Old 12-14-2011, 03:28 PM   #16
supershaft
because I can
Oddometer: 9,116
I remember when the sticking weights bulletin first came out and I have had my eyes open for it every since. In all the airheads I have worked on I have never found them sticking in a bean can. I have since heard so many people on the net talking about it. I have still never seen it except for maybe once but I fixed too many things at once to know for sure. I have seen a couple completely F'ed up for water crossings but I don't count them. I have fixed tons of fast idling or other engine troubles always blamed on sticking bean can weights but it has always been something else. Namely carb adjustments. I have seen regular points advances cause more trouble in my experience but not by much. I think part of the problem is a couple of guru's "definitive" sticking weights diagnosis methods that are in fact not definitive at all. For these reasons I think it is highly unlikely.
Old 12-14-2011, 03:41 PM   #17
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,195
I'll agree with that. If it runs fine once started, the problem isn't the advance!
The most likely areas to check are the choke and coil/plug leads/connections to the coil. But the plugs not being damp really points at the enricheners.
If the throttle is opened at all when cranking, the vacuum needed by the chokes will be drained off. So leave the throttle closed until the engine actually starts.
Old 12-14-2011, 09:18 PM   #18
Mike Ryder
Kriegerkuh
Mike Ryder's Avatar
Oddometer: 999
Be carful with starting fluid [ether] as it is FREAKIN flamable. A small spark is all it takes to light up. I know fires are fun but.....
If you can, use unlit propane in the same manner.
Yes I am quite serious.
Mike Ryder screwed with this post 12-15-2011 at 05:25 PM
Mike Ryder is online now   Reply With Quote
Old 12-15-2011, 07:58 AM   #19
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,724
Originally Posted by Westbrook View Post
Can you elaborate on the method for finding vacuum leaks with starting fluid?
I don't think anybody answered you yet? Now that you have been warned that using starting fluid, especially in the method I'm going to describe is dangerous, we can proceed. This method belongs properly in the large category "Shade Tree Mechanics". A forum that doesn't even exist but which I am a leading member of, go figure.
Spray starting fluid around the air tubes and intakes of a running engine. If the idle noticeably changes, usually up, then you have found an air leak. This can be done with other sprays like WD-40 or carb cleaner but like implied they may not cause idle to go up. Starter fluid will make the idle go up.
Charlie
PS; I think England Kev has the neatest bikes.
---Albert Einstein
Old 12-23-2011, 09:09 AM   #20
CurlyMike
Formerly SaddleSoar
CurlyMike's Avatar
Oddometer: 985
England-Kev, what was the final diagnosis that fixed the problem...
Giving the horses and the wife a break from riding...
CurlyMike is offline   Reply With Quote
Old 12-24-2011, 04:50 AM   #21
England-Kev OP
Oddometer: 3,642
I've not been through it all yet. work has got in the way!
But I have been riding it the last couple of days, and it has started up after a few turns, but is still not right.
After Christmas I shall go through all the above suggestions one at a time, and see if I can find the problem.
Merry Christmas to all those that do, and Seasons greetings, to all those that don't.
Peace be with you all.
England-Kev is offline   Reply With Quote
Old 12-24-2011, 08:36 PM   #22
Reryder
Onward through the fog...
Reryder's Avatar
Oddometer: 1,399
Originally Posted by England-Kev View Post
If I don't ride it for a while, it will not start,...
Can you define "a while"?
Seems like all modern petrol goes crap very quickly when left sitting in unused vehicles.
Back in the early 80s I left my old Harley Sportster in my Dad's garage while I went overseas.
Came back in the early 90s, put a battery in it, gave it two priming kicks, switched ont he ignition, and it started first live kick. Running purely on the decade-old gas in the tank. True story.
Now, that same bike (fully restored these days) is a bitch to start if it has been sitting unused for a month or more.
They just don't make petrol like they used to back when it contained good old-fashioned lead and and all that good stuff.
'77 Harley Ironhead 6,000 miles across Oz
http://advrider.com/forums/showthread.php?t=527966
Reryder (AKA Hopper)
1977 Harley Sportster
81 BMWR100RS
01 HONDA VFR800
99 SV650
Ancient Harley 45, Snortster (Sporty engine in a Norton), Norton Atlas, Honda 350/4, Ariel HS scrambler
Reryder is offline   Reply With Quote
Old 12-25-2011, 01:29 AM   #23
England-Kev OP
Oddometer: 3,642
I had'nt used it for two or three weeks. It really was such an easy starter, that is why it is odd. When I do get it started, it then becomes instant again. so it is related to the initial fire up.
The only thing I have changed recently is the plug leads, I got a new set from Rick at Motorrad. I shall go through everything over new years.
Old 12-26-2011, 01:29 AM   #24
JohnDL
JohnDL's Avatar
Oddometer: 168
I find my '92 R80RT doesn't start as easily as it normally does if left any longer than two weeks,
When I use it more regularly, it starts instantly - first press of the button every time, but once it's been standing about two weeks, it needs to turn over much longer before firing.
My brother said his six year old Harley is the same, so I'm guessing it must be the fuel going off pretty quickly because once the bike is started, it runs faultlessly.
There's plenty of evidence of poor shelf life and other issues relating to petrol/ethanol on the 'net.
I found this after a quick search:
http://www.fuel-testers.com/manufact...hanol_e10.html
Motorcycles
* Manufacturers that prohibit use of E10 fuel or issue warnings include:
Ducati - Prohibits use of E10 fuel- Quote, "Additives to fuel or lubricants are not allowed.".
Harley Davidson - E10 warnings/precautions only - Quote, "You may find that some [ethanol] gasoline blends affect the starting, driveability, or fuel efficiency of your motorcycle. If you experience one or more of these problems, it is recommended you operate your motorcycle on straight unleaded gasoline.".
Suzuki - E10 warnings/precautions only - Quote, "If you are not satisfied with the driveability or fuel economy with your motorcycle when you are using an oxygenated fuel, you should switch back to regular unleaded gasoline."
JohnDL is offline   Reply With Quote
Old 12-26-2011, 01:20 PM   #25
redboots
Johnny Lung
redboots's Avatar
Oddometer: 141
Have you tried putting proper fuel in it instead of E10 shit?
E10 is hygroscopic and as its a bit moist in the UK
In France they tell you not to use it in ANYTHING prior to 2008. Mostly rubber parts deterioration related I think.
John
Are you a Hollow Chocolate Bunny of the Apocalypse?
redboots is offline   Reply With Quote
Old 12-26-2011, 02:50 PM   #26
Mototrekker
Oddometer: 14
I'm surprised no one has mentioned checking the start relay connections.
Mototrekker is offline   Reply With Quote
Times are GMT -7.   It's 09:13 PM.
