Old 04-08-2005, 08:03 AM   #1
Velocibiker OP
Adventure Antagonist
Velocibiker's Avatar
Oddometer: 1,164
More power from KTM Adventure
Not more HP, more VOLTS!
Max output for my Adventure is 200W. A GS 650 pumps out 400W(!!!!)
The stator is already wound up as much as it's going to go. Anybody know of a way to get more juice flowing? I'd like at least another 100W.
Then I could stop thinking about LED retrofitting and HID lighting....
Currently bikeless.
Velocibiker is offline   Reply With Quote
Old 04-08-2005, 08:34 AM   #2
ChrisC
Amal sex?
ChrisC's Avatar
Oddometer: 6,316
Chris
1974 Bultaco Sherpa T 350
1943 BSA M20WD
ChrisC is offline   Reply With Quote
Old 04-08-2005, 08:56 AM   #3
Velocibiker OP
Oddometer: 1,164
Originally Posted by ChrisC
Already tried that!!! Doesn't work too well on the single track
I was thinking I might strap a Honda generator to the rear rack, but it's too noisy.
Currently bikeless.
Old 04-08-2005, 09:18 AM   #4
Jim Bud
Jim Bud's Avatar
Oddometer: 3,439
Bicycle generator rubbing against the wheel???
Jim Bud
"Nearly all men can stand adversity, but if you want to test a man's character......give him power".....Abraham Lincoln
Jim Bud is offline   Reply With Quote
Old 04-08-2005, 09:34 AM   #5
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
You are screwed Velo... no room for more windings. What you want to power up anyway... yer' house?
So... how's tricks?
creeper is offline   Reply With Quote
Old 04-08-2005, 10:09 AM   #6
AusieRob
Just Gas It!!
AusieRob's Avatar
Oddometer: 377
Well you can get around a 25% increase in electrical efficiency by replacing the stator wiring with these new high temp super conductors. You'd have to install a small cryogenic plant on the back to keep the stator cold. And I mean cold...
I'm guessing, but I think you'd have to step up the main jet just a couple given the colder operating conditions
Oh yeah, and don't drop the bike. The engine cases are likley to shatter like glass. Just awarning
"And then I asked myself, 'What would God do in this situation?'"
"Locusts...." :uhhuh
AusieRob is offline   Reply With Quote
Old 04-08-2005, 10:11 AM   #7
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
What we talkin' here?... 'bout $20... $30 bucks?
So... how's tricks?
Old 04-08-2005, 10:15 AM   #8
AusieRob
Just Gas It!!
AusieRob's Avatar
Oddometer: 377
Yeah about that.
Well, that's after the Stanford Uni research grant and a couple of Military development grants.
Your out of pocket? around $30
Old 04-08-2005, 10:17 AM   #9
creeper
Still alive...
creeper's Avatar
Oddometer: 10,718
Yeah about that.
Can't get 'er down to $25 huh?
So... how's tricks?
Old 04-08-2005, 10:20 AM   #10
Buckster
Buckster's Avatar
Oddometer: 1,003
Acouple of small wind generators under the fairing and a solar panel should get you 30 to 40w, after that you are on your own.
Buckster is offline   Reply With Quote
Old 04-12-2005, 09:17 AM   #11
Velocibiker OP
Oddometer: 1,164
Geez......You guys just trying to up your post counts?
I was really hoping for some actual ideas. A serious answer to a valid question.
I asked a similar question when my bike was new and basically there were no options. Now, 3 years or so later, I was hoping some of you might have heard to seen something new. Obviously not.
Currently bikeless.
Old 04-12-2005, 09:27 AM   #12
Loadedagain
making chips
Loadedagain's Avatar
Oddometer: 26,732
** iba - 22936 *** Alcan5000 - 2006, 2008, 2012, 2014 ***
Stenhouse Racing - Specializing in KTM Upgrades
custom cnc service available to suit your specific needs.
Loadedagain is offline   Reply With Quote
Old 04-12-2005, 09:39 AM   #13
AusieRob
Just Gas It!!
AusieRob's Avatar
Oddometer: 377
As far as we know, not one is making an aftermarket item with higher output.
- You could try hand winding the coils. Careful selection of conductor size and precision winding may get a few more mAs out of it.
- Redesign the whole thing, closer tolerances, highest quality components, again some improvement to output.
- Change the elect starter for a second generator. Mod the gear drive to provide constant drive to the gen. That'd be good for a few extra volts...
But basically you are trying to break the law. The law of diminishing returns!
Mate, if there was a serious answer to your valid question you would have gotten it along with the 90% BS (is that the correct ratio?) and stuff.
Enjoy it, it all good ...
Old 04-12-2005, 09:58 AM   #14
potatoho
Cheese and Rice!
potatoho's Avatar
Oddometer: 4,703
I thought you could just use stronger magnets on the flywheel
http://ktmtalk.com/index.php?showtop...26&hl=flywheel
http://www.trailtech.net/flywheel_1.htm
"All Trail Tech flywheels have high strength magnets which boost the stator output by 30-50%."
potatoho is offline   Reply With Quote
Old 04-12-2005, 12:36 PM   #15
AusieRob
Just Gas It!!
AusieRob's Avatar
Oddometer: 377
Ok, Yes that is what is meant by better quality components but up to 50% by magnet alone, errr hard to imagine, very hard. I think we need to read the whole quote "can boost the output of your lighting coils up to 30%-50% (when combined with a rewound stator)" Arr... Yes!! now that'll work....
But these flywheels are for RFS engines? I'm out of my depth now. Are RFS's the same as LC4's in the electrical part? And do the RFS engines have the same stock power output (as fully wound) as the LC4 Adv engines? ie so the increase will be the same for the LC4 as the RFS.
Times are GMT -7.   It's 03:38 AM.
