Old 12-13-2011, 09:24 AM   #1
England-Kev OP
Location: Berkshire, England. Just off the Beaten Track!
Oddometer: 2,556
Odd airhead problem
I am having an odd problem with my R80ST...
If I don't ride it for a while, it will not start, it just turns over and over, and won't fire up? it never used to do this. even when stood during winter months, you could turn on the fuel, full choke, ignition on, and it would fire right up.
But now I can go through that same sequence, and it will just turn over, I even gave it extra power by jumping it from my works van, but it still just turned over for ages, finaly it fired up, and then ran great, and would then start instantly.
Now I think this could be a fuel starvation thing, I wonder if the new high ethanol fuel is gumming up the jets when parked up. I say this, as I pulled a plug on Saturday, and it was dry not wet.
Your thoughts please.
England-Kev is offline   Reply With Quote
Old 12-13-2011, 10:31 AM   #2
supershaft
because I can
Oddometer: 6,047
See if the plugs are sparking next time.
Make sure your choke cables are adjusted correctly.
Old 12-13-2011, 11:12 AM   #3
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 7,354
Check the choke cables, but also the choke jets in the float bowls that they're not obstructed, plus the choke bodies tend to loosen and the gasket pulls in allowing a vacuum leak which equates to no suck - no choke action.
Old 12-13-2011, 11:28 AM   #4
mark1305
Old Enough To Know Better
mark1305's Avatar
Oddometer: 5,516
Kevin, I'm with your guess about gas gumming up the carbs. The blend here in FL has gotten so bad that gas powered yard tools try to gum up if not started on a weekly basis. We are nominally at 10% ehtanol here, but the other seasonal additives appear to be carb unfriendly as well. Don't know how your gas blends over there compare, but could be the culprit.
And to echo what wirespokes said - my ST was acting similarly a couple of year ago prior to the partial carb overhaul. Sure enough, the choke pickup tube had the little tiny jet in the corner of the float bowls clogged up.
Mark J
Merritt Island, FL
When a person asks you for advice, they don't want advice. They want corroboration.
mark1305 is offline   Reply With Quote
Old 12-13-2011, 12:09 PM   #5
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,004
Do verify the battery. Low volts during cranking can mean not enough amps left for a sharp spark.
A pritz of starting fluid is a quick test. If no jump to attention from that, you know it's a spark issue. If it does fire, fuel or vacuum issue. Once running, any vacuum leak can be found with the starting fluid.
Just investigate the usuals mentioned above. You can have the culprit in hand in 10 minutes. Don't be surprized if you find more than one weakness adding up to no cold start, so do inspect and test all possibles noted.
DoktorT is offline   Reply With Quote
Old 12-13-2011, 12:30 PM   #6
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 945
I would also check valve clearance and timing.
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 12-13-2011, 12:46 PM   #7
Westbrook
Oddometer: 108
Can you elaborate on the method for finding vacuum leaks with starting fluid?
Westbrook is offline   Reply With Quote
Old 12-13-2011, 07:11 PM   #8
Cogswell
Spudly Adventurer
Cogswell's Avatar
Oddometer: 3,253
Do you run the float bowls dry prior to parking the bike, or leave them full of petrol and just turn off the tap ?
I have found if I run the bowls dry before parking it is a lot easier to start with "fresh from the tank" fuel in the carbs.
My $.02
Mike
Cogswell Rides To Big Bend
See my airhead project here
Time Warp Vintage Motorcycle Club
The good thing is, your damn motor can't read. If it says oil on the container, it's pretty much OK to dump in there.... ED.
Cogswell is offline   Reply With Quote
Old 12-13-2011, 08:10 PM   #9
goatroper
goatroper's Avatar
Oddometer: 530
This is like a quiz show, right?
If I don't ride it , blah, blah, blah high ethanol fuel is gumming up the jets blah, blah, blah
And for the bonus points.............. You've been hangin' around that plunger-framed trollop.
How did I do?
goatroper is offline   Reply With Quote
Old 12-13-2011, 08:43 PM   #10
Wolfgang55
Wolfgang55's Avatar
Oddometer: 2,955
dirty carbs not the same
Have done a bit of carb work & not trying to get in anyone's space here.
What I've seen is the NON ethynol gas would gum or sticky up a carb if allowed to stand in a carb for long periods of time w/o a stablizing additives.
That said, what I have found in the same carb on a different bike that ran on our 10% ethynol & when left sitting w/o any fuel additive was Fuzz & water in the bottom of the carb bowl. The main intake jet, the pilot jet, needle jet & more were near green w/ fuzz. I think you get the picture here. The brass was actually fuzzed over not gummed up.
Ok, we may at first think a non working carb is all the same but actually it's not.
If you clean & de fuzz the carb you still have the same separation taking place in the botton of your fuel tank.
What I have seen is when the bike is running it will injest a bit of moisture & still run, not perfect but it will run. The moisture will again begin to settle at the bottom of your carb. Our bikes' tanks are always moving left & right etc, so the better fuel is still flowing in to the carb in higher levels over the water.
Let this bike sit around again & in a shorter time than before the same bike using the same tank of fuel will now be on a fast track to fuzz up again.
I'm not trying to sell any product here because I've not found all fuel additives do all thing for all fuels.
So when thinking about going to a fuel additive, read the lable & be satified you are buying what will help your current fuel to not seperate, as time go on.
Wolfgang55 is offline   Reply With Quote
Old 12-14-2011, 06:06 AM   #11
DoktorT
BigBrowedNeandereer
DoktorT's Avatar
Oddometer: 1,004
Works best with a digital tach to find small vacuum leaks. Bigger leaks can be heard by ear.
Set the engine running at idle. Shoot a little spritz of starter fluid at the various clamps and interfaces, carb to head, enricher gaskets, and watch the tach or listen for increase in rpm. Just a quick and easy way to eliminate one of the usual suspects.
Old 12-14-2011, 08:24 AM   #12
Westbrook
Oddometer: 108
Thank you!
Old 12-14-2011, 11:59 AM   #13
Horsehockey
A GPS? Huh?
Oddometer: 222
Do not ignore this suggestion. Particularly valve clearances.
Horsehockey is offline   Reply With Quote
Old 12-14-2011, 12:09 PM   #14
supershaft
because I can
Oddometer: 6,047
I shut off /2 petcocks because you have to. It pays to shut them off a bit before the ride is over. /5 on wise on the other hand, properly set up Bings and Dellortos don't leak. I almost never shut my airhead petcocks off because it doesn't matter. If I am gone for a long time or my bike is getting transported, sure but other than that . . . no.
Old 12-14-2011, 01:21 PM   #15
England-Kev OP
Oddometer: 2,556
I always run the float bowls dry, valve clearences are good, and I have never had to adjust the timing in the 3 years I have owned it.
I will check the choke tubes this weekend, could this problem be sticking weights in the bean can?
Times are GMT -7.   It's 08:58 PM.
