Old 12-31-2007, 05:36 AM   #121
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,236
Originally Posted by opposedcyljunkie
another day? i've had too much popcorn already
Virtually speaking?
Old 12-31-2007, 01:27 PM   #122
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,051
So, I just got back from a 30 minute ride aorund town doing a bunch of braking in assorted circumstances. I would note here that I also changed my fork oil from 15wt to 10 wt, and removed the end cap from my right hand fork leg that was partially blocking the new holes drilled for my Racetech cartridge emulators so I did experience a bit more dive (but the front end felt much more plush!). And, I used the pads that came with the caliper and are about 20-30% worn.
So, the first time braking from speed I said to myself "WOW!!" this different then the 4-piston caliper! (and then kept saying the same thing each time I braked)
I would say that the 6 brings more stopping power, with the 4 I had two finger braking with no issues and the 6 brings easier two finger braking for sure
I am thinking that there is less feel, so more braking with less squeezing but less feel as to what the front brake is doing. I think I need to ride some more and do some more research
"punk rocks what it's all about" - J. Strummer
R65LazaruS
So I sold my GS and went shopping for a G/S!
Solo Lobo is offline   Reply With Quote
Old 12-31-2007, 07:03 PM   #123
opposedcyljunkie
Heavyweight Boxer
opposedcyljunkie's Avatar
Oddometer: 4,776
OCJ
92 R100GS-PD Euro
01 Vespa PX150E - sold
05 Yamaha Fazer FZS-1000
07 R1200GS
opposedcyljunkie is offline   Reply With Quote
Old 12-31-2007, 07:41 PM   #124
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
post pics of the skidmarks
datchew is offline   Reply With Quote
Old 01-31-2008, 08:07 AM   #125
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,051
Here is a shot of the new 'six. Still waiting for my driveshaft to return from HPNguy to put on some miles and provide some further assessment!
Oh and no my bike isn't oxidized, that's some left over dust from cutting a few 2x4's recently !
R65LazaruS
Old 01-31-2008, 08:16 AM   #126
elmoreman
takin' a break, boss
elmoreman's Avatar
Oddometer: 1,770
airhead aficionado
elmoreman is offline   Reply With Quote
Old 01-31-2008, 08:18 AM   #127
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,051
where are the photoshp experts when you need them
R65LazaruS
Old 01-31-2008, 09:04 AM   #128
Dharmadon
road warrior
Dharmadon's Avatar
Oddometer: 231
Laugh farkles n stuff
Thanks to all of you here for the great info! I have yet to pick up my
'92 R100 GS (March), but I can see that there will be plenty of Winter tech mods in the Future! Better find a bigger clamp for the wallet!
Thanks again for the info,research, great pics, and some "opinions"...
Liquor & Broadway
Dharmadon is offline   Reply With Quote
Old 01-31-2008, 09:46 AM   #129
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
waiting patiently.
Old 01-31-2008, 06:23 PM   #130
lesman
Live easy, Brake Hard
lesman's Avatar
Oddometer: 705
That's a good looking 6 piston baby!
Solo,
As a proud parent of a 6 piston caliper...I can say you have a strapping little
6 pistoner.
Les
Obsessive compulsiveness always trumps good sense.
lesman is offline   Reply With Quote
Old 03-04-2008, 12:25 AM   #131
johno
johno's Avatar
Oddometer: 2,912
Just put a 4spot Nissin on my GSPD, with 46" hose.
Having a heap of trouble bleeding it. Nothing is moving.
Had to give up and come to work. What a bummer.
I will continue tommorrow and see if I can fix this issue.
johno is offline   Reply With Quote
Old 03-04-2008, 01:42 AM   #132
The Cougar
Barry Dawson's Twin
The Cougar's Avatar
Oddometer: 457
Come on Ian!!
Come on Ian, I'm counting on you to get this one right for us boys down south. Let me know how you go b4 I start source a 4 spot.
The Cougar is offline   Reply With Quote
Old 03-04-2008, 03:46 AM   #133
johno
johno's Avatar
Oddometer: 2,912
I will have another go tommorrow before I start work. Just run out of time today. Had to get a tap for one of the threads in the adaptor, then get a hose made up.
Now I need more fluid( brake that is )
Off Thurs, and Friday, so should have it under control by the weekend.
Hope my shocker turns up by then as well.
I will keep you informed Scotty.
Old 03-04-2008, 08:01 AM   #134
Solo Lobo OP
airhead or nothing
Solo Lobo's Avatar
Oddometer: 9,051
The trick to bleeding these suckers is to remove the caliper from the fork, hold it so the bleed nipple is straight up and wail on the caliper with a rubber mallet to move the air bubbles up to the bleed nipple, then reinstall, bleed as normal and repeat.
When I did the 6-piston, I slowly filled the caliper through the bleed screw hole (with the verticle) very slowly and let it sit for a day or two and then put is on the bike. I also filled the brake line off of the bike as well....
Keep at it, it is a serious chore to get done but worth it!
R65LazaruS
Old 03-04-2008, 09:33 AM   #135
datchew
Don't buy from Brad
datchew's Avatar
Oddometer: 7,409
I'm dying to know if you really needed the 46" hose or if you have an armlength of extra coiled up in the handlebars somewhere.
I've assembled and measured 5 times on my 89 GS and even with the acerbis rally pro guards and the steel transfer brakeline removed, I can't come up with measurements showing that I need anything more than 37" of brakeline.
Times are GMT -7.   It's 07:26 PM.
