Old 01-11-2012, 04:54 AM   #1
Murphy Slaw OP
Murphy Slaw's Avatar
Oddometer: 1,555
Sportster "High Mileage" ?
Lotta Sportster talk lately.
Made me wonder......
How many miles will a well cared for Sporty run? You never read about 150,000+ on stock engines like you do the Suzuki (water cooled) V twins.
Is 50,000 considered "high miles" on the air cooled V?
I've never really paid much attention and was curious.
Murphy Slaw is offline   Reply With Quote
Old 01-11-2012, 06:19 AM   #2
kruzuki
Gear in the Machine
kruzuki's Avatar
Oddometer: 807
The thing about Sportsters (and HD in general) is that engine rebuilds are fairly easy. I had 3 Sportsters in a row, all had over 30k on them when I sold them and they were going strong.
www.XLforum.net should answer your questions
I'm allergic to asphalt, whenever I touch it I get a rash.
kruzuki is offline   Reply With Quote
Old 01-11-2012, 06:24 AM   #3
131unlimited
Oddometer: 452
All 4 cams are gear driven with hydraulic valves, which is a good design. Any Evo Sporster motor that is properly maintained and not beat on will live many miles and years, there will be the occasional rocker box leak to address, but they are out there running in excess of 50 k without requireing full rebuilds or needing the top ends redone. They are not touring bikes, so the amount of feedback you would get from guys who are racking up huge miles with them will be limited.
I got 60k out of my ironhead sporty motor ( rebuilt it from the ground up when I bought it as a basket case way back when ). It was running great when sold, hope the next owner treated her as good as I did...
131unlimited is offline   Reply With Quote
Old 01-11-2012, 08:50 AM   #4
grandelatte
Consistently Inconsistent
grandelatte's Avatar
Oddometer: 106
+1 on xlforum. Cindy Dietz from that forum has well over 100,000 miles on her Sportster.
"You ain't lost if you got gas in your tank." - Tommy the KLR rider
grandelatte is offline   Reply With Quote
Old 01-11-2012, 08:58 AM   #5
woodnbow
woodnbow's Avatar
Oddometer: 1,593
I'd consider 100K high miles if it's been maintained at recommended intervals and not beat on too badly. Evo Sportsters have a solid reputation outside of the rumor mills.
woodnbow is offline   Reply With Quote
Old 01-11-2012, 09:19 AM   #6
Phineas
Joe Lunchbox
Oddometer: 170
I was at the bike shop not long ago when a Sportster pulled in with 150K. It's ridden by a teacher from Pasadena to Moorpark Ca every day. It looked stock (or was not obnoxiously loud at least). The mechanic introduced us because of our respective mileages. He said that the motor had never been apart.
Phineas is offline   Reply With Quote
Old 01-11-2012, 10:26 AM   #7
rudolf35
Warped & Twisted Mind
rudolf35's Avatar
Oddometer: 797
Miles on a Sportster
As most have noted, a maintained Sportster is as dependable as they get. Making trips on them is also no issue. Took my XR on a extended run (after the ergonomics where addressed) and it performed flawlessly. In one year of ownership I put 16k on it (09 purchased late 10).
http://advrider.com/forums/showthread.php?t=727865
2013 Ural Gear-Up, 2008 Fatbob, 1999 Jeep Sahara, 1982 BMW R65LS, 1973 Honda CL350 K5, 1971 BMW R50/5
rudolf35 is offline   Reply With Quote
Old 01-11-2012, 05:56 PM   #8
Badge320
Wild Hog No. 3
Badge320's Avatar
Oddometer: 3,855
I worked part time for 2 Harley dealers for several years. I saw quite a few high mileage Sportsters. I had one customer with over 60k on his Sportster....with only routine maintenance.
Badge320 is offline   Reply With Quote
Old 01-11-2012, 06:01 PM   #9
natez1
Oddometer: 83
Guy I work with had 70,000 on his 04 sporty custom, ran as good the day he gave it to his son, as the day he got it! One day he thought the motor was coming apart till I told him he should adjust his primary chain once in a while. Tires, brakes and one belt that's it. Great bikes and low maintenance most problems I have seen is when people mess them up themselves otherwise anything under 50,000 is probably ok to buy, one with 100.000 probably needs the top-end done.
natez1 is offline   Reply With Quote
Old 01-11-2012, 07:02 PM   #10
pmelby
Home Brew Adventurer
Oddometer: 724
I agree that the H-D motors are well made with quality components, but....
