Old 02-19-2013, 07:03 AM   #1426
fiep
fiep's Avatar
Oddometer: 1,938
Originally Posted by fiep View Post
parot mode:
adjustable front brake lever anyone?
mine is in the shop,
noise from the forks
enough noise for the BMW service rep to ride and listen
Originally Posted by VitSports6 View Post
What kind of noise, Clunk, scratching, WooHooing?
Did you notice any functionality issues as well?
Best of luck!
klunks,
klunks bad enough to sound like the front is just about to fall out
if you run over some very moderate potholes
not sure about the funktion, did not even try to put in any real riding
the sound is too gut wrenching
so far no feedback from the dealer
fiep is offline   Reply With Quote
Old 02-19-2013, 05:46 PM   #1427
grizzlyj
Oddometer: 38
Originally Posted by kdennan View Post
Talked with Touratech and they said that you have to buy the Adjustable Windshield Bracket, P/N 300-5330 for $98
Then you adjust the windshield up and out and you can easily remove the GPS. With the unit back in the dock you can then move the windshield back down into the stock position and, wallah!
I'm in!
So far I'm very impressed with TT. Every question I've asked has been answered right away and they have been truly helpful. And their stuff is really cool looking too:)
I'm not sure you're right about being really impressed, since to solve the problem they want you to spend even more with them, and to quote their description of the GPS bracket "The mounting plate attaches neatly to the existing mounting points behind the windscreen on the BMW G 650 GS" The instruction pdf says you can combine with the screen adjuster, not you have to? Maybe a few washers to space the screen out would work too?
http://shop.touratech.co.uk/gps-moun...n-systems.html
grizzlyj is offline   Reply With Quote
Old 02-20-2013, 03:48 AM   #1428
kdennan
kdennan's Avatar
Oddometer: 621
I talked with them again yesterday and he said I do not have to use the adjustable windshield mount. I can simply twist the gps in it's dock down enough to open it. That works for me
kdennan is offline   Reply With Quote
Old 02-20-2013, 10:59 AM   #1429
ZBone
ZBone's Avatar
Oddometer: 339
I received my TT adjustable windscreen bracket today and I can't figure out how to get the stock windscreen off. Whenever I turn the 4 bolts holding the windscreen on they just spin and spin like the nut on the other end isn't attached to anything. Anyone have any experience with this?
ZBone is offline   Reply With Quote
Old 02-20-2013, 11:10 AM   #1430
Bronson1
Bronson1's Avatar
Oddometer: 63
Nuts twisting
ZBone I had the same problem. I had to take the black bracket cover off behind the screen (in front of you as you are sitting on the bike) and then use a pair of needle nose to hold the back of the nuts to keep them from turning. Once they brake loose then they will come on out without having to hold them. There are some small screws holding the cover on with a star type head.
Bronson1 is offline   Reply With Quote
Old 02-20-2013, 11:16 AM   #1431
ZBone
ZBone's Avatar
Oddometer: 339
Yea, I just figured that out... I've gotten the top 2 out but I'm having a hell of a time with the bottom 2. Thanks for the reply, Bronson.
Old 02-22-2013, 04:36 PM   #1432
swamp
U lie&yo'breff stank
swamp's Avatar
Oddometer: 1,800
does anyone know if the stock heated grips work with MX bars ?
... just looked. took the left grip off. there are two small screws that thread into the handle bars. the rubber part of the grip is on top of a plastic piece (the part that is screwed into the handle bars).
not sure how i could use the stock heaters with a beefier handlebar. guess i would have to drill and tap the new bars to accept the stock screws?
any other ideas?
also,
someone posted a picture of their relocated regulator rectifier earlier. did you just buy longer bolts ?
Enduro Earth
YOUTUBE
off the grid and deep in the woods
swamp screwed with this post 02-22-2013 at 04:51 PM
swamp is offline   Reply With Quote
Old 02-22-2013, 05:36 PM   #1433
kion
kion's Avatar
Oddometer: 184
Fender extender
Anyone know if Sertao beak extender will fit an '05 F650gs beak? They do look the same to me but just to make sure. If so anyone is willing to sell one?
kion is offline   Reply With Quote
Old 02-23-2013, 03:14 AM   #1434
Mr. GREEN
Oddometer: 15
rack wolman and remus
Hello
excuse me for my language
i have small information :
The wolfman rack does not adapt with a silencer remus.
It is necessary to cut and to lengthen a fixation(binding).
I have contact wolfman.
Their answer
Thank you for your email. I can now see the problem. But, I do not know what Wolfman can do. It is not possible to make racks and know every exhaust manufacturer. It is only possible to manufacture to BMW original system.
Dammage ! Wolfman is good farkles !
See the photo.
Uploaded with ImageShack.us
here it's just possible (3/5 mm)
but not here ! I have cut
Mr. GREEN screwed with this post 02-23-2013 at 06:09 AM
Mr. GREEN is offline   Reply With Quote
Old 02-24-2013, 06:47 AM   #1435
fiep
fiep's Avatar
Oddometer: 1,938
parot mode:
the dealer just put the forks back together
and the 'klunk' is gone
next question
is it normal for the Sertao to consume considerable more gas than the Dakar did?
thought the new engine was supposed to be a little more economic than the old one
Old 02-24-2013, 07:11 AM   #1436
Mr. GREEN
Oddometer: 15
next question
I am 4,3 liters / 100 km.
I believe that it is a lot.
Old 02-24-2013, 08:21 AM   #1437
fiep
fiep's Avatar
Oddometer: 1,938
the Dakar always got 60mpg, on a good day 65 that's between 3.9 and 3.6L/100km
the Sertao gets around 50mpg = 4.7L
Old 02-24-2013, 08:48 AM   #1438
ZBone
ZBone's Avatar
Oddometer: 339
I'm not sure where you got your information, but according to BMW the Sertao gets 74mpg at a constant 55mph and my experience with my bike has been spot on with this. Riding slab in the mountains at 65-70mph I'd average around 65-70mpg and riding the bike off-road and hard on the throttle I'd still get 55mpg.
Old 02-24-2013, 09:02 AM   #1439
ZBone
ZBone's Avatar
Oddometer: 339
Has anyone added some sort of soft tank panniers to their ride? I'm thinking it'd be a great way to carry some extra tubes, tire spoons, and levers. Looking at the bike I'm a little concerned that they'd cover the vents on fairing, but I'm unsure whether those vents have any sort of function or if they're just there for looks. All the hot air leaving the bike exits below the fairing onto my knee so I can't imagine what other purpose they would serve.
Old 02-24-2013, 09:43 AM   #1440
ar1814
ar1814's Avatar
Oddometer: 116
Same here, my "old" 2-Spark GS gets around 65 mpg, less than what the two above are getting with their Sertao
ar1814 is offline   Reply With Quote
Times are GMT -7.   It's 02:16 PM.
