Old 12-29-2011, 07:48 AM   #16
photomd
photomd's Avatar
Oddometer: 744
I have the Enduralast system. I've had in on the bike since 07...I think. Since my airhead is my winter bike, it runs Dual Star grips and a heated jacket that the stock system couldn't handle. I run about 100w extra in accessories daily. Within the first year the R/R took a dump. The fella at Enduralast wanted me to run some simple test (gotta know how to test diodes) and he sent me a replacement within a week: good service. It's been very reliable since.
I also run a stock Bosch system on my Guzzi. I never run any extras and it keeps an AGM battery well charged. IMHO, everyone says Rick has great service. My point is pick the system that fits your needs. I think they're all good, but these bikes are getting old and need attention to stay reliable: the connections have to be clean, good grounds and wiring in good shape. As long as everything is in good shape and not overloaded, they'll all keep your battery charged.
1979 V-1000SP
1988 R100RS
1996 R1100RSL
1998 CR250
photomd is offline   Reply With Quote
Old 12-29-2011, 09:10 AM   #17
Rob Farmer
Rob Farmer's Avatar
Oddometer: 5,877
Electrex in the UK make a high quality item
http://www.electrexworld.co.uk/cgi-b...500#aSTK_2d500
Rob Farmer is offline   Reply With Quote
Old 12-29-2011, 11:24 AM   #18
Uncle Pollo
happy cachiporra
Uncle Pollo's Avatar
Oddometer: 48,541
Great.
Now I will be polishing the motor for the rest of our lives.
Uncle Pollo is offline   Reply With Quote
Old 12-29-2011, 04:43 PM   #19
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 626
Crap!
Originally Posted by Stagehand View Post
I think one issue with the Omega is that if the rotor blows, you cant just swap in a stock rotor. I mean it will fit, but it wont charge. It will keep the front seal from leaking to have a rotor on there though.
also, I will corroborate everything Ignatz mentions. I have an Omega system on mine, and Rick is only a phone call (and some USPS) away. His system works really well when its maintained like the stick system should be. Watch out for dirty connections.
Well, you've thrown a monkey wrench in an otherwise perfect plan, Stage. Thanks a LOT!
I guess the choice is less clear-cut in an emergency failure situation now, except you could still replace a faulty VR or diode board in a pinch with the Omega. I've already got the ME 14.2 VR, and Rick's diode board in the kit is supposed to *never* fail, so... that would leave the stator or brushes as possible weak points of the Omega. With the Enduralast it sounds like the only real possible weak link is the rectifier.
I suppose the final decision lies in how much juice you need and at what RPM, then you dance with the one you paid for.
I think I'm still a bit partial to the Omega...
Current: 93 R100GS, 03 XR650R
Prior: 73 CB350, 77 R100/7, 83 R100RT, 04 XR650L
I love every motorcycle I've owned and even some that I haven't.
ignatz72 is offline   Reply With Quote
Old 12-29-2011, 04:53 PM   #20
ignatz72
call me iggy
ignatz72's Avatar
Oddometer: 626
Looks like an Enduralast to me...
Old 12-30-2011, 07:40 AM   #21
photomd
photomd's Avatar
Oddometer: 744
Laugh
Originally Posted by PolloAsesino View Post
Great.
You say that like it's a bad thing.
1979 V-1000SP
1988 R100RS
1996 R1100RSL
1998 CR250
Old 12-30-2011, 08:09 AM   #22
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,530
My 2c:
Every car manufacturer uses the energized rotor alternator. This is the industry standard. Early 1960's Japanese bikes used and currently Ducati uses a magnet spinning in a stator alternator. Enduralast is a retrofitted Ducati system.
Rotors fail. Carry a spare. Ever tired to get an Enduralast Rectifier/Regulator whilst broken down in Podunk?
The Omega/Emerald Isle system is simply what the Bosch system should have evolved into by the /7 models. Nothing mysterious, just a slightly larger rotor, slightly different windings.
Why is charging at 1500 rpm important? How often to you ride at that RPM? Or need extensive charging at idle?
I have 150K miles on the stock Bosch system and 30K on the Omega without failure.
FWIW.
'73 R60/5 Toaster
Old 12-30-2011, 09:07 AM   #23
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,210
Honestly I need charging down that low. But I'm just one guy
Unintentional psychokinesis.
Stagehand is online now   Reply With Quote
Old 12-30-2011, 09:18 AM   #24
BobLoblaw
Comfortably Numb
BobLoblaw's Avatar
Oddometer: 1,507
Originally Posted by Bill Harris View Post
My 2c:
FWIW.
Not everbody wants to carry a lump of steel and wire with them every trip. And, if you have a 400w Omega system the rotor is NLA.
Ride till you can't - Marty Hill
BobLoblaw is offline   Reply With Quote
Old 12-30-2011, 09:21 AM   #25
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 27,210
A spare rotor is usually only a day or two away from almost anywhere, so you can get by, and possibly enjoy the scenery for an extra day. THere are ways around not charging.
Old 12-30-2011, 04:45 PM   #26
mattcfish
R90SS/6
mattcfish's Avatar
Oddometer: 272
EME...It charges when you idle, love it.
I modified mine a little. Yes, aftermarket ignitions can work with it. Now EME has there own version of a crank mounted ignition.
mattcfish is offline   Reply With Quote
Old 12-30-2011, 06:56 PM   #27
Hawk Medicine
Coyote's Brother
Oddometer: 3,304
Aha!
An Omega electronic ignition!
I've been running one of those for a couple years now and I really like it but unfortunately, they're no longer being manufactured.
I'd sure like to have a spare, so if you run across one for sale let me know, cause if I had an extra, the original one would last forever!
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine is offline   Reply With Quote
Old 12-30-2011, 11:49 PM   #28
fabiox
fabiox's Avatar
Oddometer: 203
Enduralast
+1
installed in 2006
most city ride (NYC) 30.000 miles
no problems so far
Odyssey yeah
ride to live
live to ride
ride to ride
fabiox is offline   Reply With Quote
Old 12-31-2011, 01:21 AM   #29
oz_airhead
Oddometer: 204
You forgot one!
As well as the Enduralast, Omega, Electrex, you also have Silent Hektik:
Rough translation via Google:
http://bit.ly/uasKrj
Ignition to suit:
http://bit.ly/spVwbl
(Note: Monoblock is for a kickstarter system, Powerblock is for non-kicker bikes.)
I am looking at one of these ignitions/Alternators myself; or the Enduralast/Eduraspark combination.
Cheers
OZ
oz_airhead is offline   Reply With Quote
Old 12-31-2011, 08:42 AM   #30
fishkens
Further...
Oddometer: 5,162
Let's have another look at this pretty photo...
Originally Posted by blaine.hale View Post
fishkens is offline   Reply With Quote
Times are GMT -7.   It's 04:49 PM.
