Old 10-19-2014, 11:04 PM   #1
herman maire OP
Oddometer: 164
R80GS instrument cluster. Would it fit on R100GS
Hello,
I have a 1992 R100GS project bike. Would a R80GS instrument cluster fit? I have removed all the R100GS fairing, windshield and instrument gauges that are incorporated into the R100GS fairing.
Is there any other options for a instrument cluster set up.
Does anybody know of where I could find a R80GS cluster. I have looked for a while on ebay with no luck.
Thank you
R100GS
R75/7
KTM 950 ( slowly looking)
herman maire is offline   Reply With Quote
Old 10-19-2014, 11:18 PM   #2
Padmei
enamoured
Oddometer: 3,604
Ditch the stock stuff & just get a Trailtech vapour or vector or if you wanted to spend more money get an acewell unit.
Padmei is offline   Reply With Quote
Old 10-19-2014, 11:35 PM   #3
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,182
Yes, you could go back to the 88-89 R100GS set up. But be aware that you'd need to modify or replaced the wiring loom to do so (the 91+ loom is longer in that area).
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is online now   Reply With Quote
Old 10-20-2014, 01:05 AM   #4
Beemerboff
Oddometer: 2,305
Moorespeed has a instrument set up that actually works on airheads as supplied , comes with fitting instructions, and is serviceable, with good spare parts availability, should they ever be needed. You will still need a headlamp / faring set up, but they are not hard to find as long as you dont mind ugly/costly, Boxxerparts and BMWBOXERSUPPLIES? have them.
Adelaide Hills, Australia. 93 R100 GS, 77 R75/7 ,70 BSA B44VS, , 86 R80 G/S PD, 95 BMW Funduro F650 ST
Beemerboff is offline   Reply With Quote
Old 10-22-2014, 01:24 PM   #5
herman maire OP
Oddometer: 164
Thank you all for the reply.
Does anybody know of any early 88-89 GS instrument and headlight assembly's that are available.
Another ADV member sent me a link to one on ebay but its over
640U.S$ for a old sun faded part.
too expensive .....
thanks again.
R100GS
R75/7
Old 10-23-2014, 12:57 AM   #6
Wirespokes
Beemerholics Anonymous
Wirespokes's Avatar
Oddometer: 8,079
The early GS headlight/gauges were the same as the R80G/S, but with one difference - speedo ratio. The G/S normally came with a 3.36 final drive and the 100GS came with a 3.09.
Times are GMT -7.   It's 09:36 PM.
