Old 04-06-2005, 04:29 PM   #1
CountPacMan OP
KTM 640 Adventure abuser
CountPacMan's Avatar
Oddometer: 106
640 Adv DUAL radiator fans guide
Most of us have had overheating problems, usually on really hot days while stuck in traffic. I've run through everything - there's no air in my water lines, I'm using a good mix, etc... there's a reason why the 660 Rally's have dual fans and today I finally picked up a second fan for my 2000 Adventure. Upon first inspection, I notice that it is the NEW fan - the one included on the new LC4s, which is MUCH bigger and it has a big casing to go with it. After I took the tank off and fiddled with it a bit, I noticed that it would take a little casing modification with the knife to get it to fit on the right side radiator because of the decompression cable, but it would easily fit on the left side where the original, smaller fan sits. Now before getting started, I recommend disconnecting the battery, or at least removing the main electrical system fuse next to the battery - this is especially important when handling the Capacitor as if you're not careful, you can short the leads on that thing and... and... well, not much, you'll probably just blow out the main fuse that you should have removed. I first removed the Capacitor and bracket, becasue it was in the way on the right side and the I removed the original fan and remounted it to the right side and put the new one on the left side. No problems so far.
New BIG fan on the left side:
Now I have this orange colored capacitor dangling there I can't for the life of me figure out where to put it so it doesn't make contact with something else. My solution was to mount it using the front most bolt on the Thremostat. Of course, since I'm certified, I removed the bolt and instantly had coolant shooting all over me. Do the opperation quickly and use a finger to stop the coolant while fumbling to thread the bolt in the Capacitor's bracket. The bracket can face inward (to the engine) or outward (like KTM puts it at the factory). I had to make it face inward to clear the tank.
Capacitor attached to the Thermostat(note the coolant that shot all over the place):
Now, it looks really nice, but there's only one plug for the fan, and now I have two of them. Easiest solution was to chop the plug off one of the fans (I chopped the old, small version as it has really thin wires) and splice them into the the other fan's wires, just before the plug. I think you gotta get the pos/neg right, but am not sure if it matters. I'm not an electrician. I turned on the ignition on and tested the setup by shorting the thermoswitch in the right side radiator with my screwdriver. Both fans instantly shot to life.
Both fans. Looks cool eh?:
I put everything back together and went to roast in some Bucharest traffic. No overheating, fans come on, and whats really nice, is how quickly they turn off. Normally if you sit in traffic and crawl for 15 minutes to your destination, and leave the ignition on after parking the bike, you can hear that poor little fan go for 3 minutes or more. Not anymore. The dual fans cool things down really quickly, and I haven't seen them go for more than 10 - 20 sec. after shutting off the engine.
I had kind of hoped that having two fans would eliminate the "blowdryer" sound I get when the fan kicks on. No suck luck. Its now "Blowdryer 2: in Stereo!"
"Improvement makes strait roads, but the crooked roads without Improvement, are roads of Genius"
- William Blake 1757-1827
spake Rad, "The KTM will reward you like a very expensive mistress where the BMW will reward you like a, like a... like a wife "
CountPacMan is offline   Reply With Quote
Old 04-06-2005, 04:41 PM   #2
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 14,242
Nice write up PacMan! Thanks for the help. How much did the parts cost ya?
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is online now   Reply With Quote
Old 04-06-2005, 06:11 PM   #3
craigincali
Just hanging around
craigincali's Avatar
Oddometer: 2,142
I was just in the garage looking at a solution to this and I came up with the same idea except I am gonnna use a old fan...the small one. I will then have two small fans.
Tell me again how to test the fans to make sure they work? You short the thermostate? How...?
Craig
Me
I am usually drunk when I post so dont take it personally !
2010 KTM 990
craigincali is offline   Reply With Quote
Old 04-06-2005, 06:12 PM   #4
craigincali
Just hanging around
Oddometer: 2,142
Craig
Me
2010 KTM 990
Old 04-06-2005, 07:46 PM   #5
CountPacMan OP
Oddometer: 106
Hi Craig, I'm sure it will work just as well using two small ones. Found one off a donor bike?
Craig
Not the thermostat, the thermostat is just a valve that opens at a specific temp to let the water flow. You short the the thermoswitch, which is the electrical thingy that is screwed into the right side radiator at the very bottom. This thing just completes a circuit when the water temp rises above 85 Celcius and breaks it when it drops below 80. You'll see wires coming out of it. The wires lead to the fan. Just pull the sheath off(which hardly stays on to begin with), and you'll see two bare wires. Complete the circuit using someting metal - like a screwdriver (while holding on to the plastic handle of course) while the ignition is on(engine does NOT need not be running).
Glad you liked it. I bought the fan from some guy here who has a 2003 Adventure and has lost his mind. He is attempting to make some sort of ultra-light rallyraid machine out of it. He's selling the fairing, fuel tank, and stock pipe as well. I have NO clue, why he thinks the fan weighs so much, but I was happy to buy it off him for 50 Euro. Thats like $68, which is close to how much it would probably cost brand new back in the States, but not here. Everything is more expensive in Euorope. Yes folks, KTM parts actually cost more in Austria in Mattinghofen than anywhere in the States, not to mention the ridiculous price of the bike itself.
