Old 09-22-2009, 01:24 PM   #76
Lear60man
Sleeping
Lear60man's Avatar
Oddometer: 714
Update. Install was stupid easy. Hard wired it to the battery with an on off switch on the handlebars. Noticeable difference as the temp drops immediately. Does anybody know if the thermostat that comes with the kit is the lower temp thermometer?
Lear60man is offline   Reply With Quote
Old 09-22-2009, 01:52 PM   #77
ChrisC
Molon Labe
ChrisC's Avatar
Oddometer: 6,286
I was going to try to retrofit the older 85 deg C thermoswitch. When it came I found it to be for the older style, smaller bung in the radiator. So I capitulated and wired in a manual override switch (still on one fan though)...
Chris
'03 KTM Adventure 640
'43 BSA M20WD
ChrisC is offline   Reply With Quote
Old 02-01-2010, 09:17 AM   #78
makazica
makazica's Avatar
Oddometer: 705
Would somebody be willing to teach me how to wire a second fan so I can also mount a switch....in order to manually control the second fan....??
Sorry, I'm an electrical idiot......
makazica is offline   Reply With Quote
Old 02-01-2010, 02:40 PM   #79
sellmeyer
Oddometer: 387
looking for dimensions of the radiators
can anyone provide me with the approximate size of each radiator on the 640 LC4?
I'm currious how they might work on a BMW F650GS single, which has a single, thin radiator which is 25% blocked by the main frame...I was thinking about looking for a custom pair of radiators but figured they would cost too much.
Maybe a pair from the KTM would be suitable and a cheaper option than custom?
-also, can anyone tell me why these engines are running so hot? I know the fan kicks in quite a bit on my bike, but maybe the Rotax does run as hot as the LC4 and can thus get away with a smaller radiator?
-thoughts?
sellmeyer is offline   Reply With Quote
Old 02-01-2010, 04:22 PM   #80
boney
Ride > Post
boney's Avatar
Oddometer: 1,376
-thoughts?
Another option, for those who aren't into spending money on another fan is to piggyback a pair of wires to a switch in your cockpit. Just run two wires connected to a switch on your handlebars or wherever down to the thermoswitch. At the south end of the wires attach some piggyback connectors:
Disconnect the two stock wires from the thermoswitch, plug in your new wires (with the piggyback connectors) then re-attach the stock wires onto the piggybacks. Now you have manual control of your fan, which will still work via the thermoswitch normally if you haven't manually activated it.
In my experience, if I turn the fan on early, I don't need a second fan. The key is to get air flowing asap when your speeds get low. Your mileage may vary.
The Beach Bus
Esoteric, at best.
boney is offline   Reply With Quote
Old 02-02-2010, 08:55 PM   #81
meat popsicle
Ignostic
meat popsicle's Avatar
Oddometer: 13,839
there have been a few wiring diagrams over the years posted... was it on this?
dig, dig, dig...
This one enough?
http://www.advrider.com/forums/showp...6&postcount=70
Kronreif Trunkenpolz Mattighofen LC4 640
Its not so much staying alive; its staying human that counts.
meat popsicle is offline   Reply With Quote
Old 12-29-2010, 09:09 AM   #82
9Toes
9Toes's Avatar
Oddometer: 35
Question Its a worry
Just for feed back fitted fan as per right had side but wired into the unused power lines for the factory fitted road book plug just above the lights. Just not the brightest as I added the road book a year earlier and hard wired that into the 12 V aux socket. I just couldn't figure what fuse I would require, but in both cases hoping that both are fused to main box at battery.
Fan works fine on manual toggle.
Someone with some sense of electricity can let me know how dump this is or is piggybacking ok ?
Cheers
Bothy,Angus, Scotland.
KTM 640 Adv & GS 1200
9Toes is offline   Reply With Quote
Old 02-09-2013, 07:17 PM   #83
wrk2surf
BITD/Rallye
wrk2surf's Avatar
Oddometer: 5,307
just a bump for a good thread.. is it in the lc4 thread ??
Thanks for the 2013 support: DUNLOP, BELL HELMETS, Kriega USA, Carbon-pro.com, Ride 100% Goggles, Renazco Racing, Sidi/Motonation, Acerbis USA,KLeN, FMF, Mx1west,,Masters paint and body, Magura , motolab ,and Freedom Cycle
wrk2surf is offline   Reply With Quote
Old 02-11-2013, 05:59 AM   #84
meat popsicle
Ignostic
Oddometer: 13,839
'tis
meat popsicle screwed with this post 04-28-2013 at 10:44 AM
Times are GMT -7.   It's 07:22 PM.
