Old 01-05-2012, 08:08 PM   #1
k12lts OP
k12lts's Avatar
Oddometer: 339
Braided Stainless brake lines 81 R100RT
I need to replace the rubber brake lines on a newly aquired 81 R100RT. Any suggestions on brand or best price?
The best I've found are at Moto Bins in the UK.
k12lts is offline   Reply With Quote
Old 01-05-2012, 08:19 PM   #2
Beamer Bum
Beamer Bum's Avatar
Oddometer: 287
Spiegler
Spiegler has kits for your bike. http://www.spieglerusa.com/brakes/cy...line-kits.html.
Made in USA and the braided lines make your brakes feel much firmer.
"There’s probably no better way to go from New York to San Francisco on a motorcycle than on an R90S."
Cycle, January 1977 and Mike last night
Beamer Bum is online now   Reply With Quote
Old 01-05-2012, 08:43 PM   #3
SOLO LOBO
airhead or nothing
SOLO LOBO's Avatar
Oddometer: 8,715
Call cyclebbrakes.com they do custom Galfer's for something like $60, with a discount to ADVR's
"punkrocks what it's all about" - J. Strummer
SOLO LOBO is offline   Reply With Quote
Old 01-05-2012, 09:15 PM   #4
Hawk Medicine
Coyote's Brother
Oddometer: 3,302
I have used Spiegler's on a couple of my bikes and the difference in braking is significant but I'd also suggest that you rebuild or at least bleed your brakes for the best results.
With an unknown, used bike, I like to rebuild em.
Hawkdude
Hate rots the pocket that carries it.
Hawk Medicine screwed with this post 01-05-2012 at 09:23 PM
Hawk Medicine is offline   Reply With Quote
Old 01-05-2012, 09:32 PM   #5
Voltaire
Bored Of The Rings
Voltaire's Avatar
Oddometer: 1,477
I've just spent the last couple of days on mine.....rebuilt the 40 mm ATE calipers, fitted a new Brembo 13mm master cylinder...but the old hoses for test purposes.
Took me ages to get the air out....ended up with the calipers removed, sitting bleed nipples up on a box with a 25mm bar inserted in the calipers....
Got a reasonable 'pedal' but could with some effort pull the lever to the grip.Used up over a litre of fluid...
Today got some Allegri brand hoses that you buy in pre made lengths and bolt/loctite on the couplings.
Braided hoses used to be illegal here in NZ but this type meet our local standards.
Just finished my initial setting with the new hoses using the refined box/bar method....have already got a better 'pedal' on the lever, only 250 mils.....getting better at this...
Going to leave the lever with a carb rubber ring on it overnight and go and have a beer....its 24C here
I put a set on my Bevel a year or so back and it was definitely an improvement over the original 1978 ones...
Voltaire is offline   Reply With Quote
Old 01-05-2012, 09:33 PM   #6
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,400
The common upgrade from the oem brake lines are ss lines. After 30 years, they'll feel fantastically improved over the discards. So will a set of oem rubber lines, and they'll feel just as good as new ss.
With the multitude of ss options available, I'm guessing they'll be cheaper??
Another option is Venhill, via ebay.
Voltaire...try loosening the master cylinder and tilting it a bit to allow the air to bleed better. A mate does it that way and swears by it.
boxerboy81 is offline   Reply With Quote
Old 01-05-2012, 10:08 PM   #7
wirewrkr
the thread-killer
wirewrkr's Avatar
Oddometer: 4,295
Incredibly short memories you guys have.
BMWRENCH makes these line to order.
www.thenickwackettgarage.com
He's gives professional advice here constantly
for free.
www.wirewerkes.com
KILL YOUR TELEVISION !!!!
wirewrkr screwed with this post 01-06-2012 at 07:51 AM
Old 01-05-2012, 11:46 PM   #8
boxerboy81
Stay Horizontal
boxerboy81's Avatar
Oddometer: 2,400
He's gives professional advice her constantly/
for free.
From his website...
Custom Brake Lines There are now several companies making braided hoses, but mine are the only ones made by someone who is intimately familiar with BMWs and classic Triumphs. If you have a problem with the fit, or need a custom hose, you can call me. You’ll be speaking to the guy who makes them and has probably installed them on a bike just like yours.
Old 01-06-2012, 12:16 AM   #9
supershaft
Oddometer: 9,110
New braided teflon is a lot better than new rubber and lasts a lot longer too. My braided teflon lines are over twenty years old and they are just as firm as the day I got them. I have recently seen a rash of trouble caused by rubber lines going bad. Why bother with it.
Old 01-06-2012, 12:43 AM   #10
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,471
I fitted new pads and changed my brake fluid a couple of days ago - as an experiment I clamped the hose at the top, and the lever was rock hard.... then I clamped at the bottom of the hose and it was rock hard. With no clamp there is some softness in the lever. No real test with new pads of course, but I'm pretty confident there is no flex in my old rubber hoses. I might have to get my wife to recheck for me as I'm a bit weak - I tend to cry at sad movies.
motu is online now   Reply With Quote
Old 01-06-2012, 01:57 AM   #11
Tosh Togo
Oddometer: 1,594
"Clamped"?... please explain what that means.
Tosh Togo is offline   Reply With Quote
Old 01-06-2012, 02:54 AM   #12
motu
Loose Pre Unit
motu's Avatar
Oddometer: 4,471
Brake hose clamp - used when doing work on brake systems. I usually clamp the hose so when I push the pistons back fluid won't go back up into the master cyl. Also used in brake diagnosis (on cars) - clamp each wheel to see where problems are.
Old 01-06-2012, 07:32 AM   #13
k12lts OP
k12lts's Avatar
Oddometer: 339
for free.
Thanks for all the tips, I sent an email to these guys today.
Old 01-06-2012, 07:57 AM   #14
DaveBall
DaveBall's Avatar
Oddometer: 1,163
I have also used Spiegler's SS lines on my 81 RT. Got the complete kit that included the one for the back brake as well. Made a huge improvement. I have installed Spiegler lines on many bikes and have always found the fitment to be just about perfect.
Easiest way to bleed the back brake and actually make it work is to leave it on the bike. Get a couple of large syringes and use one to suck all the brake fluid out of the master cylinder, Then fill the other clean one with new brake fluid and use a small piece of clear tubing to attach it to the bleed nipple on the caliper, open up the nipple and slowly force brake fluid into the system. Eventually it will fill the master cylinder. Do this a couple of times and you should have a good solid brake pedal. I flush my brake fluid every 2 years this way. Always have a good working rear disk on my bikes.
As to the person that clamps his brake hose so that he can press the caliper pistons in without brake fluid going up into the master cylinder. Just were the hell does it go then? Also, I don't believe that clamping a hose does it any good, tends to weaken the hose at that point and will become a failure point. On something so critical as the braking system, I would not want to do anything that may compromise it, especially in an emergency stop situation.
DaveBall is offline   Reply With Quote
Old 01-06-2012, 10:42 AM   #15
photomd
photomd's Avatar
Oddometer: 718
If you want to make your own, pull the hoses on the bike, measure the diameter and threads of the banjo bolts and fittings. Then carefully write down what fittings go where, the number you need and go to Advance Autozone and order Earl's brake line stuff. It'll take a few days to get in, assemble it and you'll be done.
1979 V-1000SP
1988 R100RS
1996 R1100RSL
1998 CR250
photomd is online now   Reply With Quote
Times are GMT -7.   It's 08:16 PM.
