Old 01-05-2012, 01:43 PM   #1
AlexSonoma OP
Oddometer: 27
Which Oil Filter on '72 BMW r60/5?
I need to change my oil/filter on my BMW R60/5 but am not sure of which filter to use. I've found a few on the internet that look like they will work but thought I would ask the advice of someone who has done this before, before I order something. Also, hinged or straight? Any help would be greatly appreciated! Thanks!!
AlexSonoma is offline   Reply With Quote
Old 01-05-2012, 03:32 PM   #2
east high
east high's Avatar
Oddometer: 955
I got these and they've been good to me so far: http://goo.gl/rXY4M.
Hinged is the way to go.
'71 r75/5
east high is offline   Reply With Quote
Old 01-05-2012, 08:11 PM   #3
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,423
I've read about instances of collapsed elements on the one piece filters. I've never witnessed that. I stick with the hinged filters as they are easier to remove / replace, especially if you have a crash bar. I've always used the Mahle Filters. Not advisable to go with discount filters with such an important item IMO.
The Mahle Filters are getting expensive though, I paid $19.00 ea. for the last batch from Huckys.
http://jupiterhack.blogspot.com/
Living proof you shouldn't play with matches
ABC# 1992
bmwhacker screwed with this post 01-05-2012 at 08:22 PM
Old 01-06-2012, 02:35 AM   #4
Bill Harris
Confirmed Curmudgeon
Bill Harris's Avatar
Oddometer: 8,009
Thumb
Ditto on what 'Hacker sez.
'73 R60/5 Toaster
Old 01-06-2012, 08:52 AM   #5
AlexSonoma OP
Oddometer: 27
i ended up going with a Mann hinged filter which was slightly less expensive than the Mahle but hopefully still good quality.
Old 01-06-2012, 09:41 AM   #6
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Mann is/was one of the best.
O.E.M. for many many European companies.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
Old 01-06-2012, 11:54 AM   #7
Bill Harris
Oddometer: 8,009
Mann, Mahle, Knecht-- all "OEM" standard.
Yong Sung, no-go.
Noris ignition points are good.
'73 R60/5 Toaster
Old 01-06-2012, 01:39 PM   #8
disston
ShadeTreeExpert
disston's Avatar
Oddometer: 9,813
I found some really cheap oil filters. Called Hi-Flo. I haven't tried them yet but I will. I'm a living on the edge kinda guy. You might not understand.
Charlie
---Albert Einstein
Old 01-06-2012, 04:53 PM   #9
bmwhacker
Still on 3 wheels
bmwhacker's Avatar
Oddometer: 4,423
I think "EMGO" makes filters for the airheads too.
If their other "quality" products are any indication of workmanship, I'd avoid them too.
ABC# 1992
Old 01-06-2012, 05:15 PM   #10
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
hi flo is decent, so is K&N.
I think they are made by the same company.
best bang fer the buck.
www.wirewerkes.com
Times are GMT -7.   It's 03:55 AM.
