Old 12-22-2011, 08:52 PM   #16
3 up
Les in LV
3 up's Avatar
Oddometer: 146
I left the vent on the carb open didn't want gas sloshing into it. vented the tank outside by the main tube check out he pics
The big hole in the intake boot I plugged it
Life is Short Ride More Work Less
3 up is offline   Reply With Quote
Old 12-22-2011, 08:54 PM   #17
3 up
Les in LV
3 up's Avatar
Oddometer: 146
Old 12-22-2011, 08:54 PM   #18
3 up
Les in LV
3 up's Avatar
Oddometer: 146
Size:  28.7 KB the gas tank vent
Old 12-22-2011, 08:55 PM   #19
3 up
Les in LV
3 up's Avatar
Oddometer: 146
Intake boot plugName:  ImageUploadedByTapatalk1324616132.546311.jpg
Old 12-22-2011, 08:56 PM   #20
3 up
Les in LV
3 up's Avatar
Oddometer: 146
More pics hope this helpsName:  ImageUploadedByTapatalk1324616186.716102.jpg
Old 12-22-2011, 08:57 PM   #21
3 up
Les in LV
3 up's Avatar
Oddometer: 146
Old 12-22-2011, 11:06 PM   #22
gitsum79 OP
Oddometer: 91
After I put it back together the second time, it worked! Thanks for the pics and additional instructions, it confirmed what I screwed up. Apparently the air box/intake hose that was going to the smog device under the gas tank was more or less open because the cannister was removed from the other side.
Update!
The carb vent has to stay open. Previously I tried hooking it up to a one way valve I pulled off with the smog junk.
Apparently there wasn't enough air pressure, because sometimes the Wolf would run fine, sometimes it would run horrible again. Took me a little while to figure out the problem, but once I left the carb vent hose open, all was good
gitsum79 screwed with this post 12-24-2011 at 07:22 PM
gitsum79 is offline   Reply With Quote
Old 12-27-2011, 03:06 PM   #23
guns&coffee
Gnarly!
guns&coffee's Avatar
Oddometer: 1,239
I was stationed at Camp McGreggor north of El Paso and at White Sands back in 07/08. It looked like there were some nice roads/trails to ride out there. If you like Mexican food, try El Chapparal in El Paso. The Gorditas are kick ass.
"Over the Mountains Of the Moon,
Down the Valley of the Shadow, Ride, boldly ride,"
The shade replied- "If you seek for Eldorado!" E.A.P. 1849
04 KTM 950ADV ~ "BEASTIE", '13 KTM 300XCW, '75 Husky 360WR/CR,
guns&coffee is offline   Reply With Quote
Old 12-27-2011, 03:28 PM   #24
3 up
Les in LV
3 up's Avatar
Oddometer: 146
Wow small world my dad was stationed there in 1958 fort bliss I think. I was born in Las Cruces NM wife is from Santa Fe
Times are GMT -7.   It's 01:06 PM.
