Old 09-30-2010, 12:49 AM   #496
DimitriG
DimitriG's Avatar
Oddometer: 87
Thumb
Originally Posted by Beemerboff
The Ohio Cafe Racer Web site has a good list of what fits what - hopefully some computor geek will link us to the ones that fit Airheads- Im to dumb to.
good info, http://www.ohiocaferacers.com/OCRTubeSizes.pdf
DimitriG is offline   Reply With Quote
Old 09-30-2010, 05:17 AM   #497
Beemerboff
Oddometer: 2,331
They also have a listing on stem bearings.
Airhead bearings are 28mm bore x 52 x16, top and bottom.
52 x 16 mm bearings are also availible in 25 and 30 mm bore , so forks with a combination of 25. 28 or 30 mm bore stem bearing should be a relatively easy swap.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 09-30-2010, 06:12 AM   #498
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
because i'm okay with the rest of the front end, i just wanted more stopping power.
Originally Posted by DimitriG
is there any reason why people are not just replacing the whole front end, wont be that much more expensive from a breakers yard, then you get the handling benefit and chop the springs to your needs. i know honda and suzuki use the same headset sizes (am i wrong?).
bmwblake is offline   Reply With Quote
Old 10-01-2010, 11:38 PM   #499
peterman
cop magnet
peterman's Avatar
Oddometer: 13,820
I got a Nissin 4 pot from and older Katana 600, milled the tabs on the mounting ears, made a couple of the adapter/link thingies,and everything looks good so far. I will need another brake line as mine is a different fitting on the bottom end than the Nissin.
Does anyone have a good source for replacement seals for the calipers? The one I have has been sitting for a long time, and probably needs new squeezy rings inside.
thanks for any info,,
peterman
___________________________
"Your God, your rules,,YOU go burn in hell!" LLV
peterman is offline   Reply With Quote
Old 10-07-2010, 09:10 AM   #500
cK75
Oddometer: 15
Does anyone know if this caliper is suitable for a R100GS with the Nissin caliper adapter? Its a Kawasaki ZX6/ZX9 left caliper
cK75 is offline   Reply With Quote
Old 10-07-2010, 09:27 AM   #501
bmwblake
upside down parker
bmwblake's Avatar
Oddometer: 3,274
it will, but you'll have to tap the threads on one of the caliper mounts to get the correct thread pitch needed to mate to the adapter.
you can see it here on my bike.
Old 10-07-2010, 02:48 PM   #502
Beemerboff
Oddometer: 2,331
Mine went straight on using the HPM link.
My local Super Cheap auto parts store had Galfer hh pads at half the price of Ebc s and they work well with the original disk.
Old 10-09-2010, 10:17 AM   #503
cK75
Oddometer: 15
After reading the complete thread I have a doubt about getting a better braking in my R100GS PD, I have a bmw 1100 4 pot caliper but should I buy a Nissin 4 pot? Is Nissin 4 pot caliper much better than bmw?
Old 10-09-2010, 04:43 PM   #504
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,008
I doubt the Nissin is stronger, but it does have different sized pistons that theoretically would give you better "feel" (maybe).
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 10-10-2010, 02:11 AM   #505
cK75
Oddometer: 15
Nissin is 30/34 mm and bmw is 32/34 mm, so if they both are similar, I think I must keep using bmw caliper -perhaps with Versah or Galfer green pads- or if I want to spend money, buying a Tokico 6 pot caliper to improve braking, am I right?
Old 03-31-2011, 05:49 PM   #506
Cigars&Scotch
My eyes are up here
Cigars&Scotch's Avatar
Oddometer: 1,850
Reviving an old thread.
Does any one have and adapter they wish to sell. A buddy of mine just picked up a 95PD and is really jealous of my 6 piston setup.
If you ave one on the shelf and want to unload it, please pm me
Mike
"Why don't you buy some flea collars for your ankles so the ants wont climb up you leg and bite your candy ass!!!" Kennyanc 07 H.Springs
38 BMW R71 w/sidecar Kung Fu version
77 BMW R90S Huh ?
90 BMW R100GS/PD "At last!"
NRA Life Member, Trout Unlimited Life Member
Drink till I'm Drunk Life Member
Cigars&Scotch is offline   Reply With Quote
Old 03-31-2011, 06:40 PM   #507
elmontanero
Practicing...
elmontanero's Avatar
Oddometer: 1,866
I've got the HPM Guy one and I"m not using it.. PM'd you.
"And if we have food and covering, with these we shall be content."
elmontanero is offline   Reply With Quote
Old 05-19-2011, 09:11 PM   #508
JMforPres
JMforPres's Avatar
Oddometer: 439
EBC FA188HH Brake Pad
Anybody still watching this thread?
I have installed and love the 6 pot Tokico caliper on my GS. I put Galfer Black pads on (as opposed to Green) to get a longer life out of the pads.
The pads worked well but work out quickly and I want something that will last longer. Anybody have knowledge about the EBC FA188 HH pads? The FA188 (without the HH) have been mentioned in this thread before but not the HH pads. Are they too tough on the rotors? Do they stop well?
Jon
R100GS
R1150GS
R1150RT
77 R100RS
"I picked up a nice burlap thong. It makes me feel pretty." - BluRidgeRider
JMforPres is online now   Reply With Quote
Old 05-19-2011, 11:39 PM   #509
Beemerboff
Oddometer: 2,331
I love EBC HH pads , but not with Brembo disks.
Galfer do a HH rated pad too , which I have found works OK with Brembo disks.
But I aint bought any EBCs for a while , so things may have changed ---.
Old 01-14-2012, 12:47 AM   #510
Padmei
enamoured
Oddometer: 3,718
I've got the nissin callipers & measured the pads. They're between 2.5-2.8 mm deep. Does anyone know the wear limits on them & if they need to be replaced.
Padmei is offline   Reply With Quote
Times are GMT -7.   It's 09:34 PM.
