Old 02-23-2015, 08:24 PM   #1
DiabloADV OP
Semi-Occasional
Oddometer: 2,313
Shifter options 90/6
I've rebuilt a /5 and a G/S, and this /6 motor came out of a G/S frame. So...I realize I don't have a shifter for a /6 five speed. The fiche shows a few different things... A simple lever that replaces this thing, and some other setups. Can somebody give me a quick picture guide/advice to the options here?
1974 R90/6 motor w/1050 kit; twin plugged; installed in...1970 R60/5 frame; RM125 front end; KZ1000 Police Tank.
DiabloADV is offline   Reply With Quote
Old 02-24-2015, 12:42 AM   #2
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,551
I think this is everything to make the linkage work that trans is set up for. It uses the extra foot peg as shown.
This is the shifter than originally was on a /6/
Sorry th pics are so large.
---Albert Einstein
disston is online now   Reply With Quote
Old 02-24-2015, 11:29 AM   #3
DiabloADV OP
Semi-Occasional
Oddometer: 2,313
I think that top one only works with later frames, that have a footpeg mounting point on the frame, back at the curve. My frame doesn't have that...I have to mount a footpeg on the rear engine mounting bolt, ala the /5 bikes.
Old 02-24-2015, 11:40 AM   #4
chasbmw
Oddometer: 2,259
I don't think that the linked gearchange did much good, it wasn't until they lightened the flywheel that gear hanging really improved
Charles
1971 Commando Fastback
Old 02-24-2015, 11:46 AM   #5
DiabloADV OP
Semi-Occasional
Oddometer: 2,313
Well, since every pic I can find of a 90/6 has the standard fixed gear lever, I'm going to find one of those.
Old 02-24-2015, 02:46 PM   #6
PaulRS
Dutch fool
Oddometer: 806
Early /6
Later /6
Just look at the shifters and don't get confused by the rest.
On the first pic you see an /6 engine and box in a /2 frame from my old hack, a rh footpeg mounted lh, to be able to shift in winter, wearing Sorel boots.
Second pic shows a lenghtened and lowered peg on my DS Beemer.
Paul.
Geht net, gibbet net.
PaulRS is offline   Reply With Quote
Old 02-24-2015, 03:42 PM   #7
Jake
crustacean
Oddometer: 29
'76 R90/6
'00 RT
'76 R90/6
Jake is offline   Reply With Quote
Old 02-24-2015, 05:40 PM   #8
beemerphile
beemerphile's Avatar
Oddometer: 1,905
The adjustable ball-end turnbuckle style is helpful if you have big clodhoppers or if you ever wear heavy boots. The non-adjustable linkage style is the worst of the bunch.
ΜOΛΩΝ ΛΑΒΕ - Lee
Unreconstructed Southerner living in Occupied Georgia
beemerphile is offline   Reply With Quote
Old 02-24-2015, 05:57 PM   #9
DiabloADV OP
Semi-Occasional
Oddometer: 2,313
Originally Posted by PaulRS View Post
Later /6
Paul.
Ah. I get it now. Need a different type peg to use the linkage type.
Times are GMT -7.   It's 02:55 PM.
