Old 12-28-2012, 05:29 PM   #106
Daithi OP
Destination Unknown.
Daithi's Avatar
Oddometer: 177
Originally Posted by Prutser View Post
Did you take the bike for a spin yet?
Hi Prutser, went for a fairly handy spin yesterday, the PD behaved brilliantly with no glitches.
This is the best thing I could have done with the bike, massive bottom end, plenty
of grip, infinitely better suspension and brakes that work even when wet.
There's a few of us heading out to the same place on the 30th and I hope to test it
a little more, but so far so good.
CCM404 & DRz1000
Daithi screwed with this post 12-29-2012 at 02:43 AM
Daithi is offline   Reply With Quote
Old 12-29-2012, 06:42 AM   #107
tdrrally
tdrrally's Avatar
Oddometer: 3,422
very nice
1996 Dr350se 1997 DR350se
1980 TS125 project in the corner 2002 Drz250k2 i miss that bike
tdrrally is online now   Reply With Quote
Old 12-29-2012, 09:23 AM   #108
Prutser
Prutser's Avatar
Oddometer: 1,030
What's next
BMW R100'91/R80'93/R75/6 R80ST'83/R65GS'87/GasGasTXT300/DouglasW20-1920
Ride Report 2012
Prutser is offline   Reply With Quote
Old 12-29-2012, 12:40 PM   #109
Beater
The Bavarian Butcher
Beater's Avatar
Oddometer: 3,527
Bravo.
I love mine too. The DRZ forks are huge and beefy. They are a 10x upgrade from the stock.
Fred <|> Need an Airhead Part? .... I May Have It!
'85 BMW R80RT G/Sified <|> '73 BMW R75/5 LWB <|> '94 MZ Silver Star Hack
Beater is offline   Reply With Quote
Old 12-30-2012, 06:03 PM   #110
Daithi OP
Daithi's Avatar
Oddometer: 177
Originally Posted by Beater View Post
Bravo.
I agree, makes the bike way more usable. My DRz400 hasn't seen the light of day in more than a week ! :)
DRZ1000GS
CCM404 & DRz1000
Daithi screwed with this post 01-02-2013 at 03:49 AM
Old 12-30-2012, 08:17 PM   #111
Stagehand
Imperfectionist
Stagehand's Avatar
Oddometer: 26,977
very cool <--
Unintentional psychokinesis.
Stagehand is offline   Reply With Quote
Old 01-02-2013, 03:52 AM   #112
Daithi OP
Daithi's Avatar
Oddometer: 177
What's next
Not much apart from 50mm bar risers, the exhaust Y-piece, and the bashplate to protect the y-piece, FD Vent mod, top shock mounting re-location, Battery-box rotation, permanent GPS fitting, Vacuum moulded HPN Tank protector, Kill-switch, front brake light switch, choke lever, double check driveshaft phasing, seal carb vents, time to enjoy it now.
CCM404 & DRz1000
Old 01-02-2013, 12:16 PM   #113
Phreaky Phil
Oddometer: 1,885
Top shock mount relocation ?
Phreaky Phil is offline   Reply With Quote
Old 01-02-2013, 05:55 PM   #114
Daithi OP
Daithi's Avatar
Oddometer: 177
Hi Phil, it was Prutser pointed out the shorter torque arm causes the bottom cup of the shock to impact the swing arm, moving the mount point back gives additional ground clearance combined with more travel. I will cut out the two mounting plates/gussets and weld in two new wider and stronger ones which will allow the top eye to be 50mm further back.
That's the thought, in a nutshell, the shock hits, the back of the bike is too low, etc....
If I'm wrong then 5 minutes will revert it. What d'ya think. ??????
CCM404 & DRz1000
Daithi screwed with this post 01-02-2013 at 06:04 PM
Old 01-02-2013, 06:15 PM   #115
Phreaky Phil
Oddometer: 1,885
Like the rear shock in this one
with the shortened arm, what happens to the rear joint angle when the shock is in the compressed position. ?
Old 01-02-2013, 06:37 PM   #116
Daithi OP
Daithi's Avatar
Oddometer: 177
Thumb
The shorter torque arm causes the FD to pivot down around the pivot bearing, this puts tension or reduces compression on the shock, moving the top mounting point counteracts this. I can't see any real downsides, it's something I can try out and revert if needs be, your photo above is exactly it, is that HPN or BMW ?
Edit: By the way, I've only shortened the torque arm by 10-15mm.
CCM404 & DRz1000
Daithi screwed with this post 01-02-2013 at 06:42 PM
Old 01-02-2013, 06:44 PM   #117
Airhead Wrangler
Adios Mexico
Airhead Wrangler's Avatar
Oddometer: 6,571
That's one of Matt Beeker's bikes I think - the guy that runs BMWboxersupplies.com aka boxertoko
R80ST Gets The HPN Treatment
Seattle to TDF on an airhead
Old 01-02-2013, 06:46 PM   #118
Phreaky Phil
Oddometer: 1,885
Its one of Matt Beekers creations. Very cool bike !
Old 01-02-2013, 07:22 PM   #119
Box'a'bits
In need of repair
Box'a'bits's Avatar
Oddometer: 2,361
I think (speculate) that the laser cut strap running down to the bottom subframe mount is also important to brace the extension & to triangulate that area.
My '91 R100GS thread is here
My Ride photos are here
Box'a'bits is offline   Reply With Quote
Old 01-02-2013, 07:39 PM   #120
Phreaky Phil
Oddometer: 1,885
I would put money on that Not that i've got any to put on it.! Must work as it has done a Dakar Rallye
Times are GMT -7.   It's 11:58 AM.