If you want to order it new, the part numbers are:
58435041000 x 1 (fan)
58435044000 x 1 (casing)
58435044050 x 2 (not so important rubber flaps)
0017060203 x 2 (attachment screws)
0081500181 x 4 (casing attach screws)
58312085100 x 1 (really unimportant edge guard that you could make yourself)
I think it was under $90 for everything. I say WAS, since I did order it a while back, my brother got them in the mail very rapidly from Munn Racing in Texas, and then mailed them to me in Romania. In January. Lo and Behold, they're still not here. Surprise...
Old 04-06-2005, 07:58 PM   #6
Frank Warner
Traveller
Frank Warner's Avatar
Oddometer: 6,593
How reliable are the fans?
The ones on BNMW K series have a habit of sezing (lack of use leading to corrosion on the front bearing) and then when needed they over heat the brush area (made of plastic) that then deforms and eventaully blows the fuse ... mean while the engine is overheating ...
Regards Frank Warner
motorcycles BMW R80 G/S 1981, BMW K11LT 1993, BMW K75 G/S
http://www.geocities.com/fwarner_au/
Frank Warner is offline   Reply With Quote
Old 04-06-2005, 08:14 PM   #7
CountPacMan OP
Oddometer: 106
I've never seen or heard of one go out
Old 04-06-2005, 08:28 PM   #8
craigincali
Just hanging around
Oddometer: 2,142
Actually, by replacing the small fan with just the large fan alone may be all it needs to stay cool.....
Me
2010 KTM 990
Old 04-06-2005, 08:33 PM   #9
CountPacMan OP
Oddometer: 106
not really, I've heard that the new bikes still have the problem, though not as often. Besides, they don't really weigh all that much, so if you're ordering another fan, might as well use both. There's absolutly no drawback, as you can't "overcool" it. Fans switch off when water temp reaches 80 C.
Old 04-07-2005, 04:37 AM   #10
rob_erto
rob_erto's Avatar
Oddometer: 150
Very good post!
had already thought of doing something similar to my transalp. As my main transportation for the city, it heats up quiet quickly in heavy traffic.
Rodolfo Barros - Portugal
Honda AfricaTwin '00
Honda X8R-X '00
rob_erto is offline   Reply With Quote
Old 04-07-2005, 06:04 AM   #11
meat popsicle
Ignostic
Oddometer: 14,242
I am surprised the shroud or cowling for the fan doesn't cover more of the radiator on that side? I guess its for air flow with the fan off.
Parts fiche from CycleHutt
#40
Item #: 58435041000
FAN CPL. 12V LC4 2000
Quanity On Diagram: 1
Cost Each: $83.18
#41
Item #: 58435044000
FAN CAP LC4 2000
Cost Each: $4.49
#42
Item #: 58312085100
EDGE PROTECTOR PER METER
Quanity On Diagram: 0,22
Cost Each: $7.33
#43?
#44
Item #: 58435044050
FAN FLAP RUBBER LC4 2000
Quanity On Diagram: 2
Cost Each: $3.38
#45
Item #: 0081500181
SCREW FOR PLASTIC D=5X18
Quanity On Diagram: 4
Cost Each: $0.78
#46
Item #: 0017060203
EJOT PT SCREW K60X20 WS=6
Cost Each: $1.05
Total for a setup: $100.21 plus tax (free ship?) and some wiring work during the install.
not bad for what you get!
Old 04-07-2005, 11:38 AM   #12
CountPacMan OP
Oddometer: 106
Order through KTM Talk as a member, and you get 15% off + unless you live in the dealer's state, no sales-tax. Probably why I remember paying under $90 for the stuff originaly...
Old 04-07-2005, 12:30 PM   #13
techieguy
Lost in the woods
techieguy's Avatar
Oddometer: 354
You can also order the stuff from Budd at Matto Cycle, www.mattocycle.com and get the 15% discount too.
Just click on the "KTM Parts Online" graphic and you get the parts diagram.
techieguy is offline   Reply With Quote
Old 04-07-2005, 02:09 PM   #14
Buckster
Buckster's Avatar
Oddometer: 1,003
If the dual fans run that little, it probably means that they are drawing less juice than running the single fan for much longer periods so this could be a good "battery saver" mod as well.
Buckster is offline   Reply With Quote
Old 04-07-2005, 07:22 PM   #15
rapiti
IOR Veteran
rapiti's Avatar
Oddometer: 1,907
Thank you for taking the time to write this up! I had been planning this mod, and I will likely do it after exposing my waterless coolant to Texas Summer heat. The bike does seem to run cooler, but dueling fans offer some redundancy comfort.
...its the best paint scheme that has ever been or ever will be on an Adv...-AussieRob
rapiti is offline   Reply With Quote
Times are GMT -7.   It's 10:29 PM.
