Old 12-22-2011, 11:18 AM   #1
Beater OP
Scope Creep's Victim
Beater's Avatar
Oddometer: 2,199
Paralever Driveshaft
Has anyone had experience with these?
http://www.ebay.com/itm/BMW-Motorcyc...item20c01f8d8c
And if so ... what's the good /bad, etc? I have a new driveshaft in my 91, but it will eventually fail, and just doing a bit o' research.
As always, Thanks in Advance ...
Fred
'85 R80RT G/Sified
'91 R100GS Bumblebee
Airhead Zen: Ride-Maintain-Repair-Ride On.
Beater is offline   Reply With Quote
Old 12-22-2011, 12:58 PM   #2
grteacher
Oddometer: 45
I also would like to have some info about that !
Look's just the way it sould be but.... is it so ?
grteacher is offline   Reply With Quote
Old 12-22-2011, 01:08 PM   #3
Beater OP
Beater's Avatar
Oddometer: 2,199
There is a facebook group about his Airhead Club in Australia ... and anyway the guy is a hoot (good thing!). He doesn't have a lot of literature about it, but he claims that they last about 200 Km, and then you 'wack' in a new set of CV joints and new rubber kush cartridges, and you're good for another 200 Km. At half the cost of a new shaft (installed) ... it might be the way to go.
Facebook Club: http://www.facebook.com/#!/groups/Ai...0563518021073/
I have no idea about shipping ... and I have no idea if it's real ... but it seems like a great thing if it is ...
Fred
'85 R80RT G/Sified
Old 12-22-2011, 01:59 PM   #4
jackd
Oddometer: 2,367
There's a whole other thread on this unit from last summer - suggest you go there and start reading.
Old 12-22-2011, 02:28 PM   #5
lockyv7
dont wish it, do it.
lockyv7's Avatar
Location: Sunshine Coast Australia, There is no winter here.
Oddometer: 940
Send a message via MSN to lockyv7
I knew i had seen them before, there in an add for Ted Porters Beemer Shop Scotts Valley CA.
The add is in the BMW-ON for $579.00 with one year warranty
i dont see it in the latest issue but its in others.
Cheers Locky.
lockyv7 is offline   Reply With Quote
Old 12-22-2011, 07:52 PM   #6
darklight79
RAD WASTE
Oddometer: 260
yep running one now in my gs .... buy it from ted porter nice unit well put togtether when i changed mine it wasnt that u joints were toast> they were ok .. it was out of phase ..I noticed quite a difference in ride after the change out smoother etc ... and lubable bite the bullet Order it ....from Ted
darklight79 is offline   Reply With Quote
Old 12-22-2011, 08:06 PM   #7
bmwrench
Oddometer: 1,459
The BeemerShop is supposed to have exclusive rights to distribution of these 'shafts in the US. Looks like Ted is charging a fair price for them.
bmwrench is offline   Reply With Quote
Old 12-22-2011, 08:08 PM   #8
Stagehand
+/- V TDSPP
Stagehand's Avatar
Oddometer: 19,849
I've also got one in right now. Seems to be holding up fair well.
What to do... What to do...
Stagehand is offline   Reply With Quote
Old 12-22-2011, 08:51 PM   #9
supershaft
because I can
Oddometer: 6,047
I think we have seen one shredded here on ADVR but that doesn't mean they all do that.
supershaft is online now   Reply With Quote
Old 12-22-2011, 09:16 PM   #10
jackd
Oddometer: 2,367
That wasn't one of these. That was one of the HPM rebuilt units. From what I remember, the suspected cause of the failure was contamination of the cush drive by the leaks from the final drive. This failure was very rare - he puts out a good product.
Old 12-22-2011, 10:11 PM   #11
fishkens
Further...
Oddometer: 5,146
Yeah, mine's out of phase right now (check out the angle of the u-joint at the front that bolts to the tranny on the right).
Smoother, eh? That'd be a plus in addition to some peace-of-mind as this shaft is going on 60K (the one on the left crapped out at ~30K).
fishkens is offline   Reply With Quote
Old 12-23-2011, 02:46 AM   #12
grteacher
Oddometer: 45
They can be found in Europe also !
The thing is to know if they last , at least longer than the original ! Mine was gone at 30000 km. The second one is still good , so far....
How many miles on your aftermarket ?
Old 12-23-2011, 01:29 PM   #13
supershaft
because I can
Oddometer: 6,047
Thanks, I thought they were one and the same. Are they designed different? Since the final drive input seals leak on a very regular basis, I hope they are fairly oil resistant.
Old 12-23-2011, 01:46 PM   #14
Velocipede
Velocipede's Avatar
Oddometer: 313
So what am I supposd to see here?Is the four bolt flange on the end supposed to line up with the universal.
If Stagehand gives the aftermarket driveshft the thumbs up given the way he beats the living daylights out of his GSPD then it should be fine for bikes ridden by the average rider.
John
Velocipede is offline   Reply With Quote
Old 12-23-2011, 01:47 PM   #15
mykill
odd
mykill's Avatar
Oddometer: 1,092
The original driveshaft on my GS looked much like the one on the right but worse. My whole swingarm was filled with Hypoid when I got it and the rubber was swollen and oozing out of the shaft. The shaft was also about a 1/4 turn out of phase. I'm running an HPM now which is filled with a firmer (polyurethane) material that is similar to skateboard wheels. My output shaft and FD have all been resealed, but I hope it is more oil resistant regardless.
Never underestimate the laxative properties of motorcycling.
mykill is offline   Reply With Quote
Times are GMT -7.   It's 10:06 PM.
