Old 02-03-2012, 09:22 AM   #16
booger1 OP
booger1's Avatar
Oddometer: 928
For now I ordered a new MS and will look into this further when I have time, for right now I jsut want to ride. I contacted some one else in northern Ca. He asked for some pics before sending it to him, but I have to wait for the old to get back to me before doing this.
Eating_goat_with_the_Cartel , Never_ventured_never_gained
oncostaricantime , boundlessbooger , 1998xr400buildwithe-start
Good judgment comes from experience. Experience comes from bad judgment - Mark_Twain
booger1 is offline   Reply With Quote
Old 02-03-2012, 11:40 AM   #17
dmn0507
dmn0507's Avatar
Oddometer: 352
Originally Posted by rsuncloud View Post
Do you or your friend have any pictures? I think I know what you mean but a picture is worth..... Saw a link for someone from uplan ca using stainless sleeve??
No pics sorry, anyways the brass sleeve has about 3mm thick wall (internal diameter just a little over the piston diameter).
No need to reach the bottom of the MC with the new sleeve, 4-5 mm from the bottom is ok, that's the space where only the piston spring goes, so even if the sleeve isnt perfectly aligned with the old hole is not a big deal.
dmn0507 is offline   Reply With Quote
Old 02-03-2012, 12:17 PM   #18
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,066
Did you have to make a hole at the side
just where the liquid store feeds new liquid into the system? What dia hole did you drill to fit the sleeve in? Where did you find such a smooth pipe?
Old 02-04-2012, 01:38 AM   #19
dmn0507
dmn0507's Avatar
Oddometer: 352
Right! i've forgot about that :)
The brass sleeve was obviously machined by my friend, dont know exactly the external diameter of the sleeve, but roughly it was 15mm, i would say "the thinner, the better" (so u dont need to drill out a lot of your m/c) as long as its strong enough to be slightly (almost nothing) pressed in, we used some loctite to avoid any leak.
I drilled the hole (actually 2) for the reservoir, the big one is 2mm IIRC, the tiny one is about 0.5mm and its in front of the other hole, under the little metal screen (this is the self-purge hole), i've used a .7mm because it was the thinnest available. After drilling i've smoothed the inside of the sleeve with some fine sandpaper (just where the holes are).
Holes drilled AFTER installing the sleeve, of course.
Old 02-08-2012, 07:49 AM   #20
Quietus
Mariner
Quietus's Avatar
Oddometer: 477
SD's master cylinder installed. I had to buy an adapter for the tube to be able to fit as it has smaller diameter but nothing else. Just installed it, bleed it and ready to go. It's somehow stiffer than the original but not that much that it can be a problem even when I drive downtown during rush hour.
Cheers.
Dakar Team F5 proud member
Not all those who wander are lost..
KTM 990 Adv: "The Black Machine"
KTM 690 Enduro: "Agent Orange"
Quietus is offline   Reply With Quote
Old 02-08-2012, 09:32 AM   #21
75monza
75monza's Avatar
Oddometer: 355
I used the 10.5 Magura on mine. The rebuild kits didn't work for me.
What is the benifit of the 9 Magura vs the 10.5? I thought you wanted to have the 10.5 size on the ADV bikes?
2006 KTM 950 Adventure - Go Everywhere Bike
1993 Suzuki GSX1100G - Street Touring Shafty
2000 Suzuki DR200 - A Little Smaller
75monza is offline   Reply With Quote
Old 02-08-2012, 10:35 AM   #22
Navin
Navin's Avatar
Oddometer: 8,337
About a 40-50% reduction in lever pull. It is only good, no downside. Why anyone goes stiffer is a mystery to me.
I did it as a performance mod, my OEM masters were fine and I sold them as used parts. All my KTMs and Huskys with Magura masters got a 9.0, including 3 950s. Never a problem with any of them, worth doing even when you don't "need" it.
Navin is online now   Reply With Quote
Old 02-08-2012, 12:10 PM   #23
gefr
Life is a trip
gefr's Avatar
Oddometer: 4,066
A few more questions
why 2 holes?
what do you mean self purge hole?
sand paper inside a 10.5mm hole?
the inside of the sleeve was made on a lathe?
great mod I should say. Cheers
Old 02-08-2012, 12:53 PM   #24
75monza
75monza's Avatar
Oddometer: 355
Thanks. I will have to remember that for the future.
Old 02-09-2012, 09:57 AM   #25
dmn0507
dmn0507's Avatar
Oddometer: 352
why 2 holes?
the small one (if u sit on the bike and look into the reservoir, its about 3mm on the right of the main hole) lets the air escape (if there is some) when u start to pull the lever but the piston will pass it soon, so it doesnt affect the clutch operation
a little piece of fine sandpaper on the tip of a screwdriver, just to smooth out a little where the holes are
yep
Old 02-09-2012, 11:24 PM   #26
Deviant666
Present
Deviant666's Avatar
Oddometer: 536
I like to workout while I ride....Seriously, the SD master (which is ridiculously expensive and worth having only as a used part) isn't that much stiffer than the stocker. I'd say about 15-20% and that's without the Oberon slave installed that's supposed to lighten the pull.
KTM 990 Adventure White 2009 R specced
ZZR1400 ABS 2008
Deviant666 is offline   Reply With Quote
Old 02-10-2012, 01:42 AM   #27
Quietus
Mariner
Quietus's Avatar
Oddometer: 477
exactly, is not that bad just a little stiffer but not a real issue while driving. The whole setup cost me under $200 so I was the way to go for me.
Old 02-10-2012, 12:40 PM   #28
Navin
Navin's Avatar
Oddometer: 8,337
A one finger clutch pull is worth its weight in gold.
Still not getting this as it offers nothing in the way of an upgrade. All negatives only.
Old 02-10-2012, 01:02 PM   #29
NeilP
Oddometer: 73
Going the re-sleeving route
Experiencing a weeping master cylinder as well. 2006 950 Adv, 17K miles
Have called a few bicycle stores that are Magura dealers and they can order the OEM Magura MC for $280 CDN.
Decided I'll go the re-sleeving route and found this place in New York which I'll ship the part off to.
Apple Hydraulics
http://applehydraulics.com
They will re-sleeve with brass for $90, adding shipping both ways I'm probably up to $130ish in the end. Worth a try if it cures it.
Hope this helps someone
NeilP is offline   Reply With Quote
Old 02-10-2012, 01:09 PM   #30
Navin
Navin's Avatar
Oddometer: 8,337
http://compare.ebay.com/like/350489574922
That and a sicass racing light switch gives you more bar room so you can cut them down AND a "off" headlight switch AND less lever effort.
Times are GMT -7.   It's 08:41 PM.
