Old 12-23-2011, 05:37 AM   #1
Chillis OP
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,097
2 stroke chambered silencer quiet?
I have a performance exhaust for my scooter but it's a bit loud. Is it possible to make a silencer that is chambered to cut down on the dB's and stop the need for repacking?
Chillis is offline   Reply With Quote
Old 12-23-2011, 05:52 AM   #2
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Two stroke exhaust is a science. Much more so than 4 stroke. The "Expansion chamber" portion is critical, size and shape, to scavenge the spent exhaust gasses. Like everything, it's a compromise, low end power, mid range, top end, etc. After all that takes place, the "stinger" or exit pipe must not be restricted (if you want to retain all that scavenging, power making goodness) so a straight through, glass packed silencer is a better choice than none at all. As for a metal, baffled muffler, it'll most likely kill the power gains from the performance pipe... UNLESS it can be be made L A R G E and unrestrictive, usually not feasable on a bike. So, to answer the original Q, not really, if you want quiet, put the stock pipe back on and sell the race pipe. Corking up the (scooter?) race pipe will negate the benefits... and more.
concours screwed with this post 12-23-2011 at 06:18 AM
Old 12-23-2011, 06:12 AM   #3
Chillis OP
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,097
It is a 2 stroke and running the stock restrictive exhaust makes for a boring powerband.
The stock muffler is considerably quieter though.
Old 12-23-2011, 06:20 AM   #4
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
Duh, you had it in the title, my dumb. 50cc? bigger? Variator stock? My advice is just get a bigger engine, way cheaper than modding a weenie one. But, I understand the draw to extract just a wee bit more....
Old 12-23-2011, 06:36 AM   #5
Chillis OP
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,097
I may go with a bigger engine down the line but right now I have the performance exhaust. It was quiet when I got it but after 2,000 miles it talks a little bit on the loud side. When people start turning heads, it's too loud. Heads are turning.
Old 12-23-2011, 06:45 AM   #6
speedracertdi
speedracertdi's Avatar
Oddometer: 985
Maybe it's time to repack the muffler?
Roads? Where we're going we don't need roads.
-Doc Brown
speedracertdi is offline   Reply With Quote
Old 12-23-2011, 06:47 AM   #7
Chillis OP
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,097
I know but I don't want this to be an every couple of months maintenance.
Old 12-23-2011, 03:06 PM   #8
concours
WFO for 41 years
concours's Avatar
Oddometer: 5,415
It's the price you pay to ride a race replica. Use packing designed for it.. http://www.faster-motocross.com/fmf-...r-packing.html
Old 12-23-2011, 05:22 PM   #9
Switchblade315
Switchblade315's Avatar
Oddometer: 5,789
repacking is a once a year thing if you ride it alot. do it right and you might get more.
When I die bury me upside down so the whole world can kiss my ass.
"My mind jumped off the high dive into the deep end of the gutter and took scuba gear with it" Me.
Switchblade315 is offline   Reply With Quote
Old 12-24-2011, 06:36 PM   #10
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 983
Original packing in glass-pac mufflers is often crappy right out of the box,
so it quickly fails. The solution I've used is fire rope wound tightly around the
muffler core with any excess packed into leftover space in the housing.
Fire rope is sold by the foot in wood stove stores, and comes in many
diameters.
Last time I used 5/8", tied to the ends of the core with stainless
wire.....It lasts much longer than loose blanket-type repacking. It took
30 feet to pack a V&H muffler on a Buell, yours would take much less.
CycleDoc59 is offline   Reply With Quote
Old 12-25-2011, 08:28 PM   #11
svejkovat
svejkovat's Avatar
Oddometer: 856
There are many 2 stroke mufflers that are chambered and without packing. You might even have tossed one out when you added a performance muffler. You could just strap that on the back of your performance pipe, but it may be too restricted at this point (i'm not at all technically competent to guess). Maybe a similar style of aftermarket OEM muffler designed for a larger displacement scooter than yours?
