10-06-2012, 01:14 PM
#61 |
Destination Unknown.
Oddometer: 117
Thanks for posting those pics Prutser, the gap between the spring and tyre is very reassuring. PhreakyPhil's figure of a 25mm offset for the 2.50"x17" makes the likelihood of the 2.50"x18" working out based on the space I have between the swingarm and my 18"x4.00" rear with a tourance fitted.
Thanks for all the help !
DRz100 GSPD Daithi screwed with this post 10-06-2012 at 01:27 PM |
10-06-2012, 01:42 PM
#62 |
In need of repair
Oddometer: 1,430
Also has the Boxer Supplies (Matt Beckers) shortened torque arm to change the angle of the FD & raise the back end.
10-06-2012, 01:48 PM
#63 |
Oddometer: 117
How much shorter is the torque arm than standard ?
DRz100 GSPD Daithi screwed with this post 10-06-2012 at 02:20 PM |
10-06-2012, 03:53 PM
#64 | |
Oddometer: 505
I don't know at what length the new owner is using it now.Its adjustable. I did take of some of the exhaust to keep the tire from touching it with the 17" rim using the torque arm.
BMW R100'91/R80'93/R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920 R100GS'91 (sold) |
11-28-2012, 05:31 PM
#65 | |
Oddometer: 117
BTW, 18" rim and 1100 hub are gone to Hagon for lacing with the 25mm offset.
DRz100 GSPD |
11-28-2012, 06:46 PM
#66 |
In need of repair
Oddometer: 1,430
AFAIK the shortened torgue arm is to gain height from rotating the FD around the pivot. Don't know what impact it has in the Universal Joint nr the FD. Prutser might be able to answer that.If/when I do this I'll be looking to put in the aftermarket driveshaft so that I can service the U-joints.
11-29-2012, 02:10 AM
#67 | |
Oddometer: 505
11-29-2012, 02:27 AM
#68 |
Oddometer: 2,523
what a project!
Bringing BMW R90S back to life, R80G/S, LiFePO4 testing Which is more reliable ... Points or Electronic Ignition for Airheads? |
12-04-2012, 01:11 PM
#69 |
Oddometer: 117
I have an adjustable torque arm (BELOW) awaiting collection, and the wheel should be with me middle of next week.
![]() I've two questions, ......the final drive kicks upwards relative to the drive shaft, shortening the torque arm will raise the rear end which is the main reason I'm fitting it, but it should straighten the final drive joint which should make it less prone to failure, d'ye think this would is this the case ?? .....Box'a'Bits, I saw a photo on here (BELOW) where the torque arm was bolted to a mount welded to the swingarm, it was correctly suggested the weld could tear out of the swingarm if the load was to great which would be bad, but what was the benefit supposed to be ?
DRz100 GSPD Daithi screwed with this post 12-09-2012 at 11:05 AM |
12-04-2012, 02:30 PM
#70 | |
Oddometer: 505
What tire size are you planning to use ?
12-04-2012, 02:39 PM
#71 |
More tacos than you
Oddometer: 5,097
As a paralever newb still learning the perils and pitfalls of paralever use, I'd be concerned by the fact that these shortened torque arms severely change the angles of the U-joints in relation to one another. These u joints are phased so that they cancel each others' vibrations when they are both operating at similar angles. If one joint is nearly straight and the other is at an angle, then that will result in vibration and axial loading that was not intended by whoever designed this abomination of a driveline. I've been reading up way too much on drivelines trying to eliminate a nasty vibration on my pickup with a 2 piece shaft w/ carrier bearing getting pinion angle and midshaft angle out of the trans within a degree of right. It's been interesting.
R80ST Gets The HPN Treatment Ducati Pantah 500SL Rebuild Seattle to TDF on an airhead WTB R100R Mystic sidestand and mount. |
12-05-2012, 09:46 AM
#72 |
Oddometer: 117
Hi Prutser, based on what you suggested I'll go with 120/90-18 Michelin Comp 3 and a 90/90-21 Comp 4 in the front. Can't wait.
I won't be going extreme with shortening this, just a small bit to raise the arse end of the bike and maybe straighten the FD out a bit, thanks for the heads-up though.
DRz100 GSPD Daithi screwed with this post 12-05-2012 at 09:58 AM |
12-05-2012, 10:40 AM
#73 | |
Oddometer: 505
12-05-2012, 10:53 AM
#74 |
In need of repair
Oddometer: 1,430
Unfortunately I don't have an answer to that. The photo was one I collected sometime ago, & I do not now have details on where it came from. My guess is that the person was seeking to have a straight drive shaft (single u-joint) without needing to go down the monolever conversion route. But there is no sign that the shaft then became 'an oil in shaft' swingarm, so whether he/she achieved what they were seeking from this... don't know.
12-05-2012, 08:50 PM
#75 | |
Oddometer: 1,175
I will have to wait until I get our DR home so I can measure. ( picking it up tomorrow )
