Old 01-20-2014, 10:20 AM   #196
Falconfixer
It is what it is....
Oddometer: 570
Originally Posted by Black Hills View Post
My local bearing house built me one for $17. Used it for 15,000+ miles with no problems.
17 bucks sounds even better to me. I've thought about having the local hydro hose shop build me one. And now that I know what size the thread pitch is on the drain plug, I'll ask to have them give me a price on it.
Falconfixer is offline   Reply With Quote
Old 01-20-2014, 10:40 AM   #197
Black Hills
Oddometer: 1,206
I just took the plug when I did an oil change and had them put a fitting on one end and picked out a metric sized plug for the other end. Took about 15 minutes.
Black Hills is offline   Reply With Quote
Old 12-30-2014, 09:31 AM   #198
Jailor8
Jailor8's Avatar
Oddometer: 2,443
I just found a 90 degree fitting with the oil tank threads on one end and flare on the other. The tank side has a o ring and nut so the fitting can be set at any angle and locked. With your fuel tank off and that lower bracket under the tank removed you can put the fittting in the tank and time it so it misses the fuel petcock and other bolts. To change oil just remove the cap and drain. Depending on the set up you may need some little funnel or something but mine "just" clears. Or you could slide a piece of hose over the end of the fitting.
And I purchased the hose kit prior to this. Even had the local weld shop copy it with some changes I thought of.
As for catching shavings that your filter isnt getting, glue a donut magnet to your oil filter cap if you have a particular worry.
YMMV
J8
Never push a loyal person to the point they don't care anymore.
No Humans, before Coffee!!
RIP my Mother, She should certainly be up for Sainthood!!
RIP my Cousin, Austin City Limits aka Terry Hammond
KTM950A, KLR685, KLR650, KLR250, KLX250, Honda Rebel, Foretrax Foreman 4x4
Jailor8 is offline   Reply With Quote
Old 02-14-2015, 09:52 PM   #199
outbacktaz
outbacktaz
outbacktaz's Avatar
Oddometer: 611
Quick question:
Since the hose is not an integral part of the pressurized oiling system, do you guys think I could get away with a nylon braided hose?
The point being that I could go all black on the system, and that those hoses can withstand temperature form 275F to 500F...
Thanks!!
Marty aka Outbacktaz!!
__________________________________________________
Only the dead have seen the end of War! George Santayana
To sin by silence makes cowards out of men! Ella Wheeler Wilcox
Peace is mostly valued by those who are sworn to protect it! Unknown
outbacktaz is offline   Reply With Quote
Old 02-14-2015, 09:56 PM   #200
Qwik
Adrenaline Addict
Oddometer: 6,738
I don't think it would be an issue. I don't think it's pressurized
Topes never seem to make me go any faster.
Qwik is offline   Reply With Quote
Old 02-14-2015, 10:59 PM   #201
bikyto
Dans le doute...gaz!
bikyto's Avatar
Oddometer: 2,177
Originally Posted by outbacktaz View Post
Quick question:
Thanks!!
the braided hose wasn't picked for the pressure but for an extra safety feature to protect the hose for outside damages
Personally, i put some shrink tube on top of it to make it all black.
The race is long and, in the end, it's only with yourself...
bikyto is offline   Reply With Quote
Old 02-15-2015, 08:14 AM   #202
rockitman4x4
ol retread
Oddometer: 92
I run the CJ hose on my 990, then I drilled about a 3/4 inch hole in the corner of my skid plate. Now I just drop the front bolts of the skid plate put a catch pan under the plate pull the plugs, oil drains into the skid plate out the hole into the catch pan. When it's all drained I clean the skid plate with brake cleaner and put it back together. Complete job in under 15 minutes. Or about the time it takes to drink a beer, well you have to have something to do when you're watching oil drain into a pan.
Stay thirsty my friends
rockitman4x4 is offline   Reply With Quote
Old 02-15-2015, 08:45 AM   #203
henryroten
Oddometer: 256
Do you have a trick for removing the oil filter without the mess that I always create?
2011 990R
henryroten is offline   Reply With Quote
Old 02-15-2015, 09:22 AM   #204
Qwik
Adrenaline Addict
Oddometer: 6,738
Yeah, brake cleaner to spray the mess off of everything when you are done.
Old 02-15-2015, 10:47 AM   #205
rockitman4x4
ol retread
Oddometer: 92
Everything goes into the skid plate and out the hole. Right, just use a can of brake cleaner to clean up the engine and skid plate, it all goes into the catch pan. Oh I do have a stavens racing skid plate which is wider then stock. Stay safe out there
Old 02-15-2015, 12:40 PM   #206
outbacktaz
outbacktaz
outbacktaz's Avatar
Oddometer: 611
A mess when you remove the oil screen??
You do remove the oil from the under pan before removing the screen, right? I use an aluminum plate, the kind you find in a kitchen, to catch anything coming out of it, which is very little... And it's reusable!!
My .02...
Merci Bikyto!! Bonne idée, but the nylon braiding should protect it, and it's cheaper... Most of the line is hidden behind cowlings or tank... And if something was to break the line, I figure that some other less manageable damage were to happen to the bike... Which would probably render it unrideable...
Qwik, thanks for your input as well!
Old 02-15-2015, 12:48 PM   #207
outbacktaz
outbacktaz
outbacktaz's Avatar
Oddometer: 611
Chris, how long does that hose need to be??
Old 02-15-2015, 01:51 PM   #208
Qwik
Adrenaline Addict
Oddometer: 6,738
I believe the drain hose on mine is about eight inches. It reaches to just under the middle of the stator cover and I secure it with ziptyes to the hard lines that run under the motor
Qwik screwed with this post 02-15-2015 at 01:59 PM
Old 02-15-2015, 05:28 PM   #209
outbacktaz
outbacktaz
outbacktaz's Avatar
Oddometer: 611
Thanks Qwik! So a 12" line would suffice... Cool!!
Old 02-15-2015, 11:57 PM   #210
bikyto
bikyto's Avatar
Oddometer: 2,177
Yes mine reaches a few cms past the oil filter cover. 12 inches works.
Times are GMT -7.   It's 04:39 AM.
