12-22-2011, 06:05 AM
#1 |
/5 dirt road wannabe
Oddometer: 342
A little airhead help, please
So I've got a 1972 R75/5 in my little shop and I'm close to getting it road worthy; it was only running on one cylinder when I picked it up due to an over bent float tab. A complete Bing overhaul kit cured the neglect. It does seem that the starter struggles to spin the motor over, quickly draining the 18ah eBay gel battery below it's ability to spin the starter. Common? Would a dedicated ground line to the motor help significantly?
Odo shows 36K miles but it can't be confirmed it's the original gauge. I have removed more oil/tar build up from this motor unit than I have ever seen on a bike and there's still a lot more to go. I have managed to rotate out all of the fluids, set valves and points gap and set the timing; thanks to Jeff Trapp for the cool tools. And, I have attempted to wade through Snowbum's epic site but the yellow background and mulit-colored font makes that an exercise in patience and I can only take it in small chunks before my bifocals mist up. Good information trapped in a hard to read website. But I digress...
12-22-2011, 06:17 AM
#2 | |
Further...
Oddometer: 5,146
Starter problems on an airhead common? Yep. Could be a number of things: the bushing on the starter may be worn causing the starter to draw excess current. The cables may be corroded causing the same. The battery may be weak. You can start by confirming a healthy battery. Then measure voltage drop along the cables, pull the starter and check it's readiness. Others will pipe in with ideas. Just remember that it's a system so there's no single silver bullet and there may be multiple issues. More pics. |
12-22-2011, 07:23 AM
#3 |
Scope Creep's Victim
Oddometer: 2,214
Fred '85 R80RT G/Sified '91 R100GS Bumblebee Airhead Zen: Ride-Maintain-Repair-Ride On. |
12-22-2011, 07:47 AM
#4 |
Oddometer: 342
That's next in line for reconditioning. It's a mid 80's British Coach Works replicar on a Chevette platform; one of maybe as many as 50 made for Schweppe's as a contest prize. I got lucky finding this one. They built the body onto the completed platform and I've got some cutting and fab-ing to commission to replace the transmission mount. Should be loads of fun when it's done. The BCW guys were pretty thorough as all of the MG repop parts will fit the body so it can really be made to look authentic.
the core bike: ![]() new fenders from 7 Metal West, will have to massage the rear to fit so it looks right: ![]() ![]() going to be a scrambler-esque bike like way back in the day when you changed out tires, fenders and handlebars and crushed your low hanging exhaust running dirt roads and fire trails. oldroadie screwed with this post 12-22-2011 at 07:55 AM |
12-22-2011, 08:22 AM
#5 |
ShadeTreeExpert
Oddometer: 5,020
The starters can be rebuilt. Kits available, a brush kit and an everything else kit but I don't know if the bushing is part of that. I just looked a a parts picture, looks like the bushing is in the everything else kit.
You have the 8 tooth starter. Later starters, starting in '81 I think, are 9 tooth. The two don't mix or interchange. Used starters also available. People who rebuild them if you don't want to do it yourself but they are a fairly easy to do with a little patience. Extra ground wires are sometimes a benefit but the stock wiring should not be the problem if in good clean shape.
Never memorize something you can look up. ---Albert Einstein |
12-22-2011, 09:49 AM
#7 | |
Oddometer: 342
Here's a look at the bike when I picked it up in back in Feb:
oldroadie screwed with this post 12-22-2011 at 09:58 AM |
12-22-2011, 09:51 AM
#8 |
the thread-killer
Oddometer: 4,297
the 9 tooth starter started with the 1977 model year bikes.
The bushings are sold separately, the front nose bushing is the most common to wear and is pretty easy to replace. It's amazing how much better that starter works when it has a fresh bushing. |
12-22-2011, 11:09 AM
#9 | |
combustophile
Oddometer: 1,559
nice tutorial here: http://www.thisoldtractor.com/gtbender/print/moto_guzzi_loopframe_electrical_starter_and_soleno id_repair_-bosch-.htm
"If you want to fix it with a rock, you have to stick to stone-age technology" -Anton "...solving the latest crisis that is preventing my Airhead from taking me to the bar." -Beater- |
12-22-2011, 11:31 AM
#10 |
Coyote's Brother
Oddometer: 3,299
If the ground wire is going to the frame, someone moved it. AFAIK, all of the stock ones go to the trans case. What I'd do is add a ground wire that goes to the stock position, service the starter and see what happens.
By the way, Those SWB Toasters Tank /5 are getting to be pretty rare, so take good care of that bike and keep whatever parts you strip off of it. Someone might want to return it to stock some day!
Hawkdude Hate rots the pocket that carries it. |
12-22-2011, 11:55 AM
#11 | |
Oddometer: 342
just tape and blocks holding the mock up in place, got some angled spacers to make so it all sits square.
12-22-2011, 12:26 PM
#12 |
Coyote's Brother
Oddometer: 3,299
Oh...! OK!
![]() I had to go back and look at a couple of photos to understand how you constructed your muffler. Thats some good thinking! Please remember to report back let us know how it works.
12-22-2011, 03:51 PM
#13 |
Oddometer: 342
Thanks, I didn't really construct anything; I cut off 4 or 5 inches including the flared end and then had the stub expanded at my local muffler shop so that off-the-shelf Supertrapp end would fit snugly. Some RTV and a bolt secure the tuning disc end and I added the off-the-shelf heat shield so it doesn't cook the final drive. With the kit's full set of 12 discs it's already much quieter than the old pipe while retaining a nice throaty growl. Ought to make final A/F tuning fun.
12-22-2011, 07:45 PM
#14 |
Oddometer: 1,465
Even at it's best, a /5 starter is rather wimpy. A really good battery-Odyseys come to mind- will make the most of it. You might also find a /6 starter (another .1 horsepower) and rebuild that. There should be a lot of them around, too.
It seems to me that Robert VV looked into putting a /5 starter drive on a /7 starter, but I can't remember if that worked out. |
12-22-2011, 09:38 PM
#15 |
Tinaversal
While the Snowbum site has plenty of good information, it's almost impenetrable, which really reduces its usefulness for many.
IMHO. Fuck Cancer. Ride bikes. - dave + tina |
