Old 07-05-2014, 02:09 AM   #1081
Strey1100
Oddometer: 35
Problem
Originally Posted by The Toad View Post
The switched power wire does indeed trigger the relay. Full 12V is required. Connecting it directly to the battery is an option as far as testing goes, but leaving it there means that your lights can be triggered by anyone, anytime - with our with the key/ignition on.
-Brian
Your suggestion fixed the problem. The 12V supply I was using, did not carry quite enough amps to activate the relay. Connecting it to the battery did the trick. However, as you said, that was a temp fix to see what the issue was. When I get home, I'll need to find a good switched power source to make it work properly. Thanks again
Strey1100 is offline   Reply With Quote
Old 07-05-2014, 02:29 PM   #1082
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,147
Thanks for the update.
Let me know what bike you have, I can probably direct you to a good switched power point.
-Brian
MondoMotos - LED Auxiliary Light Kits - Tusk Panniers
RoadRUNNER Magazine - Blog
Ride Reports - Four Corners - Amish Country - Costa Rica - Expedition Michigan (or not) - Tellico Plains
The Toad is offline   Reply With Quote
Old 07-06-2014, 09:28 PM   #1083
chrishsu
Oddometer: 501
I have a BMW S1000RR and currently using the PIAA 1100X Xtreme mounted to the same fender bolt location. Both the PIAA bulbs just went out again for the 2nd time in 2 years! I'm tired of buying new bulbs at $30 each! Do you have the "universal" hardware kit mentioned in your post yet?
Also, is the MM10 smaller or larger than the PIAA 1100X Xtreme http://www.piaalights.com/details.ph...XTREME%20WHITE
One (good) choice for a location is using the lower fender bolt.
Most likely there is a 6M screw in that location and a standoff/washers/longer bolt would needed to bolt right up.
FWIW - we are modifying our hardware kit to make it "universal" - meaning it will work to mount the MM10's in this location on many bikes.
thanks,
-Brian
Chris
12 S1000RR
09 K1300S
05 R1200GS
04 DR650SE
chrishsu is offline   Reply With Quote
Old 07-07-2014, 05:16 AM   #1084
MilSpecXC
Oddometer: 86
I'm attempting to purchase the MM10 with the 800XC mounting hardware, but you're out of stock. When do you expect to have availability?
Thanks.
MilSpecXC is online now   Reply With Quote
Old 07-07-2014, 06:53 AM   #1085
propforward
PIE!romaniac
propforward's Avatar
Oddometer: 12,531
Just ordered another set to put on my new to me ST1300.
First pair on my Tiger are still awesome.
It's not a man purse, it's called a satchel.
Indiana Jones wears one.
propforward is offline   Reply With Quote
Old 07-07-2014, 03:19 PM   #1086
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,147
Vibration's are no friend to Halogen bulbs thats for sure.
We should have the mounting kits together in a couple days.
Thanks,
-Brian
Old 07-07-2014, 03:21 PM   #1087
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,147
Thanks.
Kits are being put together this week. It will allow mounting on the 800 either up high, or down low on the forks.
Thanks,
-Brian
Old 07-07-2014, 03:23 PM   #1088
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,147
Thanks for the repeat business
Like to see some pics once you get them mounted on the ST.
-Brian
Old 07-07-2014, 03:29 PM   #1089
chrishsu
Oddometer: 501
Would you please let us know when they're ready?
Thanks,
-Brian
Chris
12 S1000RR
09 K1300S
05 R1200GS
04 DR650SE
Old 07-09-2014, 11:28 AM   #1090
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,147
The universal hardware kits are now ready to go.
Bear in mind - the hardware kit is NOT required to mount the MM10 lights. It does provide components that help in mounting them. Particularly useful for mounting the lights low on the forks (replaces OEM reflectors, fender bolts, etc). It also includes the needed bits to mount the lights alongside the headlight on the Tiger 800.
Thanks,
-Brian
Old 07-09-2014, 03:44 PM   #1091
chrishsu
Oddometer: 501
My S1000RR uses M5x14 fillsiter head screws in the lower fender where I would like to mount these lights. So I probably won't need the "Universal hardware kit"? So will the MM10K2 kit be all I need to order?
Thanks,
-Brian
Chris
12 S1000RR
09 K1300S
05 R1200GS
04 DR650SE
Old 07-09-2014, 05:03 PM   #1092
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,147
M5? Good to know.
It is hard for me to say without having the bike in the shop, I believe the screws are countersunk - that may require either a slightly longer screw/bolt and/or spacer to run through the lights mounting bracket. However it may not. In either case, once you have the lights in your hand you can determine if either is needed. A decent hardware store (bog box) should have it.
Thanks,
-Brian
Old 07-09-2014, 07:07 PM   #1093
chrishsu
Oddometer: 501
I just placed an order on a MM10 kit without the universal hardware kit.
M5? Good to know.
Thanks,
-Brian
Chris
12 S1000RR
09 K1300S
05 R1200GS
04 DR650SE
Old 07-10-2014, 06:22 PM   #1094
Pescador
Pescador's Avatar
Oddometer: 86
Hi, Is there any coupon codes for members at this time.
Seconds or scratch and dent?
Thanks, Bret
MM10's
Pescador is offline   Reply With Quote
Old 07-10-2014, 09:11 PM   #1095
The Toad OP
Let There Be Light
The Toad's Avatar
Oddometer: 1,147
Thanks, Bret
MM10's
Bret,
use code ADV10 at checkout - gets you 10% off the price of the MM10 light kit.
thanks,
-Brian
Times are GMT -7.   It's 08:10 AM.
