Adventure Rider
Welcome, lurker!   Even if you don't post, the system can help you find the good stuff faster if you register.
Register Members Pics Search Today's Posts Mark Forums Read
Old 04-09-2005, 04:06 PM   #1
Taki
Waiting for Godot
Taki's Avatar
Oddometer: 901
Garmin 276c help please
I have a 276c that has worked flawlessly until today when the PC suddenly did not recognize the gps. The com ports are configured the same as always, so I reinstalled the usb drivers. No luck. Then I ran the Mapsource software and plugged the unit into a different computer to see if the usb was working properly on the pc or the gps. The Mapsource software on a different pc still did not find the gps. I figured it might be the cable so I switched cables. Same problem. In sum, I have installed the latest software from Garmin, uninstalled, reinstalled, (drivers too) ran an old version on another pc, and changed cables.
My guess is the software inside the GPS is buggered, but I have no way to access the unit since the com ports dont seem to work.
Am I missing something? Any advice is greatly appreciated.
Taki
No matter where you go, there you are
Taki is offline   Reply With Quote
Old 04-09-2005, 04:15 PM   #2
Drif10
Accredited Jackass
Drif10's Avatar
Oddometer: 33,711
Taki
Did you try resetting the unit?
Been there. Done that. Fuck that.
Unattended children will be served espresso and given a puppy.
Carpe the living shit out of the diem - Roscowgo
Drif10 is offline   Reply With Quote
Old 04-09-2005, 04:22 PM   #3
Taki
Waiting for Godot
Taki's Avatar
Oddometer: 901
To the factory settings? Yes. Is there another way perhaps?
Old 04-09-2005, 10:37 PM   #4
edwyun
edwyun's Avatar
Oddometer: 149
I had a similar problem when i upgraded to software version 3.20 and the USB drivers.
I can't remember but after fiddling with some files and updating them, it now works.
You should speak to someone at Garmin to help you out.
HTH
Ride Safe,
Edward
'72 Ducati 750GT
'98 Ducati 900 SS/FE
IBA#18798
www.geocities.com/edwyun/index.html
edwyun is offline   Reply With Quote
Old 04-10-2005, 09:01 AM   #5
Bradley
Oddometer: 49
Drivers
Make sure you load the newest garmin USB drivers off the Garmin website.
Bradley is offline   Reply With Quote
Old 04-10-2005, 10:23 AM   #6
DangerMoney
Loud Helmets Save Lives
DangerMoney's Avatar
Location: Mesa, Arizona, USA, Earth, Milky Way, Local Group
Oddometer: 920
Check the communications protocol that the 276 is set to. It should be "Garmin". The Mapsource software is trying to talk Garmin protocol and if the 276 is set to something else (like NMEA), the two won't communicate.
'04 K1200RS
'05 R1200GS
'07 950SE-R
Originally Posted by Stevie2wheels
Even so I wouldn't sit there like a shag on a rock, waiting to be punched up the arse into next week by the next negligent drongo who happens to come along.
DangerMoney is offline   Reply With Quote
Old 04-10-2005, 12:18 PM   #7
Taki
Waiting for Godot
Taki's Avatar
Oddometer: 901
My best guess so far is the Gps unit is not "broadcasting" its connection to the pc properly, or the Mapsource drivers are not working properly so they dont recogize the gps.
My problem is I have already updated the software on the pc and the gps to the latest versions therefore, when I update the drivers the wizard tells me that I have the latest drivers. So I uninstalled all the software and reinstalled everything with the same problem. The only software that I am unable to alter is the software in the gps unit because I am unable to establish a connection. I have also tried the gps unit on another computer that has all the old versions of Mapsource, same problem. The usb cable has been eliminated as a culprit.
I hope Garmin has a solution because I have wasted too much time guessing and really want to use the unit next weekend so I'd hate to ship it back and wait if the problem is solvable.
