Old 03-18-2013, 09:39 AM   #1
kcc OP
kcc's Avatar
Oddometer: 100
Front brake pad retaining clip shortcut?
When I dropped my wheels for new tires this weekend, the non-piston side pad on one of the front calipers popped out of the top retaining spring clip and hung down from the lower pin. I could not figure out a way to finagl the top of the pad back into the retaining clip without driving the lower pin out and repositioning both pads and reassembling. Not that hard in a clean shop, but...
With the caliper hanging loose to get the wheel out, it's really super easy for the pad to move enough to pop out of that clip. I had a wooden wedge in between the pads (have always done that when the wheels are off) and it still happened!
Is there a shortcut trick to getting it back in if that happens again? Seems like a pain in the ass to have to drive remove the safety clip (very small part) and drive the pin out if it were to happen on a trail.
"Kev, I don't think ADVRider is a good influence..."
-my wife
kcc is offline   Reply With Quote
Old 03-18-2013, 10:59 AM   #2
keener
Speed changes you.
keener's Avatar
Oddometer: 928
No shortcut that I know know. But I hear you about the pads popping out. I put it back in without removing the pin.
04 ADV 950
keener is offline   Reply With Quote
Old 03-19-2013, 05:34 AM   #3
ABuck99
0.0
ABuck99's Avatar
Oddometer: 595
I've had the same issue, and I didnt find any other way than removing the pin, then inserting the pad with the tab end hooked into the caliper then inserting the pin.
KTM: 06 KTM950S & 10 KTM450EXC
ABuck99 is offline   Reply With Quote
Old 03-19-2013, 11:04 AM   #4
kcc OP
kcc's Avatar
Oddometer: 100
Fair enough - thanks guys. I will make sure to include a drive pin in the toolkit!
-my wife
Old 03-19-2013, 11:36 AM   #5
MortimerSickle
Semi-Adventurer
MortimerSickle's Avatar
Oddometer: 12,228
BTW, I thought I would mention to be careful to not damage those clips. They come as a set at about 20 bucks for one caliper.
I miss round headlights.
"When I was a young man, I liked to race my horse...." -
G.H.W.S. 1878-1962
MortimerSickle is offline   Reply With Quote
Old 03-25-2013, 07:44 AM   #6
zedtours
zedtours's Avatar
Oddometer: 361
If your careful on removal of wheel pads should not drop, it seems they are more likely to drop when replacing wheel,so I use another inmates tip and put a short length of 8mm dia string in the gap and as disc is inserted just pull string out with pliers....no more dropped pads!
zedtours is offline   Reply With Quote
Old 03-25-2013, 08:08 AM   #7
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,806
8mm string??
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 03-25-2013, 09:41 AM   #8
DSM8
Where fun goes to die....
DSM8's Avatar
Oddometer: 3,800
I swap wheels all the times and I have never had a pad drop out, not sure what I am doing different though.
I would think the wedge from the back side would keep them in place and it gets popped out as the disk slides into the caliper.
I also make sure to compress the pads back into the housing far as they can go before taking the wheel off, maybe that is the difference?
DSM8 - A different kind of mean
SQL > SELECT finger FROM hand WHERE id=3
http://share.findmespot.com/shared/f...d5LbKWMz6cHxaH
DSM8 is offline   Reply With Quote
Old 03-25-2013, 11:23 AM   #9
Johnf3
Oddometer: 1,050
On double disc brakes like the Adventure, I find it is is easier just to take two minutes and pull the calipers. You gain back the two minutes and then some because it makes the wheel so much easier to put back on.
'06 950 Adventure S
'10 Husaberg FX 450
'01 KTM 520exc
Johnf3 is offline   Reply With Quote
Old 03-25-2013, 06:45 PM   #10
zedtours
zedtours's Avatar
Oddometer: 361
Originally Posted by FakeName View Post
8mm string??
string, rope ,cable WHY
Old 03-25-2013, 07:18 PM   #11
FakeName
FakeName's Avatar
Oddometer: 1,806
Ah.
I see you're from Surrey, and I needed the English translated to American.
And you're welcome for WW2.
(sorry ; ) )
2014 500EXC Black
Times are GMT -7.   It's 07:34 AM.
