Old 11-16-2007, 11:37 AM   #76
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,749
I'm interested to see if you like the 6 or the 4 piston more... in my racing circle a few years ago we found we actually got better front brake power and feel from the 4 pot nissan on a friends CBR929 than I could get on my 6 pot GSXR1000 brakes..
The logic was along the lines that with equivalent hydraulic force you are spreading your pressure out 33 percent more on the GSXR1000 brakes so they in fact weren't as sensitive and didn't have as good a feel as the 929's. In fact some guys racing the big gixxer converted them over to 4 pots.
Both setups with steal lines, sintered brake pads etc. .. but I'm sure with the right hydraulic ratios of master cylinders to piston, etc the six could do better.
Mind you with these bikes we were talking about the difference between 2 fingered vs. 3 finger rolling stoppies at 80 mph
Rumor has it the real hot setup now is the 4 pot calipers with 4 individual pads. You get four bite surfaces instead of two, each pad has its own direct piston, and a gap to clean the dust between pistons
Anything's gotta be better than the block of wood my R90 has up front
Old 11-16-2007, 12:04 PM   #77
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Originally Posted by SOLO LOBO
Dude, get with the program and read the first few posts...
Sorry... just too many irons in the fire and I didn't look before I typed. I think stagehand and I are related. toooo fast with the submit button.
datchew is offline   Reply With Quote
Old 11-16-2007, 06:04 PM   #78
lesman
Live easy, Brake Hard
lesman's Avatar
Oddometer: 673
6 Piston Tokico's
I was in a bike shop when I saw a 2005 1200 Bandit. It had twin 6 piston Tokico's. I saw a Hayabusa it had 6 piston Tokico's. Since it appears I got the shaft because I paid high $70 to high $80's for my 2 calipers.
Can we all just get along and end this madness of who has the most piston's in our caliper? FYI if you look at the line on the rotor it(Tokico) definitely has more pad surface than the 4 Piston Brembo. Once again thanks Solo, John the New Zealand guy and Scot Marburger.
Les
lesman is offline   Reply With Quote
Old 11-16-2007, 06:25 PM   #79
Zebedee
Zebedee's Avatar
Oddometer: 833
Originally Posted by lesman
... Can we ... end this madness
No way Les ... this is far too much like fun
I know of at least one other Kiwi who's considering this upgrade ... all I need to do now is to buy up New Zealand's surplus stock of left hand Tokico six pot callipers and I'll be one step closer to my plan for world domination.
Thanks for all the info Guy's
John the pom, in Kiwi land
aka the spring driven thing
The perverse must persevere
Zebedee is offline   Reply With Quote
Old 11-16-2007, 07:03 PM   #80
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
Les
You should go drum brakes man. It's the only way to go.
Old 11-16-2007, 07:35 PM   #81
Geek
oot & aboot
Geek's Avatar
Oddometer: 31,749
My GSXR1000 brakes are the exact same as the 6 piston Haybusa's Tokico's. They were NOT as good as as my CBR race bike's 4 piston brakes were. My R1's brakes fell somewhere in between.
"More brake pad" doesn't mean squat if you don't have the proper hydraulic pressure and feel. If you go bigger on your brake pad without increasing your hydraulic leverage you have LESS braking power due to your psi being distributed over a larger surface area.
What are you guys doing for mastercylinder replacement to match the calipers?
I'm not trying to disagree with anyone here; I need a solution for my R90 and definitely look forward to your experience(s). I'm just mentioning that "bigger isn't always better" when it comes to brakes - which I found out the hard way spending a lot of money on galfer wave rotors, ceramic pads, different diameter lines, etc for a 6 piston system that never came up to par on the stock (+ steel lines) 4 system system on my other bike(s).
p.s. another thing I learned was that I warped my rotors faster with the 6 pistons than the 4 pistons. Dunno why but I'd guess it to do with a larger heat gain with all that contact area?
...that said.. my gixxer's brakes sure were pretty....
Here.. see if you can find the brakes in this photo of it
Old 11-17-2007, 03:36 AM   #82
lesman
lesman's Avatar
Oddometer: 673
Bigger is better because you have 6 piston envy
Stock 2 piston Brembo = My wife's next husband gets my tools because I'm dead.
4 Piston Brembo = I can lead a normal life and perhaps enjoy a little adventure
6 Piston Tokico= I can press my luck ,possible ruin my retirement plans, enjoy adventure and my wife's next husband get my tools because I'm dead.
The choice is pretty clear.