Thanks for all the input so far
Old 04-10-2005, 12:21 PM   #8
Taki
Waiting for Godot
Taki's Avatar
Oddometer: 901
Protocall is set to Garmin Data Transfer in the Serial Data Format window
In the Transfer Mode window I have it set to Host
Old 04-10-2005, 04:17 PM   #9
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 2,934
Do you have XP SP2 ?
You could try uninstalling SP2 :)
Lot of problems with lots of hardware and software with this 'upgrade'
www.rockymoto.com.au
Parts and accessories for your adventure bike
BurnieM is offline   Reply With Quote
Old 04-10-2005, 10:53 PM   #10
BlitzBike
LC4 Pilot
BlitzBike's Avatar
Oddometer: 812
[quote=Taki]I have a 276c that has worked flawlessly until today when the PC suddenly did not recognize the gps. The com ports are configured the same as always, so I reinstalled the usb drivers. No luck. Then I ran the Mapsource software and plugged the unit into a different computer to see if the usb was working properly on the pc or the gps. The Mapsource software on a different pc still did not find the gps. I figured it might be the cable so I switched cables. Same problem. In sum, I have installed the latest software from Garmin, uninstalled, reinstalled, (drivers too) ran an old version on another pc, and changed cables.
Thanks [quote}
I have just encountered this same problem but, I am not enough of a techno geek to offer any real insight as to causes or solutions.
Computer does not recognize GPS.
BlitzBike
BlitzBike is offline   Reply With Quote
Old 04-10-2005, 11:16 PM   #11
BurnieM
Nipple boy
BurnieM's Avatar
Oddometer: 2,934
I loaded v3.20 as soon as it came out and everything is working fine.
I am running Mapsource v6.5 and Windows 2000 Pro SP4
Old 04-11-2005, 04:05 AM   #12
Taki
Waiting for Godot
Taki's Avatar
Oddometer: 901
Same setup as you, worked for about a month flawlessly, the while I was preparing to download a route it suddenly couldnt find the GPS.
When I speak with Garmin I'll post the diagnosis.
Old 04-11-2005, 05:28 AM   #13
BigDogAdventures.com
Fart Letter
BigDogAdventures.com's Avatar
Oddometer: 2,115
Hi Taki,
I was gone all weekend---but my wife said you had left a message---boy you are having some problems. I don't have any suggestions other than the ones others have given you. Sounds like the unit needs repaired--bummer. I've had about 6 Garmin units and never a problem--and I have beaten them up badly.
Mark Sampson
Click here for BigDogs full length DVD movies
http://bigdogadventures.com/Video.htm
www.bigdogadventures.com
Why in the heck did you buy a 250 ?? "Because they were all out of 175's"
"He who dies with the biggest gas tank--wins" !
"The less the merrier"
"I'm so old, I don't even buy green bananas"--Quote: Jimmy Dickens
"The older I get--the bigger my rear sprocket gets"
"Don't follow me--you won't make it"!!!
BigDogAdventures.com is offline   Reply With Quote
Old 04-11-2005, 09:48 AM   #14
Taki
Waiting for Godot
Taki's Avatar
Oddometer: 901
Originally Posted by BigDogAdventures.com
Hi Taki,
From the looks of the files you sent me I believe your units were thoroughly field tested. The good news is I was able to get the waypoints in before the problem, so I have to look for the route myself. Not so bad. I'll send the unit back after the trip.
Old 04-11-2005, 12:56 PM   #15
stevenknapp
stevenknapp's Avatar
Oddometer: 1,214
Send a message via Yahoo to stevenknapp
This may sound stupid, but have you powered the GPS off/on while connected to the PC? Mine gets like this sometimes and power cycling the GPS often gets it to connect.
Also does the GPS say "USB connected" at the bottom of the screen?
stevenknapp is offline   Reply With Quote
vB code is On
Times are GMT -7.   It's 10:12 PM.
Powered by vBulletin Version 3.5.2
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Copyright ADVrider 2007
