Old 01-27-2010, 09:32 AM   #481
VTbeemer
Traveler
VTbeemer's Avatar
Oddometer: 350
Originally Posted by walkingbear
working on a batch of 10 off the designed ..but a little better
Put me down for one...
http://vtbeemer.blogspot.com/
14' R1200GSW- 93' R100GS/PD- F650GS- 94' R11RS
08' WR250R- 95 R100R- K75s- 57' R69
77' R75/7- 06' Ducati S4R Monster- 74' XL 250
VTbeemer is offline   Reply With Quote
Old 02-16-2010, 07:28 PM   #482
walkingbear
walkingbear's Avatar
Oddometer: 3,502
brake adapters are being delivered
they will be here in the next 10 days.
look at this thread:
http://www.advrider.com/forums/showt...brake+adapters
BMWMOA 82741 ABC 8418
2wheeltraditions@gmail.com
75 R90S , 77 R100 RS,88 R100GS ,94 R1100RS (Aragorn) 2k 1150GS DMC sidecar,
Rosso Mandello V11 , 2014 R nine T
walkingbear is offline   Reply With Quote
Old 03-09-2010, 12:06 PM   #483
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
to you guys that have done this conversion:
what is the thread pitch on the banjo bolts. i'd like to find out without removing mine from my bike.
bmwblake is offline   Reply With Quote
Old 03-09-2010, 12:21 PM   #484
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,493
The bolt on the master cylinder are 10mm X 1.0
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 03-09-2010, 11:32 PM   #485
x3300
geoff
Oddometer: 170
The same banjo bolt M10 x1.0 will work on the caliper also: http://tinyurl.com/yecs4ud/front-bra...tock-rotor.jpg
-x3300
x3300 is offline   Reply With Quote
Old 03-10-2010, 07:38 AM   #486
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
thanks AW and x3, i'll have something on the way shortly.
Old 09-25-2010, 06:14 PM   #487
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,241
Originally Posted by ADV8
ADV8's post thread 151 (page 11) may be somewhat misleading.
I just done a Tokico 4 pot conversion for the GS. The caliper was originally off a RGV250 (VM21). My Tokico piston sizes are 34mm & 30mm respectively, ie the same as the Nissin. Pad is a Premier PH53 HH sintered, EBC158HH Sintered, Ferodo FDB574, SBS 631, or Vesrah VD-343/344. Here's a picture of it on the bike.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits screwed with this post 11-08-2011 at 01:26 AM
Box'a'bits is offline   Reply With Quote
Old 09-27-2010, 05:30 PM   #488
walkingbear
Oddometer: 3,502
SS Brake line
Can anyone share the length of your SS brake line and what fittings
you put on them.
Old 09-28-2010, 07:40 AM   #489
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
banjos on both ends with 15 degree bend. i ordered a 50in after reading a in this thread that was the needed length, but it's way too long. i had to get inventive with routing. 43in should be fine, but measure on your bike to double check.
you put on them.
Old 09-28-2010, 12:10 PM   #490
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,241
you put on them.
The standard line is about 40" or a metre long. Depends on whether you follow the standard positioning, & if you are using bar risers as to whether you need longer.
We didn't retain the metal line through the fork legs. To guard against line flex rubbing the tyre we routed it outside the fork leg. Reused standard line retainers.
Yes, slightly angled banjo at the top fitting. The guy that made my fittings used what he called a bungy line at the bottom to allow this to be bent after we fitted the line, so that there was not twisting force on the line (SS lines don't accomodate that well).
Steve
Old 09-29-2010, 12:56 AM   #491
igormortis
igormortis's Avatar
Oddometer: 1,355
Bungy line - interesting. Looks like that's what I need.
My braided line ends in a cut-down original hard line and I've been worried about it being stressed by the line and breaking.
igormortis is offline   Reply With Quote
Old 09-29-2010, 02:43 AM   #492
Padmei
enamoured
Oddometer: 3,654
Steve
Can you post up a pic of the bungyline?
Padmei is online now   Reply With Quote
Old 09-29-2010, 02:59 AM   #493
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,241
Actually I would have almost preferred to keep the original hard line. That way it could be passed through the fork leg with little issues re getting flexed into the tyre, or caught by passing bushes.
Look in the photo for my earlier post. It's the bent piece of hard line. As I understand it, it'll basically bend (& hold) whatever shape you pull it into, without crimping the hose line.
Old 09-29-2010, 12:10 PM   #494
DimitriG
DimitriG's Avatar
Oddometer: 87
Question front end replacement
is there any reason why people are not just replacing the whole front end, wont be that much more expensive from a breakers yard, then you get the handling benefit and chop the springs to your needs. i know honda and suzuki use the same headset sizes (am i wrong?).
DimitriG is offline   Reply With Quote
Old 09-29-2010, 07:13 PM   #495
Beemerboff
Oddometer: 2,311
The Ohio Cafe Racer Web site has a good list of what fits what - hopefully some computor geek will link us to the ones that fit Airheads- Im to dumb to.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Times are GMT -7.   It's 04:40 PM.
