Old 06-22-2013, 10:31 PM   #31
lacofdfireman
Oddometer: 793
Wow, the cost for these is NUTZ..
lacofdfireman is offline   Reply With Quote
Old 08-13-2014, 02:05 AM   #32
Hedonist222
Hedonist222's Avatar
Oddometer: 197
Picked up a set of Adventure for my 500 EXC.
I wear size 10.5.
I found the stock pegs to be a bit small.
Hedonist222 is offline   Reply With Quote
Old 08-13-2014, 07:51 AM   #33
rburkat
rburkat's Avatar
Oddometer: 293
Nice foot peg, but it's made from aluminium which is soft and weak. Bought these, glanced a rock, and they just fell apart around the pin area. Not much strength/material there at all. Big waste of money for a week of usage.
Don't buy aluminium billet pegs! Ever!
rburkat is offline   Reply With Quote
Old 08-13-2014, 07:59 AM   #34
FakeName
Wile E Coyote SuperGenius
FakeName's Avatar
Oddometer: 1,818
Been bashing mine for over a year, work great for me.
2011 White 990 Adv S
2014 500EXC Black
FakeName is offline   Reply With Quote
Old 08-20-2014, 09:42 AM   #35
Hedonist222
Oddometer: 197
Couldn't install out lo-boy style.
The brake pedal would've been higher.
Oh yeah, be careful when wearing shorts. They'll cut you bad.
They do add stability. Very comfortable.
I wear size 11 boots.
The 2015 500 exc 6 days direct require any shims to fit.
Old 08-20-2014, 10:22 AM   #36
HiOctaneOverland
Oddometer: 20
I was looking for some new footpegs a few months ago, took the plunge and bought a set of the Fastway Adventure pegs - love 'em!
Not cheap but great pegs, great traction and great looking. They do add a bit of extra width when you put your footdown, but you quickly get used to placing your foot a bit wider and I don't think about it at all any more.
Finally, as someone mentioned above they are aluminium and therefore soft. I see that as an advantage not a problem. If you tap a rock hard enough I would rather the peg absorbs the energy (which has to go somewhere) and takes the smash. Easier and cheaper to replace a damaged or broken peg than straighten the frame or weld the brackets back on....
HiOctaneOverland is offline   Reply With Quote
Old 08-20-2014, 12:37 PM   #37
Chuckracer
Jerkus Maximus
Chuckracer's Avatar
Oddometer: 8,423
Seemed like with the Fastways, I was always "in between" splines on my shift lever. Tried them high, low, changed back and forth a couple times, finally put the stockers back on...ahhh, perfect!
2012 KTM 990 Adventure
Chuckracer is offline   Reply With Quote
Old 08-20-2014, 01:13 PM   #38
wilmar13
Oddometer: 744
I have standard Fastway's in lowboy position, and have same Goldilocks gripe about the shifter position. Another poster suggested kerfing the lever, bending and welding it. May do that eventually, but it would be nice to find a lever with a couple of holes to move the toe boss around for fine tuning, like the RC8 has.
'14 KTM 1190-R
wilmar13 is offline   Reply With Quote
Old 08-20-2014, 01:38 PM   #39
Yardstick OP
Hydrophobic
Yardstick's Avatar
Oddometer: 3,075
I have the same issue with the Fastway pegs. I just adapt to it and it hasn't been a problem. If you want the width (nearly) of the Fastways and an otherwise stock feel, the KTM Rally pegs are hard to beat:
Yardstick is offline   Reply With Quote
Times are GMT -7.   It's 01:42 AM.
