01-29-2012, 01:58 PM
#46 |
because I can
Oddometer: 6,070
I think you have had a bad seal. You should be able to get your money back. it doesn't look right. Did you ever answer my question about the flywheel O-ring? Does it have one? Did you replace it?
01-29-2012, 02:55 PM
#47 |
Still on 3 wheels
Oddometer: 3,382
Yup, replaced the flywheel o-ring...twice.
We just returned from a hard 60 mile ride and no oil loss noted. Must have been a bad seal. It came in an engine rebuild kit I bought a while back. Maybe it was "real" old, new old stock.
01-29-2012, 03:00 PM
#48 |
Confirmed Curmudgeon
Oddometer: 3,891
This thread is good food for thought (or fodder for paranoia, whatever
). One upcoming Spring/Summer project might be the rear main seal/oil pump o-ring when I do clutch and tranny work. This is the Methusaleh of oil seals-- it's a silicone seal that has been in since the mid-1980's and hasn't leaked a drop (touch wood). I'm tempted to "leave well enough alone", but since I'm going to be in that far, I'd be remiss if I didn't do the RMS.I'll pay close attention to shiny spots and installation depth. I usually tap seals in with care, but I may invest in a seal installation plate with the depth stops.
'73 R60/5 Toaster |
01-29-2012, 03:20 PM
#49 |
because I can
Oddometer: 6,070
Everyone says how simple the job is. I think it is damn easy to all of sudden get the seal in super cocked and it F's up the seal's OD. I like a installation plate with all five bolt holes. It makes a big diff in getting the seal in straight the first time. Getting the seal out isn't so simple either if all the F'ed up seal bosses I run into are any indication. Drills and screws mess up a lot of cases. It's a shame because there is no need for them. All you need is a common hooked seal puller from the auto parts store.
01-29-2012, 04:34 PM
#50 | |
ShadeTreeExpert
Oddometer: 5,013
Yeaaaah ! We were running out of obscure twilight zone repair ideas. charlie
Never memorize something you can look up. ---Albert Einstein |
01-29-2012, 04:48 PM
#51 |
Dare to be Stupid
Oddometer: 3,789
I've heard about the depth of the seal several times but never got a definitive explanation. I've done several rear mains and I've put them in flush. All of those were on 80's model airheads.
So what's your 2 cents on the depth of the seal, SS? +1 on what SS said about using a 5-hole tool. I couldn't imagine bopping these things in with a hammer. I'm sure someone that does a lot of them could get good at it but that ain't me.
'85 BMW r80G/S--Another G/S on the road--Central America on a Shoestring--Nova Scotia on a Shoestring Proud SmugMug User Support ADV: Don't give those cheap bums your discount code |
01-29-2012, 06:41 PM
#52 | |
Still on 3 wheels
Oddometer: 3,382
I had a thick aluminum disc, which is actually a pipe "diameter gauge" holder, the disc is just a few MM's smaller than the outside seal diameter. It worked perfectly to tap the seal in squarely.....with a dead blow plastic hammer. After becoming quite intimate with the seal & bore it appeared to me the the seal seemed to sort of "bottom out" when it was flush with the engine case chamfers. In the end I got pretty good practice tearing the bike down and reassembling. The last sequence took me from 1:00pm until 5:00pm from start to finish (not counting 2 "refreshment" breaks) and I didn't have any parts left over.
01-29-2012, 06:51 PM
#53 |
Two Wheel Addict
Oddometer: 1,960
I have experience only with an '81 g/s but that was instructive as well as embarrassing. I put the seal in backwards, prompting a very tactful Anton to point out my (actually OUR--The Raven was involved) error. The second time took about 1/3 the time taken by the first replacement.
I am glad yout seal seems to be holding. I find it interesting that by following your failed attempts I have learned much more about what to do and what to watch out for than I could ever have learned by you installing it correctly and flawlessly the first time. Such is the nature of learning how to wrench. Thank you |
01-29-2012, 06:58 PM
#54 | |
because I can
Oddometer: 6,070
supershaft screwed with this post 01-29-2012 at 07:19 PM |
01-30-2012, 09:28 PM
#55 | |
Still on 3 wheels
Oddometer: 3,382
BTW....looks like the leaking problem has gone away and the rear of the engine is......as they say in Rural Montana : "Tighter than a bulls ass in fly season"...Yeeeee Haw.... bmwhacker screwed with this post 01-30-2012 at 09:34 PM |
05-02-2012, 11:52 AM
#56 | |
Oddometer: 79
Aren't we a bunch of performing seals?
I'm about to get started with this job (after getting that clutch lever arm weld squared away) and I have found a so much oil on the shelf that I'll be very interested in looking for cracks in the case also just to be safe, and now that I have a welder among my support team. How does one look for cracks on a case with a propane torch? Thanks, Mark |
