Old 01-02-2012, 04:22 AM   #1
The Fonz OP
The Fonz's Avatar
Oddometer: 69
15W 40 oil and the Cold
I recently changed my oil to Delo 400 15w 40 and was wondering how well it does on cold start ups? Should I have any concerns for cold starts with a 15w oil on cold mornings?
I ride year round and the coldest it gets here is about 15F. It usually is in the high 20s or low 30s in the mornings. My concern is that the oil may be too thick in the mornings (or after a long day sitting outside at work) for a cold start with the choke running the RPMs up. Will this oil provide adequate protection for this temperature?
Any thoughts, opinions, or experiences would be appreciated.
If it has two wheels, I'm in trouble,
The Fonz
Alaska Ride 2012: http://okiemom6.blogspot.com/
http://www.thefonz.whereamiriding.com
The Fonz is offline   Reply With Quote
Old 01-02-2012, 05:14 AM   #2
hugemoth
hugemoth's Avatar
Oddometer: 2,073
What does your owners manual say? I use 5/40 during the winter but that may not be right for your bike.
Old 01-02-2012, 05:40 AM   #3
kpt4321
kpt4321's Avatar
Oddometer: 1,665
Oil weight should be chosen based on the weight/temperature chart in most bike's owner's manual. Look there.
15W is thicker than is usually recommended for 15F, but it's impossible to say if it will be a problem or not.
I know I wouldn't use that oil for those conditions unless the owner's manual specifically asked for it.
TAT 2008 / Colorado 2010
"Both the man of science and the man of action live always at the edge of mystery, surrounded by it." -Oppenheimer
2007 Monster S2R / 2006 TE610 / 1999 KDX 200 / 2000 DRZ-E
kpt4321 is offline   Reply With Quote
Old 01-02-2012, 05:56 AM   #4
greywolf
Unpaved road avoider
greywolf's Avatar
Oddometer: 888
15W is okay down to about 6F. It can be more resistant to cold cranking above that is all.
Pat
in order of ownership
1971 Honda CB350, 2 1973 Honda CB500s, one was stolen, 1974 Can-Am 175 TNT, 1978 Yamaha XS11, 1978 Honda CX500, 1975 BMW R90S, 1983 BMW R65LS, 2005 Suzuki DL650 totaled, 2007 Suzuki DL650A, 2012 Suzuki DL650A
greywolf is offline   Reply With Quote
Old 01-02-2012, 06:44 AM   #5
LuciferMutt
Rides slow bike slow
LuciferMutt's Avatar
Oddometer: 9,504
Look in the owner's manual. You'll find a chart with a bar graph showing which weight covers what temperature ranges -- one will be adequate for almost all temperatures you're going to encounter and chances are good it's 10W-40 unless your bike is aircooled.
You'll be OK with 15W but it's not ideal for temps under freezing.
You couldn't hear a dump truck driving through a nitro glycerin plant!
Cobbie Award Winner
LuciferMutt is offline   Reply With Quote
Old 01-02-2012, 06:55 AM   #6
DockingPilot
Hooked Up and Hard Over
DockingPilot's Avatar
Oddometer: 7,437
Listen to your cold engine on start up. She will tell you weather she likes it or not.
Frank Reinbold
"Every bike I ever had, was the best bike I ever had, when I had it"
*2010 FOREVER WEST*
NEW ENGLAND AND CANADA OFFROAD F800GS
14 DAY IDAHO ADVENTURE KTM 950
TRANS AM TRAIL WEST
TRANS AM TRAIL VID CLIP
THE DEAN OF WESTERN ADVENTURE ROUTES
DockingPilot is offline   Reply With Quote
Old 01-02-2012, 07:25 AM   #7
ragtoplvr
Oddometer: 4,539
if you are talking about the gold wing in your profile, then 15W40 will not damage the engine. It will be slower to crank and feel a bit stiff. With the torque of the gold wing you may never notice If you have something different then update your profile.
If you want a better cold oil use the 5W40 synthetic Rotella.
Rod
ragtoplvr is offline   Reply With Quote
Old 01-02-2012, 07:51 AM   #8
The Fonz OP
The Fonz's Avatar
Oddometer: 69
Thanks guys,
It is the Goldwing. I'll leave it in and listen to the motor on start up. I have been running the Rotella 5w40 for quite a few years but recently read about the Delo 400 LE oil. I figured I would give it a try.
So far it is has been a night and day difference. The Delo seems to make shifting so much smoother, it has been like riding a completely different bike. I just have not had any starts below freezing yet.
I appreciate your help.
The Fonz
Times are GMT -7.   It's 11:04 PM.
