Old 01-15-2012, 11:50 AM   #1
booger1 OP
booger1's Avatar
Oddometer: 909
Clutch master cylinder leaking
Just got back, had to cut the trip a little short do to the clutch master cylinder leaking and starting to loose tension.
I've read a few posts on this issue, but there dated abit. Has there been any improvments, cures, or best replacment options?
Eating_goat_with_the_Cartel , Never_ventured_never_gained
oncostaricantime , boundlessbooger , 1998xr400buildwithe-start
Good judgment comes from experience. Experience comes from bad judgment - Mark_Twain
booger1 is online now   Reply With Quote
Old 01-15-2012, 12:58 PM   #2
DeeGee
I'm a Yorkshireman thanoz
DeeGee's Avatar
Oddometer: 1,884
There's an overhaul kit you can buy. I've had two go on me, one in the Czech Republic on the old 950 I had stolen and once on my current ride. Cost me around 35 for the O ring, spring and little piston/plunger.
I bought it from a KTM dealers so you should be able to source one. I did post up some pics of it at the time. I'll see if I can find them.
DeeGee is offline   Reply With Quote
Old 01-15-2012, 01:45 PM   #3
booger1 OP
booger1's Avatar
Oddometer: 909
Everything that I've read, seams that rebuilds don't last very long.
I'm looking for a long term fix. I've seen some expensive mc's, but if it's a long term fix I'm willing to do that.
Old 01-15-2012, 01:50 PM   #4
Dale950
Dale950's Avatar
Oddometer: 983
Yes Ive had the same problem over the years , put 2 or three kits through mine , at present it seems to have settled , but the next step is a new master or get the bore re sleeved in Stainless , problem seems to be the alloy bore wears .
Check out this Co that does it .
http://www.resleeve.com/sleeving.htm
Dale950 is offline   Reply With Quote
Old 01-15-2012, 02:14 PM   #5
booger1 OP
booger1's Avatar
Oddometer: 909
Thanks Dale. I'll try and get a hold of them this week.
Old 01-15-2012, 03:36 PM   #6
Dustodust
Dustodust's Avatar
Oddometer: 1,013
any master and lever that has the same size oil bolt would work
like maybe a Nissin off of a CRF 450 is where I'll be headed when mine blows
from a cloud of dust we race, then into the dust we return, across the finish line
04 KTM 950 S
04 KTM 525 EXC street plated
Old 01-15-2012, 03:44 PM   #7
AdvGa
AdvGa's Avatar
Oddometer: 1,320
Here is what I did and just Replaced with a better Radial Unit...for the rebuild kit lasted about a 1000 miles or so:
http://www.ktm950.info/how/Farkels/a...t_install.html
This works easier and now I can see the Fluid (w/20ml to spare) and has not budged in about 5k miles.
AdvGa is offline   Reply With Quote
Old 01-16-2012, 10:09 AM   #8
Navin
Navin's Avatar
Oddometer: 8,234
The 9.0 Magura clutch master is what you want. Under $200, shop around. Cuts pull by about 40%. Awesome mod nobody does.
Navin is online now   Reply With Quote
Old 01-16-2012, 11:53 AM   #9
dmn0507
dmn0507's Avatar
Oddometer: 352
Wicked
Mine was pretty worn out after 64K km and it was leaking (it started leaking a bit at 25K, but some fresh oil every 8-10K was enough to fix it) and since i'm cheap i've re-sleeved it (a friend did that for me) with a brass sleeve and its like new.
The piston is still the original one.
dmn0507 is offline   Reply With Quote
Old 01-16-2012, 12:15 PM   #10
rider914
Agnostic Adventurer
rider914's Avatar
Oddometer: 2,461
Originally Posted by Dustodust View Post
... like maybe a Nissin off of a CRF 450 is where I'll be headed when mine blows
Originally Posted by Navin View Post
The 9.0 Magura clutch master is what you want...
Stock master cyl on the adventure (not sure about other LC8s) has a large offset from the bars to clear the left side switch pod. Very different from the one on my 525 (also Magura) which is much closer to the bar. Not sure about the Nissin or others, but something to watch for.
-M
'05 950ADV
'04 525EXC D/S
'07 Tiger1050
Will herd cats for beer (... but I rescue puppies for free )
SmugMug (coupon: bLfv2vBXZicd6)
rider914 is offline   Reply With Quote
Old 01-16-2012, 04:42 PM   #11
booger1 OP
booger1's Avatar
Oddometer: 909
I contacted resleeve.com. Seems good enough for me, $120 plus shipping and I supply a rebuild kit.
I think thats the best way to go so that I can retain original parts and make it more durable with the stainless steel sleeve.
I contacted a local machine shop here in town and they want 3 hours min at $85 an hour, so very resonable. Let you all know how it works out when it's all said and done.
Thanks for all the suggestions.
Old 01-21-2012, 03:03 AM   #12
Quietus
Mariner
Quietus's Avatar
Oddometer: 477
I have the same problem for a few days now. I've talked with my mechanic and he told me that it's a common problem since KTM upgraded the slave cylinder - or on bikes that put evoluzione/oberon/etc. Since the slave is more robust the master gets worn quite easy. The rebuilt kits don't work cause the problem is in the housing of the piston and not on the piston or the sealings, so even if you rebuilt it, after some time it's gonna start leaking again. He suggested not to put another magura or another 10.5mm master cylinder because it's goint to happen again. Seems that the best option with no future problems will be a radial one from super duke that it's 16mm. I found one used for $150 and bought it. I'll install it by the end of next week and I'll post an update.
Cheers
Dakar Team F5 proud member
Not all those who wander are lost..
KTM 990 Adv: "The Black Machine"
KTM 690 Enduro: "Agent Orange"
Quietus is offline   Reply With Quote
Old 01-21-2012, 12:02 PM   #13
Navin
Navin's Avatar
Oddometer: 8,234
-M
Sicass Racing switch solves that. My 9.0 has been dandy up against a Evo slave. The SD had a super stiff pull, I'd avoid that.
Old 02-02-2012, 01:03 PM   #14
booger1 OP
booger1's Avatar
Oddometer: 909
Cheers
Have you installed this yet???
Just got word back from resleeve.com that they will not be able to do this. There web site says 1/4 in and up but they say they can't so there sending it back to me today.
i guess I'll just put the rebuild kit in for now, but still want a better fix.
Old 02-03-2012, 09:07 AM   #15
rsuncloud
rsuncloud's Avatar
Oddometer: 27
Clutch resleeve
Do you or your friend have any pictures? I think I know what you mean but a picture is worth..... Saw a link for someone from uplan ca using stainless sleeve??
If you are born to hang
Do not fear the gun
rsuncloud is offline   Reply With Quote
Times are GMT -7.   It's 12:04 PM.