I have enough parts to go to a dual caliper setup....don't make me do it.
Stop the madness
I didn't change my Master Cylinder. I bought a new one. I was leaving for a 3 or 4 day trip and mine started to leak bad. I was running DOT5 and switched back to DOT4. I like DOT 5 but there is a big difference in the feel of the brake lever and stopping. I think there is a 5-10 % increase in braking.A new MC arrived a few days faster than a kit. I haven't looked at MC /caliper ratio chart to see if I could spend anymore money on my brake tragedy. Has any one gone the 320mm rotor route? Can someone explain what could be expected in better braking? The brake upgrade was just hoot to do with all it's permutations. I enjoy doing the upgrades to my GS. Your GSXR came with incredible brakes, 300 to 400 % more hp, fuel injection and a real charging system...incremental increases are costly and underwhelming. My bike stops on a dime with 3 cents change, has great lights and handles like a finely tuned Greyhound bus...I am a happy crack whore.
If the R90 has dual calipers go the 4 piston Brembo route if you are trying to maintain a stock appearance. You will be pleased. I powdercoated my brembo (don't forget the clearcoat on the raised brembo letters) and it's just beautiful The Japanese caliper is just an excellent alternative. I want to point out that I weigh 230+ with gear.
Stock MC's can be bored out , SS sleave installed and I think bigger piston installed.It allows you to use stock switch gear. I think it's pricey $350+
When my bike stops good enough to warp the rotor...I'll wear a thong.
By the way her thumb is on the brakes..right?
Les
lesman screwed with this post 11-17-2007 at 10:06 AM
Old 11-17-2007, 08:21 AM   #83
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
My bike stops on dime with 3 cents change, has great lights and handles like a finely tuned Greyhound bus...I am a happy crack whore.
Les
I think Mugwest has some literary competition now.
That's a quotable quote if ever I saw one.
By the way, will you guys shut up already about the 4-piston being the "just right" setup? I'm trying to get Solo Lobo to slap that 6-piston on there and send me his 4-piston and you guys are gonna screw it all up.
Old 11-17-2007, 08:23 AM   #84
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,008
Man, I love this thread!!!.....
My wife just doesn't understand this adventure rider thing, her loss I guess
Oh, and I have a nice, new, black 46" ss line coming along with the SIX PISTON caliper!
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo screwed with this post 03-04-2008 at 10:10 AM
Solo Lobo is offline   Reply With Quote
Old 11-17-2007, 10:17 AM   #85
lesman
lesman's Avatar
Oddometer: 673
I left the "a" off
Thanks for using my quote. Please add the "a" to stops on a dime part of the quote. This happy crack whore needs an editor. Here's a quote I stole. A guy in the Houston Euroriders drives up on a 1999 1100R. It's just beautiful. I tell him I thought the Mystic was most beautiful naked bike until I saw his bike. He says"I love my naked bikes with big jugs" This is the reason I love my GS...it's got big jugs and 6 piston brakes.
Solo: Where and How much did you pay for your line? I use Spiegler. Custom length, angle of the banjo or not etc. $59.00. They are very nice and aren't judgemental.
Les
Old 11-17-2007, 12:05 PM   #86
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,008
Les
hahahahahahaahahahahahahaah..... LOVE your avitar! hahahahahahahah
My line is an ebay special... $15.99
R65LazaruS
Old 11-17-2007, 12:40 PM   #87
lesman
lesman's Avatar
Oddometer: 673
Other adaptor uses
http://www.advrider.com/forums/showt...=285146&page=2
These bikes are crying for 4 piston Brembo's or 4 piston Nissin's or 6 piston Tokico's
Solo, this is your niche.
Les
Obsessive compulsiveness always trumps good sense.
Old 11-17-2007, 01:36 PM   #88
lesman
lesman's Avatar
Oddometer: 673
Ducati brackets that may fit a Beemer
Checkout this link:
http://www.bevelheaven.com/productinfo.html brackets, master cylinder; new calipers and brake light switches.
Just options
Les
Old 11-17-2007, 03:26 PM   #89
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,213
Please add the "a" to stops on a dime part of the quote. This happy crack whore needs an editor. Les
Les - go back to the post where you wrote that and hit the edit button at the bottom. That will allow you to change the posting.
Wirespokes is online now   Reply With Quote
Old 11-17-2007, 04:14 PM   #90
lesman
lesman's Avatar
Oddometer: 673
I am an editing Crack Whore
It be done.
Les
Times are GMT -7.   It's 10:38 PM.
