had been reading all the posts in this title because I will be a proud G650GS Sertao owner, I am waiting for the delivery of my brand new Sertao sometime in September.
And I should say it gave me quite a lot of useful information reading the posts here. Thank you all.
I want to ask a question about the periodic maintenance service of this bike. Here in Turkey, the BMW motorcycle service stations are only located in some big cities. The nearest service is some 1000 km from the town I live. So it seems that I will be doing most of the maintenance on my own.
What I heard from some people here is that, for the new BMW bikes, if you do not take your bike to the BMW service for periodic checks, the bike's computer will lock the engine and you will not be able to start the engine until it's taken to a BMW service. They heard of BMW owners transporting their bikes to BMW service behind a pick up. Actually they were talking about the F800GS owners.
Is it right? And is it right for G650GS's? I never had read anything like this in this forum but after I heard the guys talking about it, I wanted to ask this and make it clear that there is not such a thing. Actually a bike that is built to be ridden all around the earth should not lock itself just because we didn't take it to a BMW service I guess.
And I want to make it clear because 1000 + 1000 = 2000 km's is a long way for a maintenance work.
muratokay is offline   Reply With Quote
Times are GMT -7.   It's 06:12 AM.
