Old 05-14-2012, 09:06 AM   #136
Spl990
Oddometer: 16
Wait reply from Rekluse Tech
Today i have send an email with a question if the Exp will work with the Radical Master Cylinder ,so when they will reply to me i inform you
Spl990 is offline   Reply With Quote
Old 05-20-2012, 01:54 PM   #137
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,433
I've had this damn Rekluse sitting in it's box in my Garage,
....yelling,...no, screaming !! at me for over 2 months now.
I've had some housebuilding priorities that have kept me from spending time with Big Orange.
This morning, I finally got it installed.
Easy. Very Easy. Two hours; only because I read the instructions 4 times to be totally comfortable with it.
A good and experienced wrench would take less than an 1/2 hour total, likely.
It worked perfectly first try, with just how it came pre-packed in the box.
Clutch "free play" adjustment took only two tries. Very easy.
OMG, this big mutha of dirtbike really needs this autoclutch. Thumpers beware
I'm really gonna like this...
Out for a "testride"........ C-ya !!!!
"got no problem with keeping truly roadless areas as wild....
On the other hand, if it has been logged or mined and roads already exist,,
...then that land should be open for public use" (peterman)
Apple Jam is offline   Reply With Quote
Old 05-20-2012, 02:23 PM   #138
Ladukebob
lost in hood river
Ladukebob's Avatar
Oddometer: 1,804
2012 wr250r
You don't know what you don't know
findLadukebob
Ladukebob is offline   Reply With Quote
Old 05-20-2012, 03:21 PM   #139
Nailhead
Free at last!
Nailhead's Avatar
Oddometer: 6,188
Just got one myself-- can't wait to ride it!
-Chris
'7? Benelli 650S, '80 BMW R100 RS, '93 Ducati 900 SS, '07 KTM 990 Adventure
Nailhead is offline   Reply With Quote
Old 05-20-2012, 10:32 PM   #140
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,433
Originally Posted by Ladukebob View Post
Holey Moley, This autoclutch is awesome !!
I can't believe the stuff I rode this pig up today
Steep, rocky & loose,....just slow down, massive traction, and NO STALLING
I made it up the POWERLINE road by going up the hill by the Oak Ridge Trail (off Smullin) to the top of Surveyor's ridge off FS17
I have never rode anything quite like that in my life...
...it was worse (I mean...better ) ....than the ride up to Mt Defiance
Old 05-22-2012, 07:01 AM   #141
cjracer
AWD please!!
cjracer's Avatar
Oddometer: 3,966
Great to hear this. Love the pics.
My 2006 950S thread. 2006 950s update
New product updates here! Wordpress BLOG
click www.cjdesignsllc.com for the full line of products. FREE STUFF!!
cjracer is offline   Reply With Quote
Old 05-22-2012, 08:30 AM   #142
Alleycatdad
Unbunch yer panties!
Alleycatdad's Avatar
Oddometer: 1,439
Yeah the rekluse is magic. Pure magic.
..Now if they'd only finish building mine....
S
When in doubt, PIN IT! It may not help, but it'll sure end the suspense...
Wretched Exce$$ See ADVr's around the world-ADV spotwalla page
Riding Wretched Wretched Passes
Bad decisions make good stories.
Alleycatdad is offline   Reply With Quote
Old 05-22-2012, 09:04 AM   #143
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,794
I'm going to have and reset mine to the OOTB setup and see if I still have the slippage at 4k-5K RPM.
Moto Trek'n to New York via the Trans Labrador Hwy, South America
Moto-Treks
moto-treks is offline   Reply With Quote
Old 05-22-2012, 09:21 AM   #144
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,433
Yeah, I mighta jumped the gun a bit with my "perfect" comments.....
I rode it on the street yesterday, and when I was passing a car, I hammered it at about 5k...
and then it spun quickly to 6k & 6.5k, then it finally grabbed and took off.
It's not quite like a normal clutch slip where you must let off throttle for it to grab,....it re-grabbed with the throttle on,
but it did slip. repeatedly. Hmmm.
Old 05-22-2012, 09:31 AM   #145
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,794
Hmm - maybe I'll wait them as those are the same symptoms I had. Riding at an RPM of 4k, open the throttle, and the clutch would slip for about 1k then it would hook up.
Are you running synthetic? When I called Rekluse they said using synthetic may cause the slipping
Switching to the heaver wedges help for me. I also changed the springs for a higher idle RPM.
Moto-Treks
Old 05-22-2012, 10:12 AM   #146
Apple Jam
Forest Flyer
Apple Jam's Avatar
Oddometer: 6,433
I have always used Motorex 10-50, the stock-type synthetic oil.
I will just ride it for a little while before I change anything, checking the clutch free-play regularly, just to see what happens.
It does not feel to me like this slip will actually hurt anything, but it'll need to be solved.
Maybe this is just a break-in issue?
I'm gonna do a larger oil jet, and I'll look at a change/fix at that same time.
Old 05-22-2012, 10:42 AM   #147
moto-treks
Back Home
moto-treks's Avatar
Oddometer: 1,794
That's the same oil I use. I agree, I don' t think the slipping will hurt anything, especially if you don't pass cars
The beauty of the EXP design is that it's very easy and quick to change out settings. I've done it twice and it's about a 10 minute job. If I get motivated and switch back to the stock 990 setting I'll post up if I still have the slipping.
Moto-Treks
Old 05-22-2012, 11:02 AM   #148
Dagwood_55
Dagwood_55's Avatar
Oddometer: 1,336
I was having the same problems. (Running Rotella reg oil). Hammer it at 4K and slip a K. I talked to Rekluse and they sent me 6 thinner smooth disk. I was then able to use another/added friction disk.
This helped a lot, but still not quite there.
I then installed the 3 heavier wts. at Rekluse's suggestion. Now it is spot on. I think if you did'nt know the bike had a rekluse in it and I let you try my bike, you would'nt even know it was Reklused. I can now break loose the rear in gravel, just like the OEM clutch. Its dang near perfect for me. And I have complete engine breaking going downhill, same as the OEM, unless you were to clutch it for a moment.
I'm completel sastified and happy!!
Live long, love much, laugh often, and
Ride, Ride, Ride.....
Dagwood_55 is offline   Reply With Quote
Old 05-22-2012, 11:39 AM   #149
ktm950se
ktm950se's Avatar
Oddometer: 1,385
'Still wondering why folks are wasting time and money on these clutches...
If they all worked perfectly straight out of the box, I might understand that they provide value in maybe 1% of the riding conditions you'd likely experience, but with the cost of these things, and the tuning frustrations, why bother?
ktm950se
ktm950se is offline   Reply With Quote
Old 05-22-2012, 11:41 AM   #150
Dan950ser
NW Shredder
Oddometer: 415
Cannot wait to get mine... Please hurry up Rekluse.
2007 KTM 990 SuperDuperEnduroR
2014 KTM 250 XC-W
Dan950ser is offline   Reply With Quote
Times are GMT -7.   It's 02:29 AM.