It is painful for me to watch the motor vibrating in its mounts while the bike is stationary. The Sportster that I tested (2009 XR1200) rattled my eyeballs in their sockets if I gripped the bars too tight when stopped. Granted the vibrations are not an operational issue when the bike is actually in motion, but the fact that the vibration is part of the mistique of the brand, just doesn't sit right with me. As a maintenance technician dealing with rotating equipment, I cannot reconcile that the inherent unbalance of the H-D v-twin motor is a good thing.
cheap
reliable
fast
It has been pointed out on these forums that a bike can be built to any two of the three adjectives noted above. The H-Ds appear to use the first two. I realize that I'm not by any means an expert, but when I see the how the various components of the H-D engines are assembled (pressed together crank, hydraulic valves, etc.), and note the performance available from the stock bikes, the only two adjectives that I can apply to the sportster are CHEAP & RELIABLE.
I don't have any first hand experiance on how this relates to "High Mileage" ("?") but my gut feeling is that if a motor is trying to shake itself apart when idling, that things aren't much better when it is at a higher RPM and under load.
I'll more than likely get castigated regarding my comments above as a harley hater. But I'm not a hater. I cannot stand the open pipe crowd, and I do feel that H-D promotes noise above performance, but other than that I do have an open mind regarding H-D products.
cheers,
melby
Melby
'14 1190 ADV
'09 G450X
'85 K100RT
pmelby is offline   Reply With Quote
Old 01-11-2012, 07:11 PM   #11
wmax351
Oddometer: 743
They seem to be great bikes. Especially the evo-engined ones. The ironheads sound like they were sometimes pieces of shit, but still the most fun you can have on two wheels, and actually fairly reliable by '50s standards. Taken care of, they seem like they last a while.
I think one of the biggest issues with the evo-sportys (and most bikes in general) is that no-one leaves them alone. They are built under-stressed, and if you try to get more power out, without building it from the ground up, you lose longevity. Most buells are built sportster engines. They are built from the ground up to have 100hp, and be dead reliable. You put 100 hp through an otherwise stock sporty engine (IE: turbocharging), you have a very expensive grenade.
The other issue is starting them up, and then blasting off with high revs on a cold engine. Not good at all, especially on a hot running air cooled engine.
The other thing to remember, is that they are easily worked on, and inexpensively rebuilt, much like BMW airheads. There isn't all that much that will ever need replaced. Freshening up the top end really isn't a big deal.
If a sporty is what you want, get one and ride the snot out of it. Make sure the guy or girl you buy it from is on top of things, though. The bikes are pretty flake proof, but you don't want to mess with it. Buy a good one, and set it up how you like.
wmax351 is offline   Reply With Quote
Old 01-11-2012, 07:18 PM   #12
DAKEZ
DAKEZ's Avatar
Oddometer: 19,714
I thought it was fair enough.
cheers,
melby
Fortunately your gut has been proven wrong for over 25 years now.
A quick and easy rebuild should be planned at or around 100k miles IMO
“Watch out for everything bigger than you, they have the "right of weight"
Bib
DAKEZ screwed with this post 01-12-2012 at 10:59 AM
DAKEZ is offline   Reply With Quote
Old 01-11-2012, 07:43 PM   #13
Fireball
Robot Doc
Fireball's Avatar
Oddometer: 2,572
My FXDX has over 160K and full compression. The only major work I've done is added gear-driven cams because of the tensioner issue. I'm riding it from NJ to NM and back this year, no worries.
More fun than clowns on fire
Fireball is offline   Reply With Quote
Old 01-11-2012, 07:46 PM   #14
Fireball
Robot Doc
Fireball's Avatar
Oddometer: 2,572
I'm a maintenance technician in the candy manufacturing industry. We have shaker tables and slipstick conveyors that are low maintenance and stone-reliable. They make HD engines look like sewing machines
Old 01-12-2012, 04:35 AM   #15
Murphy Slaw OP
Oddometer: 1,555
I HAVE to ask.......
Do you make Atomic Fireballs?
Times are GMT -7.   It's 04:15 PM.
