Old 07-15-2013, 07:13 PM   #3091
Trane Francks
Trane Francks's Avatar
Oddometer: 645
Originally Posted by ausbaxter View Post
That is such a cool pic!
Trane Francks is offline   Reply With Quote
Old 07-15-2013, 07:41 PM   #3092
Aquatic
Aquatic's Avatar
Oddometer: 1,590
I dig it!
Aquatic is offline   Reply With Quote
Old 07-15-2013, 08:43 PM   #3093
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,803
Thanks! We needed some pics .
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp is offline   Reply With Quote
Old 07-16-2013, 02:09 AM   #3094
nylon2000
Wanderer
nylon2000's Avatar
Oddometer: 253
Oil question for you - the oil filter? Thats on the other side of the bike, and to get to it, i need to remove both the sprocket cover and the little weird canister?
Can i just change the filter every 6k miles? Even if im changing oil more frequently?
And, i think its time for me to buy the repair manual (http://www.amazon.com/BMW-Motorcycle...=sertao+manual). Can anyone confirm it works on a mac? It says windows XP only online...
WineAndWater. West around the world, New York to London, then Africa. Raising money for Wine to Water, supporting clean water projects in 15 countries.
The expedition
About the bike
nylon2000 is offline   Reply With Quote
Old 07-16-2013, 02:28 AM   #3095
WayneC1
Oddometer: 2,477
The single spark manual was pdf, the dual spark windows only and have not looked at the G Series but would expect it to be as per the dual spark. You can run a windows XP virtual machine on the MAC to access the manual
Oil filter yes, remove the RHS sprocket cover and remove the round cover to the front/top of the cover area, for RTW the stainless steel filters are a better bet as they are washable and reusable
650GS Info - www.f650gs.crossroadz.com.au
WayneC1 is offline   Reply With Quote
Old 07-16-2013, 02:24 PM   #3096
ZBone
ZBone's Avatar
Oddometer: 339
Ok, so I installed the TT lockable GPS mount and the AMPS rugged mount for a Montana. Now my issue is that the AMPS mount has a regular positive/negative to hook on to the battery/splice in to a wire. I don't want to hook straight up to the battery because then I have to remove the GPS every time I leave the bike defeating the purpose of having a locking mount in the first place. I'd rather not splice in to a wire since there is a socket on the bike that I'm pretty sure is switched power (someone please correct me if I'm mistaken ). I have a car charger for a set of rechargeable batteries that I will never use. Is there any reason I couldn't just splice the end of the car charger onto the cables from the AMPS mount and call it a day? I'm a noob when it comes to anything electricity, so if I'm being a total idiot please don't hesitate to say so.
Also, here's a shot from a local get together a few weeks ago.
The guy right after me sunk his DR650 in there and we had to drain about a gallon of water from his air box.
ZBone is offline   Reply With Quote
Old 07-16-2013, 05:15 PM   #3097
Trane Francks
Oddometer: 645
You should share this in the water crossings photo thread. The guys there would love this.
Old 07-17-2013, 07:36 AM   #3098
swamp
swamp's Avatar
Oddometer: 1,803
Thanks for posting a picture Zbone!
I just use AA batteries in my GPS
when they run out i throw them on the ground then put more in.
hasn't failed me yet.
i use ultimate lithium batteries . i get up to 3 days out of 2AAs... so..ya.
i dont see the point in hardwiring a gps unit to the bike. .. i mean, you dont wire your point and shoot camera to your bike do ya?
Enduro Earth
YOUTUBE
Old 07-17-2013, 10:16 AM   #3099
ZBone
ZBone's Avatar
Oddometer: 339
Well... as it happens I'd like to have a way to charge my camera/GoPro/phone on longer camping trips so... yes?
I thought about going the battery route too. I'll definitely have a set in my tank bag just in case.
Old 07-17-2013, 10:36 AM   #3100
Kim_uk
Oddometer: 39
Mine is hard wired at the moment but I am about to fit one of these so that it is activated by the ignition. The build in rechargeable battery will keep it running while the bike is off. http://www.fuzeblocks.com/
2 new battery every 3 days is such a waist and a cost!!!
Kim_uk is offline   Reply With Quote
Old 07-17-2013, 12:58 PM   #3101
giganova
giganova's Avatar
Oddometer: 214
there is a socket on the bike that I'm pretty sure is switched power ...
The powerlet socket is always powered on, even in Ignition OFF.
giganova is offline   Reply With Quote
Old 07-17-2013, 01:02 PM   #3102
giganova
giganova's Avatar
Oddometer: 214
I am using a Centech AP-1 fuse box, which costs much less than the FuzeBox and does the same job.
Old 07-17-2013, 01:19 PM   #3103
ZBone
ZBone's Avatar
Oddometer: 339
Well. that's a bummer. I really don't want to mess with a fuse box just to run a GPS. That seems like extra money/work/clutter for something that I will hardly utilize.
Old 07-17-2013, 01:26 PM   #3104
modeselector
Common as muck
modeselector's Avatar
Oddometer: 624
You can always splice off the horn and add a cig outlet to the dash.
modeselector is offline   Reply With Quote
Old 07-17-2013, 05:06 PM   #3105
dr.cornelius
dr.cornelius's Avatar
Oddometer: 41
I have a montana hard wired to the battery, you can turn the gps off so that it is only charging the battery, which is what I do when stopped for an hour or two. If I am stopping to camp or longer stops, I simply un-dock the gps. I considered wiring up a disconnect, but I try and avoid to many extra electrical connections/splices as this adds another point of possible failure.That said I have left the gps in the cradle over night (in the off mode) and the bike fired right up the next morning. It was also 35 deg F that morning. BTW still running the stock BMW/Yusa POS battery
dr.cornelius is offline   Reply With Quote
Times are GMT -7.   It's 11:06 PM.
