Old 12-21-2011, 02:40 PM   #1
fattyjr OP
Oddometer: 3
2001 husqvarna SM610 HELP please
Hello,
This is a bit long winded, but thought best to give you all the info on what I have done.
I just purchased a 01 Husqvarna SM610s with supermoto and enduro wheels. Purchased as a project bike as it was hard/none starting bike. It has had the original catalytic converter exhaust removed and and renthal silencer installed
Guy I purchased the bike off ran the bike a few months then it started acting up. He took it to a husqvarna dealer and they talked him in to refreshing the engine which they did. He picked up the bike, rode it home and filled it with gas. Parked it up for a few days and went to start it again and nothing.
So he spoke to another husky dealer and they suggested a new CDI unit which seemed to cure it for a few weeks. Sat for a few days and NOTHING. So he decided to take the carb off and clean it. Put it back on and left it.
This is where I came in. Guy got sick and tired of it, with his job as a paramedic, he got no time to play/repair. So he put in on ebay and I got suckered.
Went and fetched it and was methodical with my approach. Checked fuel and fuel was fresh, Fuel was getting to the carb. Pulled the spark plug and checked for a spark. Had a spark but it was very weak (bearly visible). Replaced the coil, plug and cap for new as cheap option.
I spent 2hrs looking for the relevant specs for the stator etc and found the exciter coil was out of spec. Was giving a ohm reading close to spec, but output voltage during cranking was 4.8v. Sent the stator off for repair. Came back 3 days later and installed. Getting a better spark but could be better so tested voltage again from stator and got 18 - 20v during cranking. Voltage out to coil was 16v, so concluded the CDI is faulty.
Priced up a NEW cdi from husqvarna and had a heart attack. Managed to get one at a reasonable price from someone in europe but gonna take time to come so I decided to have a play.
I purchased a dirt cheap cdi off a Lifan 150 which is an 8 pin cdi and a wiring harness (just for the cdi plug). I cut the plugs off my OEM cdi and grafted them to the lifan plug then plugged in the CDI. Crossed my fingers and hit the start button. NICE BIG BLUE SPARK.
So put spark plug back in engine, coupled every thing up and sprayed a little brake cleaner in the the mouth of the carb to see if we could get any life out the beast. Hit the starter and got life straight away. So put the radiators back on and fuel tank. Coupled it up, pulled the choke and cranked it and it fire up straight away. Tried tickling the carb to get it to run without choke, but I am basically pissing into the wind at the moment as I don't know if the guy has messed with the settings.
So to my question, Does anyone have a basic OEM setup for the carb that I can start with and move from there???
On top of this, I just brought another husky a TE610, Stolen/recovered but in excellent condition
fattyjr is offline   Reply With Quote
Old 12-22-2011, 04:03 AM   #2
fattyjr OP
Oddometer: 3
Another question,
Does anyone other than husqvarna supply replacement plastics for these bikes??? , Looks like some berk broke the plastics and didn't have them repairs, they just chopped them off.
Old 12-22-2011, 06:59 AM   #3
IheartmyNx
Ihave2draft
IheartmyNx's Avatar
Oddometer: 3,858
http://www.dcvmx.com/xcart/product.p...cat=442&page=1
Everyday IS 3/11!
Everybody's always talking out the side of their mouths about our "dependency on foreign oil", what about our dependency on cheap china crap? Who exactly again is killing our dollar?
IheartmyNx is offline   Reply With Quote
Old 12-22-2011, 11:51 AM   #4
kpt4321
kpt4321's Avatar
Oddometer: 1,674
Hall's has parts diagrams that will tell you what all of the OEM jet sizes are:
https://www.halls-cycles.com/Catalog...Husqvarna.aspx
For a 2001 610 SMR, it says 175 main, 62 idle, K32 needle.
For the newer bikes, the JD jet kits are fairly good. You may want to investigate if they make one for your year/model.
TAT 2008 / Colorado 2010
"Both the man of science and the man of action live always at the edge of mystery, surrounded by it." -Oppenheimer
2007 Monster S2R / 2006 TE610 / 1999 KDX 200 / 2000 DRZ-E
kpt4321 is offline   Reply With Quote
Old 01-08-2012, 02:55 AM   #5
fattyjr OP
Oddometer: 3
Well I have tried everything with his carb. What I am really getting cheesed off with is when your on the over run / deceleration, This bike is popping and banging. But also I can't seem to get a happy medium with the settings.
So having read about all the information available for the keihin carbs, I managed to pic up a fairly new keihin FCR 40mm off a 05 yzf450 SM for a great price I think 90 (about $125-130) I will probably be getting in contact with JD for a jet kit, Saves me having to mess about from a stand point.
Old 02-12-2013, 12:43 PM   #6
R1husky
Oddometer: 2
CDI Unit
Sorry to reply to such an old post but I read your write up on using the lifan 150 cdi unit.I to have purchased these items to hopefully overcome a starting problem I have.Would you or can you remember what colour wires went where when you swapped the original plug onto the lifan cdi unit. I have a manual but the wires are different colours to what I have even though it's the correct year manual useless Italians lol.Any help would be greatly appreciated.
Many Thanks Steve
R1husky is offline   Reply With Quote
Times are GMT -7.   It's 03:00 AM.