I don't know why more of this type isn't available to top off a performance "expansion" pipe. Guess the performance parts developers have already decided for us that anyone who wants more performance automatically wants that performance to be accompanied by noise to prove to everyone around that it's now faster. Ok, so that's true for 99 percent of us. Personally, I'm with you on this one.
I'm really a big fan of QUIET. Not quite electric bike quiet, but I just happen to think quiet power is cool. A simple glass packed muffler is just the least expensive method of only barely taming the noise of a small engine. But some two strokes are extremely quiet. It's really not that difficult to come up with a quieter muffler at the end. The muffler above is CAD designed, hemholtz chambered, mass produced high tech. But you can strap on a muffler from a small car as well. I've seen this. It's pretty quiet. It's bulky. It's ugly looking. But at Autozone prices it can be really cheap. Probably not what you had in mind.
If you look up aftermarket mufflers for utility engines, small generators meant to be used in suburban confines and state camping sites for instance, they often have a series of coned baffles. Kind of like this....
It's interesting that if you google diy silencers for firearms, or even look up cutaway images of commercial silencer design for firearms, there are similarities to the above concept. Firearm silencers really need to be compact and effective. They also can suffer from the same exhaust buildup/contamination over time that 2 stroke engines do. That's gonna be a problem regardless of whether you have fiberglass packing or not. Two stroke residues will build up quickly (condensing on relatively colder metal similar to the way humidity will on a cold window) so that at this colder end of your exhaust, no matter how you construct it, you'll end up needing to 'decarb' it at some point. Maybe you could fiber wrap it to raise the internal operating temp? That would help a bit.
svejkovat screwed with this post 12-25-2011 at 08:45 PM
svejkovat is offline   Reply With Quote
Old 12-26-2011, 03:49 PM   #12
Chillis OP
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,097
diameters.
I like this idea and will go in search of it although wood stove stores are few and far between in the desert!
I like the idea of the gun type noise suppressor. I don't have the where with all to make one and I bet they are expensive
I tried the stock exhaust but it really flattens the powerband. I will put up with the excess noise until I get this thing repacked.
Old 12-26-2011, 03:55 PM   #13
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 983
Oh...well, just go on line. "fire rope" is better called "stove gasket rope":
http://www.woodlanddirect.com/Wood-S...-Repair-Gasket
Old 12-26-2011, 04:14 PM   #14
Chillis OP
Land Barge Pilot
Chillis's Avatar
Oddometer: 4,097
Did you just wind it around the core like winding it up evenly or wound around in a single layer on the core and with the free space just stuff the rest in not too tight but not loose?
Old 12-26-2011, 05:07 PM   #15
CycleDoc59
Wrench Rider
CycleDoc59's Avatar
Oddometer: 983
It should be tied to the core at one end, then wound as tightly as possible
the length of the core, then cut/tied at that end. Any remaining space when
the core is reinstalled in the shell should be packed with remaining fire rope.
Or, depending on what size rope is selected, a second layer may be wound
around the core.
Pressure pulses and heat quickly destroy original and most replacement
packings, since it is fairly loose.
It might be a little tricky with small-core mufflers, but a way to quieten them is to make
and install turbulators. Here's a link to a picture:
http://www.fuelefficiencyllc.com/feturb.html This one is shown for a boiler, but
the principal is the same; without decrease of flow much, they force some of the
gasses out into the packing. A turbulator can also be made as a spiral. The length
can be varied to get the effect needed. Staintune sells then for the mufflers they make,
and calls them "restrictors": http://www.staintune.com.au/faq4.htm
Contrary to reducing performance, a certain amount of restriction in exhaust systems
can enhance power curves. As indicated in an earlier post, proper exhaust design is
critical for 2-stroke engines, and not unimportant for 4 strokes. Noise does not make
vehicles faster.
Times are GMT -7.   It's 06:03 PM.
